[acpi] throttling werkt niet meer
  • 100 views sinds 30-01-2008
  • technocow
  • Laatst online: 22-10 17:15
hallo,
ik heb hier al eens een toppic geopend over acpi en throttling.. toen werkte het te goed klik
na een reinstall en een paar kernel updates (zit nu op 2.6.11) kwam ik erachter dat throttling helemaal niet meer werkte :'(
dmesg | grep -i acpi :
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
 BIOS-e820: 000000000fff0000 - 000000000ffffc00 (ACPI data)
 BIOS-e820: 000000000ffffc00 - 0000000010000000 (ACPI NVS)
ACPI: RSDP (v000 PTLTD                                 ) @ 0x000f7040
ACPI: RSDT (v001 PTLTD    RSDT   0x06040001  LTP 0x00000000) @ 0x0fffc800
ACPI: FADT (v001 ASUS   L8400B   0x06040001 PTL  0x000f4240) @ 0x0ffffb65
ACPI: BOOT (v001 PTLTD  $SBFTBL$ 0x06040001  LTP 0x00000001) @ 0x0ffffbd9
ACPI: DSDT (v001  Intel   Trajan 0x06040001 MSFT 0x01000004) @ 0x00000000
ACPI: PM-Timer IO Port: 0x8008
ACPI: Subsystem revision 20050211
ACPI: Interpreter enabled
ACPI: Using PIC for interrupt routing
ACPI: PCI Interrupt Link [LNKA] (IRQs *9)
ACPI: PCI Interrupt Link [LNKB] (IRQs 9) *0, disabled.
ACPI: PCI Interrupt Link [LNKC] (IRQs 5 6 7 10) *0, disabled.
ACPI: PCI Interrupt Link [LNKD] (IRQs *9)
ACPI: PCI Root Bridge [PCI0] (00:00)
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: Embedded Controller [EC0] (gpe 9)
ACPI: Power Resource [PFAN] (off)
pnp: PnP ACPI init
pnp: PnP ACPI: found 13 devices
PCI: Using ACPI for IRQ routing
ACPI: AC Adapter [AC] (on-line)
ACPI: Battery Slot [BAT0] (battery present)
ACPI: Power Button (FF) [PWRF]
ACPI: Sleep Button (CM) [SLPB]
ACPI: Lid Switch [LID]
ACPI: Fan [FAN] (off)
ACPI: CPU0 (power states: C1[C1] C2[C2])
ACPI: Processor [CPU0] (supports 8 throttling states)
ACPI: Thermal Zone [THRM] (31 C)
Asus Laptop ACPI Extras version 0.29
ACPI: PS/2 Keyboard Controller [KBC] at I/O 0x60, 0x64, irq 1
ACPI: PS/2 Mouse Controller [MOUE] at irq 12
ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 9
ACPI: PCI interrupt 0000:00:08.0[A] -> GSI 9 (level, low) -> IRQ 9
ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 9
ACPI: PCI interrupt 0000:00:0a.0[A] -> GSI 9 (level, low) -> IRQ 9
ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 9
ACPI: PCI interrupt 0000:00:0a.1[B] -> GSI 9 (level, low) -> IRQ 9
ACPI: PCI interrupt 0000:00:07.2[D] -> GSI 9 (level, low) -> IRQ 9
ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 10
ACPI: PCI interrupt 0000:00:06.0[A] -> GSI 10 (level, low) -> IRQ 10
ACPI wakeup devices:
ACPI: (supports S0 S1 S3 S4 S5)
Maar mijn /sys/devices/system/cpu/cpu0/ blijft leeg.. waardoor de daemons niet willen starten.
ik heb mij helemaal gek gezocht met google ed maar kan niets zinnigs vinden (er is veel over het probleem te vinden maar er is nergens een oplossing :( )
Als er meer nodig is (spec's staan in het andere toppic) zoals een kernel config oid hoor ik het wel
  • igmar
  • Laatst online: 26-09 18:37
igmar
ISO20022
technocow schreef op vrijdag 11 maart 2005 @ 13:00:
Heb je CPU Frequency scaling in je kernel zitten ? De .config optie heet CONFIG_CPU_FREQ.
  • technocow
ja:
cat .config|grep -i cpu:
# CONFIG_X86_CPUID is not set
# CPU Frequency scaling
CONFIG_CPU_FREQ=y
# CONFIG_CPU_FREQ_DEBUG is not set
CONFIG_CPU_FREQ_STAT=y
CONFIG_CPU_FREQ_STAT_DETAILS=y
# CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not set
CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE=y
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
CONFIG_CPU_FREQ_GOV_POWERSAVE=y
CONFIG_CPU_FREQ_GOV_USERSPACE=y
CONFIG_CPU_FREQ_GOV_ONDEMAND=y
CONFIG_CPU_FREQ_TABLE=y
# CPUFreq processor drivers
# CONFIG_X86_ACPI_CPUFREQ is not set
# CONFIG_X86_CPUFREQ_NFORCE2 is not set
# CONFIG_X86_ACPI_CPUFREQ_PROC_INTF is not set
  • HarmoniousVibe
  • Laatst online: 26-10 10:16
modprobe acpi
SolarEdge SE5K-RWB + 17 × AIKO Neostar N-Type type ABC | WeHeat Blackbird P80 | 3 × MHI Diamond 2kW
  • technocow
erm ik zie geen "m" in mijn .config :?
ik heb dus geen modules..
  • technocow
klein schopje O-)
weet niemand iets ? of geef ik te weinig info ?
