• ken
  • Laatst online: 28-10 21:50
Hoi
Mijn 8910i doet het niet meer 100%. mensen kunnen mij niet meer horen als ik zit te bellen. Ik kan de mensen wel joren. denk dat er iets fout is met de microfoon van de 8910i. Garantie is helaas verlopen. Ik wil hem dus zelf open maken. Iemand een idee hoe ik dat kan doen? Is er ergens een How To op internet te vinden?
Alvast bedankt :)
Canon 5D Mark II, Canon 35 f/1.4L
Als er een how to is, dan heb je die zelf vast al gevonden?
Heb je al gezocht op google?
Uit je starttopic blijkt eigenlijk van niet.
  • Gisae
hey i have an 8910i too and had to do some small changes to it so i had to find out the hard way in how to dismantle it.
this can be VERY TRICKY in taking it apart, it doesn't help knowing the phone is extremely expensive lol
first off unscrew two small screws at bottom of phone
take off back cover, battery, sim, antenna cover and that silver plate
(for silver plate, push down in centre and push up, it should slide off)
unscrew two screws behind antenna cover, and two underneath the silver plate
very carefully manouvre the C-shaped thing out of the phone, but while u are doing this apply pressure to the bottom sliding bit ie have the phone inbetween thumb and middle fingerpushing in a bit.
once the C-shaped silver metal brace has come out, the phone should extend a bit more than normal.
get some pliers, and carefully lift out the spring from next to the roller thing.
unscrew screw that holds roller in place.
that shud make it 7 screws so far; 5 large, 2 small.
now here's the tricky bit
the ribbon is stuck onto the metal casing - extremely annoying.
ull have to VERY SLOWLY peel some of it off
MAKE SURE YOU DO NOT RIP IT.
peel enough off so that the grooves on the top half move away from the two knobbly bits on the side of the phone.
that is the hardest part, however, depending on which bit u want to change, i might not be able to help any further, as the ribbon is somehow attached to the top half i dont know how, maybe soldered whatever .
u can change the top half two sections tho with ease, there should be one more screw under the ribbon.
however, the actual frame u might not be able to change, again the ribbon attachment is in the way.
u cud try and peelingthe whole ribbon off your old shell and triyng to stick it on your new one but EXPERIMENT WITH CARE.
hope this helps
1 minuut in google :/
Google zoeken naar: "how to dismantle" 8910i 1e hit.
Ja dus, maar daar had je natuurlijk zelf al naar zitten zoeken...
[ Voor 4% gewijzigd door Gisae op 21-04-2005 23:12 ]
Why have a civilization anymore if we no longer are interested in being civilized?
  • ken
Niet gevonden op Google. Of niet goed genoeg gezocht :)
Thanx
[ Voor 50% gewijzigd door ken op 21-04-2005 23:11 ]
voor dit soort dingen zoeken kun je beter altavista gebruiken
google filterd te veel weg
http://www.uselessinfo.pw...r.co.uk/dismantle8910.htm
[ Voor 28% gewijzigd door Verwijderd op 22-04-2005 14:39 ]
