Ordinary 5076 fout melding bij opstarten programma.
  • TheLastOttoman
  • Laatst online: 22-09 01:17
Als ik een programma opstart krijg ik de volgende foutmelding: 'The ordinal 5076 could not be located in the dynamic link library MFC42D.DLL'. De dll's zijn compleet en ik kon verder geen atwoord vinden.
Alvast bedank.
Steam ID: TheLastOttoman
  • swampy
  • Laatst online: 12-10 00:07
swampy
Coconut + Swallow = ?
http://www.tek-tips.com/viewthread.cfm?qid=814485
Use dumpbin.exe /EXPORTS mfc42d.dll to get a list of all ordinals exported by this dll that is on your machine.
The 5076 ordinal is not present in the list and that means a call is forwarded to the mfc42d.dll to call a function with the 5076 ordinal and that function is not located in the dll.
Seems to use an old mfc42d.dll.
To solve the problem , find out which compiler was used to build the .exe that you are running.
You should to rebuild it or to suplly the mfc*.dll compatible with ones when it was built.
.. Ziet eruit dat er een probleem met de dll files is... en dat de falback dll ook niet werkt!
Misschien heeft microsoft hier een patch voor!
There is no place like ::1
