Opdracht voor school: Engels
  • 43 views sinds 30-01-2008
jah ik heb een opdracht voor ICT 2(studie Economie & Management) en ik denk dat de meeste hier op dit forum wel wat meer verstand van hebben als ikzelf:
Mary Kay updates the websites of its vendors by distributing a file with information, photos and prices of its products. The size of the file is 5.2MB. In 25% of the cases, vendors that use phone-line connections (mainly those of small vendors that use them as TPS) have to reload the file from the beginning, due to disturbances in the connection.
a. Calculate the necessary time for downloading the catalogue file with phone-line (56Kbps), ISDN (128Kbps) and ADSL (192Kbps) connections.
!!!!! het erge is, degene die de college's geeft heeft gezegd op het college dat we B in het verhaaltje niet als bit maar als Byte moeten zien, omdat dat makkelijker rekent :S:S dus met telefoonlijn max 56kilobyte/s en de in de volgende vraag die 10Mb/s= dus max 10 Mbyte/seconde)!!!!! :(
b. The maximal capacity of Mary Kay’s Internet connection is 10Mbps. The number of vendors can connect to the server and download the file is limited by this capacity. How long would it take to distribute the file to 125,000 online vendors, if the connections of vendors are distributed as follows:
15% of the vendors are connected via phone lines.
30% of the vendors are connected via ISDN.
55% of the vendors are connected via ADSL.
Assume that ADSL users are first connected, then ISDN users and finally phone line users.
c. In the past (1997), Mary Kay had a 2.3Mbps connection, and the connections of the vendors were distributed as follows:
75% of the vendors are connected via phone lines.
20% of the vendors are connected via ISDN.
Again, assume that ADSL users are first connected, then ISDN users and finally phone line users. How long did it take to distribute the file to 125,000 online vendors?
iemand die mij kan helpen?
  • Nik
  • Laatst online: 06-11 06:31
Nik
Zie de FAQ, dit is een huiswerkvraag, en dat mag niet... We willen je best helpen, maar we gaan niet je huiswerk maken he :+
Voor al je huiswerk: www.google.nl
:Z
[ Voor 16% gewijzigd door Nik op 08-03-2005 18:43 ]
  • PipoDeClown
PipoDeClown
Izze Zimpell
b = bit
B = byte
is volgens mij al eeuwen zo.
God weet alles, want hij is lid van de Mosad. To protect your freedom i will take that away from you. Mijn drankgebruik heeft ernstig te lijden onder mijn gezondheid.
... meer verstand van hebben DAN ikzelf.
  • RSD1982
  • Laatst online: 19-12-2025
wat heeft dit btw met engels te maken lijk me meer een wiskunde som 8)
jaja oke, ik bedoel de b in de Kbps, die hoofdletter was onnodig dus.
En ach dan ik, als ik, heb het toch tot de universiteit geschopt! O-)
Engels: De vraag is in het Engels...
[ Voor 13% gewijzigd door Verwijderd op 08-03-2005 18:51 ]
  • dusty
  • Laatst online: 04-11 19:14
dusty
Celebrate Life!
Buiten het feit dat dit dus een huiswerk vraag is, heeft het erg weinig van doen met Internet en telefonie ( ohja ik zie de woorden ISDN, ADSL.. ) maar dat maakt het vraag stuk nog steeds een wiskunde vraag stuk. Het is een simpel rekensommetje, dat je met wat nadenken best zelf zou moeten kunnen maken.
Back In Black!
"Je moet haar alleen aan de ketting leggen" - MueR
a. De file kan met de volgende verbindingen zo snel gedownload worden:
phone-line (56Kbps) 12,67 minuten (overhead niet meegerekent)
ISDN (128Kbps) 5,5 minuten(overhead niet meegerekent)
ADSL (192Kbps) connections. 3,96 minuten (overhead niet meegerekent)
Deze formule kan je gebruiken:
((f * 1024) / (s / 8 )) / 60
Waarbij:
f = file grootte
s = Snelheid in bit/s
De rest kan je nu zelf wel, denk ik. :)
[ Voor 1% gewijzigd door Xandrios op 08-03-2005 19:20 ]
