script runnen in shell van mandrake
  • 56 views sinds 30-01-2008
  • Triple
  • Laatst online: 20-05-2025
Ik installeer een MSI wireless netwerk kaart in mandrake 10.0 met en sourceforge driver volgens de handleidingen op Ralinktech en http://rt2x00.serialmonkey.com.
De handleiding van de laatste site laat mij een script maken en daarna moet ik het script als root runnen.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
Create and run the following script as root from anywhere.
07:29, 4 Dec 2004 (PST)07:29, 4 Dec 2004 (PST)07:29, 4 Dec 2004 (PST)07:29, 4 Dec 2004 (PST)07:29, 4 Dec 2004 (PST)serialmonkey
#!/bin/sh
# By eaglenest@users.sourceforge.net
# July-August 2004, based on tips from the
# rt2400 Linux Driver project help forum
# (rt2400.sourceforge.net) - no copyright.
# This script brings up and connects an
# rt2400 chipset based wireless network
# card to a DHCP server. It is not validated
# with regard to static IP addressing.
ifconfig ra0 down
# Install the module if not installed
insmod /usr/src/rt2400-1.2.0/Module/rt2400.o
ifconfig ra0 up
# Set wireless parameters as needed
iwconfig ra0 mode Managed
iwconfig ra0 channel auto
iwconfig ra0 rate auto
#iwconfig ra0 nick nowhereman
#iwconfig ra0 key restricted [1] XXXXXXXXXXXXX
#iwconfig ra0 key [1]
iwconfig ra0 key off
# Note: scanning must start very soon after ifconfig
iwconfig ra0 essid any
# Connect to DHCP server (comment if not DHCP)
dhclient ra0
# Settings for static IP (i.e. not DHCP)
#ifconfig ra0 x.x.x.x netmask x.x.x.x broadcast x.x.x.x
#ip route add default via 192.168.1.1 dev ra0
# ./script
insmod: error inserting '/usr/src/rt2400-1.2.0/Module/rt2400.o': -1 File exists
Internet Software Consortium DHCP Client V3.0.1rc13
Copyright 1995-2002 Internet Software Consortium.
All rights reserved.
For info, please visit http://www.isc.org/products/DHCP
sit0: unknown hardware address type 776
Listening on LPF/ra0/00:08:a1:52:e6:27
Sending on LPF/ra0/00:08:a1:52:e6:27
Sending on Socket/fallback
DHCPDISCOVER on ra0 to 255.255.255.255 port 67 interval 7
DHCPOFFER from 192.168.254.254
DHCPREQUEST on ra0 to 255.255.255.255 port 67
DHCPACK from 192.168.254.254
bound to 192.168.254.5 -- renewal in 1054468517 seconds.
met emacs rt2500.sh heb ik een .sh bestand gecreerd en de bovenstaande text in het bestand gecopieerd. emacs afgesloten, en dan?
Nu moet ik het script runnen, maar ik heb geen idee hoe.
Er is vast wel iemand die hiermee uit de voeten kan.
Bedankt alvast!
There is no beast without cruelty, Friedrich Nietzsche
  • simon
  • Laatst online: 30-10 16:45
vanaf de commandline/terminal:
cd /dirvanjescript
./rt2500.sh
[ Voor 8% gewijzigd door simon op 19-03-2005 16:41 ]
  • blaataaps
Triple schreef op zaterdag 19 maart 2005 @ 16:39:
Bedankt alvast!
Hoe je programma's en scripts op moet starten is volgens mij op elk OS basisniveau, ook op linux dus :)
En laten we nou van mensen verwachten dat dit basisniveau bekend is (zie ook NOS policy - updated 22/09/2004), en volgens mij is er op internet ook wel genoeg te vinden over het opstarten van shellscripts (en nu ook in dit topic, omdat Simon het antwoord al gaf, vergeet alleen het executable bitje niet aan te zetten met chmod :).
[ Voor 4% gewijzigd door blaataaps op 19-03-2005 16:46 ]
