Rare netwerk connectivity problemen. help!!
  • 62 views sinds 30-01-2008
  • Franck
  • Laatst online: 25-12-2024
We have a VERY odd problem going on in our network.
we have 3 servers, 2 domains:
SRV1 W2K3SRVstd.:
domainA
DC
WINS server
DNS server
DHCP server
SRV2 W2KSRVstd.:
DC
domainB.domainA
DNS server
SRV3 W2K3SRVstd.:
DomainA
DC
DNS
The problem:
If i use netview from SRV2 to SRV3 using name, everythings fine. If i use
net view \\<ipadressSRV3> i get system error 5 acces denied.
if i do the same from SRV1 there are no problems.
2nd problem (maybe related?):
SOME clients (xp and win2k)have problems connecting to SRV3 by name:
Nevt view from CLIENT1:
net view \\SRV3
system error 53
net view \\<IPAddressSRV3>
no problems.
It appears the clients that use our terminal server (SRV2) get this problem.
we use roaming profiles wich are stored on SRV3. Once a user that also uses the terminal server logs on to a client, the client gets this problem. After a reboot the administrator account wich does not use a roaming profile can contact SRV3 by name. Once a user that has the problem logs onto the client, the problems happens, and will jkeep happening untill the client is rebooted. It appears that there is something going wrong with the terminal service lockdown GPO, wich is ONLY applied to SRV2 terminal users. (its put on the OU domain controllers in wich srv2 is, nothing else is in there.
I have tried quite a lot. DNS does not report any problems. Also i have
checked the settins on the network controllers and they seem to be
functioning fine. all servers have 2 NIC's, SRV1 has 1 disabled and SRV3 has
one disabled. SRV2 uses both (with only one registering its adress in DNS) 1
locally and one in the same subnet as the other for terminal server clients
to connect to.
also dcdiag, netdiag and nltest seem to report no problems.
also when i ping -a <IPaddressSRV3> form SRV2 i get the correct name.
when i ping the name i get the correct ip address. The same goes for the
clients.
i also tried adding the SRV 3 to the hosts file. Same Problems.
8)7
Alvast hartelijk dank voor jullie hulp!
Franck
  • Koffie
  • Laatst online: 17:48
Koffie
Koffiebierbrouwer
Braaimeneer
Sorry, maar zo werkt het hier niet.
We zijn een Nederlands forum, met Nedrlands als voertaal.
Verder ben ik ook niet gecharmeerd van het geschreeuw in de topic titel.
Ik stel voor dat je er eens rustig voor gaat zitten, en een normale nederlands topicstart maakt.
Braaikamer - Smoke&BBQ
