linux herkent mijn pcmcia wifi niet
  • 48 views sinds 30-01-2008
Omdat mijn vorige topic gesloten werd,
Deze guide net gekregen van een user die WEL zo vriendelijk was, alleen ik snap het niet echt
1) Log in as root.
2) Install gcc. niet nodig, heb je waarschijnlijk nl. al
3) Somehow get the latest ndiswrapper release on your system from http://sourceforge.net/projects/ndiswrapper/ (ndiswrapper-0.8.tar.gz as of this post). The tar should fit on a floppy.
4) Extract ndiswrapper whereever you like.
5) Enter the directory where you extracted ndiswrapper in a terminal window.
6) Type 'make install'
7) Somehow get the latest rtl8180 Windows XP drivers from http://www.realtek.com.tw...s1-3.aspx?Keyword=rtl8180 onto your system. You need the rtl8180.sys and net8180.inf files. Put these two files in any directory you want.
8) In your terminal, type 'ndiswrapper -i /path/to/net8180.inf'
9) Type 'ndiswrapper -l' and make sure net8180 is present.
10) Type 'modprobe ndiswrapper'
11) Type 'iwconfig' and make sure there is a wireless device present, usually it will be recognized at 'wlan0'
12) Type 'ifconfig wlan0 up'
13) Type 'ndiswrapper -m'
14) Type '/usr/bin/internet-druid' to open your Internet Configuration Wizard. Or if you use Gnome, it should be in the System Tools menu.
15) Chose 'Wireless Connection' from the list, then click 'Forward'
16) Select 'ndiswrapper (wlanX)' from the list, then click 'Forward'
17) Fill in the proper settings. Usually the mode will be 'Managed'. Hit the 'Forward' button.
18) Then there is another page of settings, make sure they are correct, and finish the wizard.
19) Upon completion of the wizard, the 'Network Configuration' window should pop up. At least it did for me. If it doesn't, you can type '/usr/bin/system-control-network' to open it, or you can open the 'Network Device Control' via the System Tools menu in gnome. Activate your wireless network card. It'll probably be 'Inactive'. Then if it prompts you to save your settings. Click 'Yes'.
20) Now go back to your terminal window, and type 'ping -c 2 google.com'. If all is well, you should be able to ping google.com with no problems.
1) Log in as root. (Dit is toch gewoon opstarten he ?)
Daar ging ik dus vanuit..
Toen heb ik dat tar.gz bestandje uitgepakt in linux.
Dat lukt allemaal nog wel :P maar nu..
Hier snap ik het al niet meer..
Kan iemand mij hier AUB mee helpen.. het lukt me echt niet
  • r0b
  • Laatst online: 29-10 09:15
r0b
KDE -> System tools -> Terminal window (iets in die trant, even rondzoeken. :) )
Hierna zal er naar een wachtwoord gevraagd worden; dit is je root wachwoord. Vul deze in en druk op enter.
Typ nu: cd <dir waar je het pakketje naar hebt geëxtract>, bijvoorbeeld: cd /home/tonks/ndiswrapper/
En typ nu 'make install' (zonder de quotes). :)
[ Voor 5% gewijzigd door r0b op 24-04-2005 22:11 . Reden: typo ]
  • Jaap-Jan
  • Laatst online: 30-10 08:48
Gewoon doen wat daar staat? Die directory binnengaan en make install doen zodat hij gaat compileren?
Trouwens, je vorige topic is dichtgegaan wegens een gebrek aan eigen initiatief. Ook hier blijkt niet echt dat je al veel dingen hebt geprobeerd...
| Last.fm | "Mr Bent liked counting. You could trust numbers, except perhaps for pi, but he was working on that in his spare time and it was bound to give in sooner or later." -Terry Pratchett
  • Boudewijn
Boudewijn
omdat het kan
omdat je zelf wss echt niks gaat doen:
su
en dan make install....
su maakt je root en make install moet je als root doen!
en please: om de zaak voor jou en voor ons leuk te houden; ga zelf eerst eens wat doen...
Japie_17 schreef op zondag 24 april 2005 @ 20:48:
Jawel heb al geprobeert hoor voor ik dit topic opende
  • Boudewijn
Boudewijn
omdat het kan
dat laat je niet zien :P
r0b schreef op zondag 24 april 2005 @ 20:47:
Hierna zal er naar een wachtwoor gevraagd worden; dit is je root wachwoord. Vul deze in en druk op enter.
Hey bedankt heb dit gedaan en kwam al weer een stukje verder :)
Alleen nu komt er een foutmelding (denk ik)
dit staat er nadat ik make install typ:
"make -c driver install
make[1] entering directory '/home/tim/desktop/tim/ndiswrapper-1.1/driver'
Can't find kernel sources in /lib/modules/2.6.8.1-12mdk/build:
give the path to the kernel sources with KSRC=<path> argument to make
make[1]*** [prereq_check] Error 1
make[1] Leaving directory '/home/tim/desktop/tim/ndiswrapper-1.1/driver'
make: *** [Install] Error 2"
Wat moet ik nu doen dan snap er niks van
  • r0b
r0b
Verwijderd schreef op zondag 24 april 2005 @ 21:49:
De volgende kernel sources installeren voor je Mandrake/Mandriva installatie:
ftp://fr.rpmfind.net/linu....6-2.6.8.1-12mdk.i586.rpm
Hierna kan je de installatie van ndiswrapper in principe weer hervatten met 'make install'.
(Uit "Can't find kernel sources in /lib/modules/2.6.8.1-12mdk/build:" blijkt dat je de 2.6.8.1.-12mdk kernel hebt, je kan dit even dubbel checken door "uname -a" uit te voeren in hetzelfde Terminal Window, als de output hiervan ook de 2.6.8.1-12mdk kernel aangeeft dan is het goed, is dit anders, dan zul je zelf even moeten zoeken naar de kernel sources)
Tip: mocht je ooit installatiebestanden nodig hebben voor Mandrake, kijk op www.rpmfind.net met het package name en mandrake als system. :)
Zo is er bijvoorbeeld ook een RPM (vergelijkbaar met een MSI onder Windows) voor Mandrake beschikbaar. Dan hoef je het niet zelf te compilen. :)
Zie de volgende url: http://www.rpmfind.net/li......&system=mandrake&arch=
En dat je er niks van snapt hadden we al door hoor. ;)
BoudewijnLinux schreef op zondag 24 april 2005 @ 22:20:
Hey wil je in het vervolg de error eens goed lezen?
Dit staat erin:
veel duidelijker kan niet imo hoor... je mist gewoon een zootje kernel modules voor 2.6.8.1 ;)
Kernel modules :? Kernel sources dus.
En je wil zeggen dat een nieuwe *nix user gelijk moeten weten wat kernel sources zijn, laat staan wat een kernel is? :o
[ Voor 49% gewijzigd door r0b op 24-04-2005 22:43 ]
  • Boudewijn
Boudewijn
omdat het kan
Dit staat erin:
  • blaataaps
We verwachten hier het een en ander aan basiskennis en zelfredzaamheid, de melding "Wat moet ik nu doen dan snap er niks van" is niet iets wat getuigt van die 2 dingen. Zeker als er een duidelijke melding staat "can't find xxx", dan ga je bijvoorbeeld op zoek naar wat xxx inhoudt.
Ook is
niet helemaal de juiste instelling ben ik bang. Zie bijvoorbeeld Je topic is dicht en het is onterecht? Lees hier! over wat te doen als je vindt dat je topic onterecht dicht is. Een kleine hint: een nieuw topic openen en een dergelijke toon aanslaan is niet de juiste weg.
