IRPStackSize geen netwerk i.v.m antivirus guard
Na het installeren van AVG Grisoft antivirus werkt mijn netwerk niet meer.
Het advies van Grisoft is om de stacksize te verhogen.
Waar vind ik dit in het register ?
To resolve this behavior, increase the IRPStackSize value in the registry:. Detailed description is available here: Microsoft 177078.
ADDITIONAL INFORMATION
This problem is caused by adding the AVG Resident Shield (implemented as Filesystem filter driver) into Filesystem stack. If all IRP packet positions are used by already existing filter drivers, adding one more driver in this situation can cause the same problem.
  • leuk_he
  • Laatst online: 29-08 20:52
leuk_he
1. Controleer de kabel!
[google=IRPStackSize]
1e hit 8)
NT4:
3. HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\LanmanServer\Parameters
4. Look for the IRPStackSize value. If the value does not exist, you must create it:
1. Right-click in the right pane, point to New, and then click DWORD Value.
2. Type IRPStackSize and then press Enter. Type the value exactly as shown; it is case-sensitive.
5. In the right pane, double-click the IRPStackSize value to enter edit mode.
6. Change the Base to decimal.
7. In the Value Data box, type 11.
8. Close the Registry Editor.
9. Restart the computer.
* To change IRPStackSize for Windows 2000, XP, and 2003
Windows dynamically adjusts this value. The IRPStackSize value is not created during the installation of Windows.
ALs het geen NT4 betreft, post dan eens wat meer info?
