Cisco 801
Onlangs heb ik een Cisco 801 ISDN router geconfigureerd en getest. Het werkte allemaal.
Nu er een paar weken verstreken zijn belt de router niet meer naar buiten.
Via een telnet sessie heb ik het volgende gedaan, gevolgd door de meldingen:
ISDN_ROUTER#term mon
ISDN_ROUTER#ping 143.164.6.110
Type escape sequence to abort.
Sending 5, 100-byte ICMP Echos to 143.164.6.110, timeout is 2 seconds:
*Mar 1 19:46:34.869: BR0 DDR: rotor dialout [best] least recent failure is also
most recent failure
*Mar 1 19:46:34.869: BR0 DDR: rotor dialout [best] also has most recent failure
*Mar 1 19:46:34.877: BR0 DDR: Dialing cause ip (s=100.0.0.90, d=143.164.6.110)
*Mar 1 19:46:34.877: BR0 DDR: Attempting to dial 00204418586..
*Mar 1 19:46:38.629: BRI0: wait for isdn carrier timeout, call id=0x8016
*Mar 1 19:46:38.633: DDR: Dialing failed, 0 packets unqueued and discarded
*Mar 1 19:46:38.869: BR0 DDR: rotor dialout [best] least recent failure is also
most recent failure
*Mar 1 19:46:38.869: BR0 DDR: rotor dialout [best] also has most recent failure
*Mar 1 19:46:38.873: BR0 DDR: Dialing cause ip (s=100.0.0.90, d=143.164.6.110)
*Mar 1 19:46:38.873: BR0 DDR: Attempting to dial 00204418586..
*Mar 1 19:46:42.649: BRI0: wait for isdn carrier timeout, call id=0x8017
*Mar 1 19:46:42.649: DDR: Dialing failed, 0 packets unqueued and discarded
*Mar 1 19:46:42.869: BR0 DDR: rotor dialout [best] least recent failure is also
most recent failure
*Mar 1 19:46:42.869: BR0 DDR: rotor dialout [best] also has most recent failure
*Mar 1 19:46:42.873: BR0 DDR: Dialing cause ip (s=100.0.0.90, d=143.164.6.110)
*Mar 1 19:46:42.873: BR0 DDR: Attempting to dial 00204418586.
Success rate is 0 percent (0/5)
ISDN_ROUTER#
*Mar 1 19:47:12.873: BRI0: wait for isdn carrier timeout, call id=0x8018
*Mar 1 19:47:12.873: DDR: Dialing failed, 0 packets unqueued and discarded
Als ik via de webbrowser heb ik het volgende commando uitgevoerd:
/level/15/exec/-/isdn/test/call/interface/BRI/0/00204418586/1000
Dan reageerd de ISDN lijn wel, tenminste de oranje lampjes knipperen even.
Weet iemand wat er gaande is? Ik heb niet zo bar veel ervaring met Cisco en hoop dat iemand dat hier wel heeft :D
  • teigetjuh
kijk eerst eens of de lijn nog werkt.... en kijk eens in je debug wat ie doet als je gaat bellen.
debug isdn q921 ofzo gebruiken....
Ik krijg zoiets....
*Mar 1 00:49:25.640: ISDN BR0 Q921: User RX <- RRp sapi=0 tei=65 nr=17
*Mar 1 00:49:25.644: ISDN BR0 Q921: User TX -> RRf sapi=0 tei=65 nr=22
*Mar 1 00:49:26.544: ISDN BR0 Q921: User TX -> INFO sapi=0 tei=65, ns=17 nr=22
*Mar 1 00:49:26.572: ISDN BR0 Q921: User RX <- RR sapi=0 tei=65 nr=18
*Mar 1 00:49:26.768: ISDN BR0 Q921: User RX <- INFO sapi=0 tei=65, ns=22 nr=18
*Mar 1 00:49:26.776: ISDN BR0 Q921: User TX -> RR sapi=0 tei=65 nr=23..
*Mar 1 00:49:30.316: ISDN BR0 Q921: User RX <- INFO sapi=0 tei=65, ns=23 nr=18
*Mar 1 00:49:30.324: ISDN BR0 Q921: User TX -> RR sapi=0 tei=65 nr=24
*Mar 1 00:49:30.340: ISDN BR0 Q921: User TX -> INFO sapi=0 tei=65, ns=18 nr=24
*Mar 1 00:49:30.360: ISDN BR0 Q921: User RX <- RR sapi=0 tei=65 nr=19
*Mar 1 00:49:30.540: ISDN BR0 Q921: User TX -> INFO sapi=0 tei=65, ns=19 nr=24
*Mar 1 00:49:30.568: ISDN BR0 Q921: User RX <- RR sapi=0 tei=65 nr=20
*Mar 1 00:49:30.768: ISDN BR0 Q921: User RX <- INFO sapi=0 tei=65, ns=24 nr=20
*Mar 1 00:49:30.776: ISDN BR0 Q921: User TX -> RR sapi=0 tei=65 nr=25..
