Zoekfunctie heb ik gebruikt, aantal topics gevonden met hetzelfde probleem maar zonder oplossing.
Specs:
Computer:
Besturingssysteem Microsoft Windows XP Professional
OS Service Pack Service Pack 2
Internet Explorer 6.0.2900.2180 (IE 6.0 SP2)
DirectX 4.09.00.0904 (DirectX 9.0c)
Moederbord:
CPU Type Intel Pentium IIIE, 800 MHz (6 x 133)
Moederbordnaam ECS P6BAP-A+ (2 ISA, 4 PCI, 1 AGP, 3 DIMM)
Moederbord Chipset VIA VT82C693A Apollo Pro133
Systeemgeheugen 256 MB (SDRAM)
BIOS Type Award Modular (06/22/00)
Communicatiepoort Communicatiepoort (COM1)
Communicatiepoort Communicatiepoort (COM2)
Communicatiepoort Printerpoort (LPT1)
Scherm:
Video kaart NVIDIA RIVA TNT2 Model 64/Model 64 Pro (32 MB)
3D-Versneller nVIDIA RIVA TNT2 M64
Monitor Hyundai HL-7770RD (8406944)
Multimedia:
Geluidskaart C-Media CMI8738/C3DX Audio Device
Opslag:
IDE apparaat VIA Bus Master IDE Controller
Diskettestation Diskettestation
Harde schijf Maxtor 6E040L0 (40 GB, 7200 RPM, Ultra-ATA/133)
Optische Station 50X CD-ROM (50x CD-ROM)
Optische Station LITE-ON LTR-40125S (40x/12x/48x CD-RW)
SMART Status harde schijf OK
Moederbord boekje:
For this mainboard, you must use 1368-pin 3.3V non-buffered Dual In-Line Memory Modules (DIMMs). The memory chips must be standard SDRAM.
The memory bus can run at 66 Mhz, 100 Mhz or 133 Mhz. If you install memory chips that oparatse over a 66 Mhz bus, you must install memory chips that operate at 66 Mhz. If your processor operates over a 100 Mhz system bus, you can instal memory chips that operate at 66 or 100 Mhz. If your processor operates over a 133 Mhz system bus, you can install PC-100 or PC133 memory that operates over a 100 or 133 Mhz bus.
You must install at least one memory module and the first memory module should be installed in slot DIMM1, the second in slot DIMM2 and the third in slot DIMM3. If the modules use standard SDRAM, the maximum capacity of each module is 128 Mb (wat zo is)
The mainboard supports memory chips that have EC (Eroor Correction) or ECC (Error Correction Code). If you install more than one module, the modules can have different capacities, but the memory chips should all be the same type.
Voor 21% gewijzigd door
Verwijderd op 09-03-2005 20:07
