[PHP] Downloaden & Uploaden m.b.v. FTP
  • Ad Hox
  • Laatst online: 23:41
Ik heb de volgende code in PHP:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
// FTP account aanmaken
// file defineren
$remote_file = 'BPFTP Server/Users.ini';
$handle = fopen('Users.ini', 'a+');
// FTP gegevens
$ftp_user_name = '*****';
$ftp_user_pass = '****';
$ftp_server = '*******.*****.net';
// verbinding maken met de FTP server
$conn_id = ftp_connect($ftp_server);
// login with username and password
$login_result = ftp_login($conn_id, $ftp_user_name, $ftp_user_pass);
// make dir
ftp_mkdir($conn_id, $gebruikersnaam);
// try to download $file
if (ftp_fget($conn_id, $handle, $remote_file, FTP_ASCII)) {
 echo "<font color=red><BR><LI>Download Succes (to Tommey.NL)\n";
} else {
 echo "<font color=red><BR><LI>There was a problem with downloading\n";
// schrijven
$dir = 'D:/sambar61/docs/';
$content = '
[$gebruikersnaam]
Login=$gebruikersnaam
Pass=$wachtwoord
Home-Ip=-= All IP Homes =-
RelativePath=1
TimeOut=600
MaxConPerIp=1
MaxUsers=0
RatioMethod=0
RatioUp=1
RatioDown=1
RatioCredit=0
MaxSpeedRcv=512
MaxSpeedSnd=512
QuotaCurrent=0
QuotaMax=5000000
Dir0=$dir\$gebruikersnaam
Attr0=RWDAMLSK
Info_Email=$email
Info_Notes=ip adres: $REMOTE_ADDR
Stat_Login=2
Stat_LastLogin=
Stat_LastIP=
Stat_KBUp=0
Stat_KBDown=0
Stat_FilesUp=0
Stat_FilesDown=0
Stat_FailedUp=0
Stat_FailedDown=0
fwrite($handle, $content);
// uploaden
ftp_fput($conn_id, $remote_file, $handle, FTP_ASCII);
// close the connection and the file handler
ftp_close($conn_id);
fclose($handle);
Nu krijg ik de volgende melding:
  • There was a problem with downloading
  • Warning: ftp_fput (): CANNOT STOR. No permission in register.php on line 404
Lijn 404: ftp_fput($conn_id, $remote_file, $handle, FTP_ASCII);
Wat ik heb gedaan:
  • Users.ini met CHMOD op 777
  • BPFTP Server/Users.ini staat niet meer op 'Alleen-lezen' (dat bestand staat op D:/, dan is ie toch wel gewoon writeable?
Hij mag (volgens mij) in geeneen bestand schrijven volgens mijn FTP webserver logs. Hoe los ik dit op?
(000003) 30-3-2005 16:42:50 - admin (81.173.33.6) > RETR BPFTP Server/Users.ini
(000003) 30-3-2005 16:42:50 - admin (81.173.33.6) > asked to download 'D:\sambar61\docs\BPFTP Server\Users.ini' --> Access denied.
(000003) 30-3-2005 16:42:50 - admin (81.173.33.6) > 550 Cannot RETR. No permission.
(000003) 30-3-2005 16:42:50 - admin (81.173.33.6) > PORT 81,173,33,6,225,206
(000003) 30-3-2005 16:42:50 - admin (81.173.33.6) > 200 Port command successful.
(000003) 30-3-2005 16:42:50 - admin (81.173.33.6) > STOR BPFTP Server/Users.ini
(000003) 30-3-2005 16:42:50 - admin (81.173.33.6) > asked to upload 'BPFTP Server\Users.ini' in 'D:\sambar61\docs\' --> Access denied.
(000003) 30-3-2005 16:42:50 - admin (81.173.33.6) > 550 Cannot STOR. No permission.
(000003) 30-3-2005 16:42:50 - admin (81.173.33.6) > QUIT
(000003) 30-3-2005 16:42:50 - admin (81.173.33.6) > 221 Bye bye ...
(000003) 30-3-2005 16:42:50 - admin (81.173.33.6) > disconnected. (00:00:00)
Vraag: EDIT: Hij schrijft dus wel in Users.ini, maar wat ie niet doet, zijn de variabelen invullen in dat bestand (terwijl bij MKDIR dat wel lukt, en daarvoor :S?)! Dus het gaat om het bestand wat op een HDD staat, hoe krijg ik die writeable, en die variabelen invullen?
[ Voor 15% gewijzigd door Ad Hox op 30-03-2005 16:58 ]
  • knopper
  • Laatst online: 11-08 12:15
knopper
Sander Knopper
Moet je sowieso niet deze functie gebruiken voordat je wat gaat uploaden: http://nl2.php.net/manual/en/function.ftp-alloc.php
  • djluc
  • Laatst online: 26-09 14:14
Werkt het voorbeeldje van http://www.php.net/ftp wel? Dan weet je in elk geval of het aan je script of ergens anders aan ligt.
Dit is een probleem met je FTP server, niet met je PHP scriptje, zo te zien.
Je hebt een 404 error. :P
