[Debian] apt-get error, dpkg probleem
  • 375 views sinds 30-01-2008
  • RutgerLAN
  • Laatst online: 25-08 12:46
Ik heb het volgende probleem. Heb net een apt-get upgrade uitgevoert, en hierna een error aan over gehouden.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
RutgerLAN-S2:/etc/init.d# apt-get install webmin
Reading Package Lists... Done
Building Dependency Tree... Done
webmin is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 32 not upgraded.
8 not fully installed or removed.
Need to get 0B of archives.
After unpacking 0B of additional disk space will be used.
Setting up libapache-mod-perl (1.29.0.3-4) ...
Error: mod_throttle.so does not have a corresponding .info file.
The above errors might cause apache to not work properly or start
Please refer to the documentation on how to fix it or report it to
Debian Apache Mailing List <debian-apache@lists.debian.org> if in doubt
on how to proceed
dpkg: error processing libapache-mod-perl (--configure):
 subprocess post-installation script returned error exit status 128
Setting up webmin-apache (1.160-3) ...
/etc/webmin/webmin.acl: No such file or directory
dpkg: error processing webmin-apache (--configure):
 subprocess post-installation script returned error exit status 2
Setting up webmin-core (1.180-1) ...
dpkg: error processing webmin-core (--configure):
dpkg: dependency problems prevent configuration of webmin-htaccess:
 webmin-htaccess depends on webmin-core; however:
  Package webmin-core is not configured yet.
 webmin-htaccess depends on webmin-apache; however:
  Package webmin-apache is not configured yet.
dpkg: error processing webmin-htaccess (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of webmin-logrotate:
 webmin-logrotate depends on webmin-core; however:
dpkg: error processing webmin-logrotate (--configure):
Setting up webmin-mysql (1.160-3) ...
dpkg: error processing webmin-mysql (--configure):
Setting up webmin-proftpd (1.160-2) ...
dpkg: error processing webmin-proftpd (--configure):
dpkg: dependency problems prevent configuration of webmin-virtual-server:
 webmin-virtual-server depends on webmin-core; however:
dpkg: error processing webmin-virtual-server (--configure):
Errors were encountered while processing:
 libapache-mod-perl
 webmin-apache
 webmin-core
 webmin-htaccess
 webmin-logrotate
 webmin-mysql
 webmin-proftpd
E: Sub-process /usr/bin/dpkg returned an error code (1)
Na apt-get remove webmin:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
RutgerLAN-S2:/etc/init.d# apt-get remove webmin
The following packages will be REMOVED:
  webmin webmin-apache webmin-core webmin-htaccess webmin-logrotate
  webmin-mysql webmin-proftpd webmin-virtual-server
0 upgraded, 0 newly installed, 8 to remove and 32 not upgraded.
After unpacking 21.4MB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 25095 files and directories currently installed.)
Removing webmin-htaccess ...
dpkg: error processing webmin-htaccess (--remove):
 subprocess pre-removal script returned error exit status 2
dpkg: error while cleaning up:
Removing webmin-apache ...
dpkg: error processing webmin-apache (--remove):
Removing webmin-logrotate ...
dpkg: error processing webmin-logrotate (--remove):
Removing webmin-virtual-server ...
dpkg: error processing webmin-virtual-server (--remove):
Removing webmin-core ...
dpkg: error processing webmin-core (--remove):
Removing webmin-mysql ...
dpkg: error processing webmin-mysql (--remove):
Removing webmin-proftpd ...
dpkg: error processing webmin-proftpd (--remove):
Removing webmin ...
 webmin-htaccess
 webmin-apache
 webmin-logrotate
 webmin-core
 webmin-mysql
 webmin-proftpd
Package webmin is not installed, so not removed
You might want to run `apt-get -f install' to correct these:
The following packages have unmet dependencies:
  webmin-apache: Depends: webmin (>= 1.140) but it is not going to be installed
  webmin-core: Depends: webmin but it is not going to be installed
  webmin-htaccess: Depends: webmin (>= 1.140) but it is not going to be installed
  webmin-logrotate: Depends: webmin (>= 1.140) but it is not going to be installed
  webmin-mysql: Depends: webmin (>= 1.140) but it is not going to be installed
  webmin-proftpd: Depends: webmin (>= 1.140) but it is not going to be installed
  webmin-virtual-server: Depends: webmin but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Na apt-get -f install:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
RutgerLAN-S2:/etc/init.d# apt-get -f install
Correcting dependencies... Done
The following extra packages will be installed:
  webmin
Recommended packages:
  webmin-core logcheck
The following NEW packages will be installed:
  webmin
0 upgraded, 1 newly installed, 0 to remove and 32 not upgraded.
Need to get 0B/1097kB of archives.
After unpacking 6050kB of additional disk space will be used.
Preconfiguring packages ...
Selecting previously deselected package webmin.
(Reading database ... 24028 files and directories currently installed.)
Unpacking webmin (from .../webmin_1.180-1_all.deb) ...
on how to proceed
Setting up webmin (1.180-1) ...
You already have /etc/webmin/miniserv.pem
 libapache-mod-perl
 webmin-apache
 webmin-core
 webmin-htaccess
 webmin-logrotate
 webmin-mysql
 webmin-proftpd
Ik wordt hier echt lichtelijk grijs van. :(
Heeft iemand een idee hoe ik dit oplos?
  • RutgerLAN
Oké, problem fixed! :)
Beide files ge-touched en klaar was ik.
Sorry :X
