SUSE 9.2 bad interpreter error
  • 40 views sinds 30-01-2008
Hi,
I have used slackware 10.1 for some time, and am now trying suse linux 9.2. After I made a clean standard install with KDE, I downloaded jdom-1.0.zip and several other things in order to setup a groupware workspace. So I downloaded the file into a directory, unpacked it, and then opened a terminal window and:
cd open-xchange
cd jdom-1.0
(untill then it went fine)
but then I tried to execute the build.sh file by:
./build.sh
at first I got an error saying "permission denied" due to permissions settings, so I enabled the ability to execute files in the root folder and subfolders.
And again I opened a terminal, went to the folder jdom-1.0, and tried to execute build.sh by ./build.sh.
And now I got the following:
linux:/ # cd open-xchange
linux:/open-xchange # cd jdom-1.0
linux:/open-xchange/jdom-1.0 # ./build.sh
: bad interpreter: No such file or directory
How can I fix this? A simple thing like executing a file..
thnx in advance anyways, grtz
  • blaataaps
Je vorige topics gingen ook prima in het nederlands, dus waarom deze niet? :)
Het probleem ligt vast in build.sh, dus daar even in kijken oftie soms een raar path ergens naar toe heeft, en anders regel voor regel kijken wat er fout gaat, succes!