*Mar 1 00:49:34.040: ISDN BR0 Q921: User RX <- INFO sapi=0 tei=65, ns=25 nr=20
*Mar 1 00:49:34.044: ISDN BR0 Q921: User TX -> RR sapi=0 tei=65 nr=26
*Mar 1 00:49:34.060: ISDN BR0 Q921: User TX -> INFO sapi=0 tei=65, ns=20 nr=26
*Mar 1 00:49:34.080: ISDN BR0 Q921: User RX <- RR sapi=0 tei=65 nr=21
*Mar 1 00:49:34.540: ISDN BR0 Q921: User TX -> INFO sapi=0 tei=65, ns=21 nr=26
*Mar 1 00:49:34.568: ISDN BR0 Q921: User RX <- RR sapi=0 tei=65 nr=22
*Mar 1 00:49:34.756: ISDN BR0 Q921: User RX <- INFO sapi=0 tei=65, ns=26 nr=22
*Mar 1 00:49:34.764: ISDN BR0 Q921: User TX -> RR sapi=0 tei=65 nr=27
*Mar 1 00:49:34.776: ISDN BR0 **ERROR**: host_disconnect_ack: Unfound B-channel
on Disconnect_Ack call id 0x800A.
ISDN_ROUTER#
*Mar 1 00:49:40.956: ISDN BR0 Q921: User RX <- INFO sapi=0 tei=65, ns=27 nr=22
*Mar 1 00:49:40.960: ISDN BR0 Q921: User TX -> RR sapi=0 tei=65 nr=28
*Mar 1 00:49:40.968: ISDN BR0 **ERROR**: CCBRI_Go: NO CCB Src->L3 call id 0x800
8, event 0x96 ces 1
*Mar 1 00:49:40.972: ISDN **ERROR**: Module-CCBRI Function-_Go Error-Event r
eceived for an unrecognized call. Data- 96, 0
*Mar 1 00:49:44.788: ISDN BR0 Q921: User RX <- INFO sapi=0 tei=65, ns=28 nr=22
*Mar 1 00:49:44.792: ISDN BR0 Q921: User TX -> RR sapi=0 tei=65 nr=29
*Mar 1 00:49:44.800: ISDN BR0 **ERROR**: CCBRI_Go: NO CCB Src->L3 call id 0x800
9, event 0x96 ces 1
*Mar 1 00:49:44.800: ISDN **ERROR**: Module-CCBRI Function-_Go Error-Event r
*Mar 1 00:49:52.812: ISDN BR0 Q921: User RX <- RRp sapi=0 tei=65 nr=22
*Mar 1 00:49:52.816: ISDN BR0 Q921: User TX -> RRf sapi=0 tei=65 nr=29
*Mar 1 00:50:00.832: ISDN BR0 Q921: User RX <- RRp sapi=0 tei=65 nr=22
*Mar 1 00:50:00.836: ISDN BR0 Q921: User TX -> RRf sapi=0 tei=65 nr=29
*Mar 1 00:50:04.524: ISDN BR0 **ERROR**: CCBRI_Go: NO CCB Src->HOST call id 0x800A, event 0x5 ces 1
*Mar 1 00:50:08.852: ISDN BR0 Q921: User RX <- RRp sapi=0 tei=65 nr=22
*Mar 1 00:50:08.856: ISDN BR0 Q921: User TX -> RRf sapi=0 tei=65 nr=29
*Mar 1 00:50:10.948: ISDN BR0 Q921: User RX <- INFO sapi=0 tei=65, ns=29 nr=22
*Mar 1 00:50:10.956: ISDN BR0 Q921: User TX -> RR sapi=0 tei=65 nr=30
*Mar 1 00:50:10.960: ISDN BR0 **ERROR**: CCBRI_Go: NO CCB Src->L3 call id 0x8008, event 0x97 ces 1
*Mar 1 00:50:10.964: ISDN **ERROR**: Module-CCBRI Function-_Go Error-Event received for an unrecognized call. Data- 97, 0
*Mar 1 00:50:10.968: ISDN BR0 Q921: User TX -> INFO sapi=0 tei=65, ns=22 nr=30
*Mar 1 00:50:10.988: ISDN BR0 Q921: User RX <- RR sapi=0 tei=65 nr=23$49:34.568: ISDN BR0 Q921: User RX <- RR sapi=0 tei=65 nr=22
Owja, en als ik er een ISDN toestel op aansluit werkt het gewoon.
