Ik heb momenteel m'n NEC3500 geflashed van firmware 2.18 naar 2.19, aannemende dat die nieuwer is dan 2.R8 die ik nergens kan vinden maar die DVDinfoPro nodig heeft om PIF/PI scans uit te voeren.
Nog steeds werkt ie niet, kan iemand me vertellen wat een R firmware is?
Dit kon ik vinden op internet:
Q: Can you explain the firmware numbering cause I am confused, 2.06=2.16=2.76?
A: NEC follows a pattern for each firmware revision: 2.xy, where:
X = Type (Retail, OEM, Rebadge)
Y = Revision number
Till today know patterns:
X = 0 (OEM)
X = 1 (Retail)
X = 2 (I-O Data)
X = 4 (Freecom)
X = 7 (TDK)
X = B (Ricoh)
X = F (MadDog)
Y = 6
Y = 7
Y = 8
Combining the above info for example we have
* 2.x6 (2.06/2.16/2.76/2.F6)
* 2.x7 (2.07/2.77)
* 2.x8 (2.F8/2.78) etc...
While the 2.x6 builds supposed to be the same, there is high possibility that due to writing strategy and released date differences, some of them are newer and hopefully better.
Is die 2.19 dus nieuwer dan 2R8?
Y = Revision number
X = 0 (OEM)
X = 1 (Retail)
X = 2 (I-O Data)
X = 4 (Freecom)
X = 7 (TDK)
X = B (Ricoh)
X = F (MadDog)
Y = 6
Y = 7
Y = 8
* 2.x7 (2.07/2.77)
