[XP] IE Favorieten
  • 126 views sinds 30-01-2008
  • Bschnitz
  • Laatst online: 11:36
beste medetweakers,
ik zoek nu al 1 week rond en vraag mensen maar niemaand schijnt te weeten hoe je de locatie waar de favorieten worden opgeslagen verandert dus in plaats dat ze onder je user profiel staan bv op de D schijf
alvast bedankt
WP: ME SUZ-SWM80VA + ERST20D-VM2D || PV: 12.000Wp || Batterij: SigenStor 12kW + 24kWh || A++++ 151m2 570m3 || Laadpaal: VoltTime One Business || Auto: Leapmotor B10 Design Pro Max 67,1 kWh
  • originalmycroft
  • Laatst online: 14-10 16:36
Gevonden door op google te zoeken naar "internet explorer store favorites location", bovenste hit. Succes!
Changing your Favorites Location
Added 10/6/96
You might want to change the location where the Internet Explorer looks for your store Favorite sites.
This can come in useful if you have multiple operating systems (Windows95 and NT 4.0) and want to share
the save set of Favorites or you simply want to have greater control over where you favorites are stored.
1. Start Regedit
2. Go to HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
3. Double click on Favorites in the right hand panel
4. Enter the new location
5. Click on the OK button
6. Do the same for the User Shell Folders section a few lines down
7. Close Regedit
8. Create the directory you just pointed to
9. Copy any existing Favorites to that location
10. Be sure to include all folders
11. Start the Internet Explorer
  • Spider.007
Spider.007
* Tetragrammaton
Niet zo lastig dus; verder is dit meer iets voor SA. Gelieve in het vervolg zelf ook even Google te gebruiken :)
WOS > SA
Prozium - The great nepenthe. Opiate of our masses. Glue of our great society. Salve and salvation, it has delivered us from pathos, from sorrow, the deepest chasms of melancholy and hate
