[VB] HTML file (table's) naar Excel wegschrijven
  • kippy
ik ben bezig met een programma om een helle hoop gegevens uit een html te halen en in een Excel sheet weg te schrijven.
Dit is mij ook gelukt, maar ik denk dat ik dit heel omslagtig doe.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"><HTML><!-- Constructed with LabVIEW Report Generation --><HEAD><TITLE></TITLE></HEAD><BODY><BR>8/31/20043:56 PM<BR><TABLE WIDTH="400.000000"><TR><TD>Typenumber:</TD><TD>tl280n42</TD></TR><TR><TD></TD><TD></TD></TR><TR><TD>Voltage:</TD><TD>229.66</TD></TR><TR><TD>Current:</TD><TD>0.777</TD></TR><TR><TD>Power:</TD><TD>178.21</TD></TR><TR><TD>Powerfactor:</TD><TD>0.998</TD></TR><TR><TD>Frequency:</TD><TD>50.00</TD></TR><TR><TD>THD :</TD><TD>3.942</TD></TR></TABLE><BR><TABLE WIDTH="400.000000"><TR><TD>    1 Harm.</TD><TD></TD>
<TD>778.030</TD><TD>  mA</TD><TD></TD><TD>100.000</TD><TD>  %</TD></TR><TR><TD>    2 Harm.</TD><TD></TD><TD>  0.622</TD><TD>  mA</TD><TD></TD>
<TD>  0.080</TD><TD>  %</TD></TR><TR><TD>    3 Harm.</TD><TD></TD><TD> 18.144</TD>
<TD>  mA</TD><TD></TD><TD>  2.332</TD><TD>  %</TD></TR><TR><TD>    4 Harm.</TD><TD></TD><TD>  0.187</TD><TD>  mA</TD><TD></TD><TD>  0.024</TD><TD>  %</TD></TR><TR><TD>    5 Harm.</TD><TD></TD><TD>  3.867</TD><TD>  mA</TD><TD></TD>
</TR></TABLE></BODY></HTML>
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
                'vvvvvvvv***Array***vvvvvvvv
                    een = Asc(een)
                    Dim intI As Integer, intJ As Integer
                    intJ = 1
                    For intI = 0 To 9
                        For intJ = 0 To 99
                            DynamicArray(intI, intJ) = (Chr(een) & (intJ + twee))
                        Next intJ
                        een = een + 1
                    Next intI
                '^^^^^^^^^Array***^^^^^^^^^
                    intI = 0
                    intJ = -1
                    Dim fs, f, ts, s
                    Set fs = CreateObject("Scripting.FileSystemObject")
                    filetoopen = Application.GetOpenFilename("Harmonic files (*.prn), *.prn")
                    Set f = fs.GetFile(filetoopen)
                    Set ts = f.OpenAsTextStream()
                    Do While s <> "</BODY>"
                    s = ts.read(1)
                        If s = "<" Then
                            s = ts.read(1)
                                If s = "T" Then
                                    s = ts.read(1)
                                        If s = "D" Then
                                            s = ts.read(1)
                                                If s = ">" Then
                                                    s = ts.read(1)
                                                        If s <> "<" Then
                                                            twee = ""
                                                            Do While s <> "<"
        If s <> "<" Then
        twee = (twee & s)
        End If
        s = ts.read(1)
                                                            Loop
                                                            Worksheets("Sheet1").Range(DynamicArray(intI, intJ)) = twee
                                                        intI = intI + 1
                                                        End If
                                                End If
                                        Else
                                            If s = "R" Then
                                                intJ = intJ + 1
                                                intI = 0
                                            End If
                                        End If
                                Else
                                    If s = "/" Then
                                        s = ts.read(1)
                                            If s = "B" Then
                                                s = ts.read(4)
                                                    If s = "ODY>" Then
                                                        s = "</BODY>"
                                                    End If
                                            End If
                                    End If
                                End If
                        End If
                    'MsgBox twee
                    Loop
                    ts.Close
iamdn een idee om dit makkelijker te berijken, ik heb het al geprobeert met
ts.readline
maar dan moet ik daarna weer die <TD> en andere zut weg filteren, wat me al helemaal niet lukt.
  • CodeCaster
CodeCaster
Stop AI Slop
Wel...
s = ts.read(4)
                        If s = "<TD>" Then
Waar is de brand, meester?
  • kippy
CodeCaster schreef op dinsdag 08 maart 2005 @ 15:45:
Wel...
s = ts.read(4)
                        If s = "<TD>" Then
Dat hoopte ik ook idd, maar dat zal niet werken, omdat je op dat moment elke keer 4 tekens inleest.
je leest dan ook dingen in als
D>45
op dat moment dal ik dus waardes missen (absoluut niet de bedoeling)
  • CodeCaster
CodeCaster
Stop AI Slop
Als je een regel inleest:
Instr(LCase(Regel),"<td>")
Geeft dan de positie terug van de tekst "<td">. Hoofdlettergevoelig, vandaar de LCase(), die het omvormt naar kleine letters.
Hierna:
Regel = Replace(Regel, "<td>", "")
Verwijdert de <td> tag uit de regel, zodat je deze direct in Excel kunt plaatsen.
Replace is ook hoofdlettergevoelig, zijn die HTMLs consequent hierin?
  • kippy
CodeCaster schreef op dinsdag 08 maart 2005 @ 15:53:
Hierna:
Ja alle <TD> en <TR> "dingen" (ben ff de naam kwijt) zijn het zelfde. die mannier van inlezen ziet er nuttig uit, ik zal het morgen even gaan uitproberen.
  • beetle71
  • Laatst online: 16-10 14:05
Misschien een hele 'domme' opmerking, maar zo'n html filetje als je in je Topicstart zet kun je in excel gewoon openen. (In ieder geval in Excel2003) En excel converteerd 'm netjes naar een normaal werkblad.
  • kippy
beetle71 schreef op dinsdag 08 maart 2005 @ 16:25:
klopt, maar op mijn werk willen ze het graag van uit een progje kunnen laden (in dit geval vb). ik zou het dan ook wel in een andere excel sheet kunnen oppenen en dan kunnen copieeren naar de juiste plek.......
maar daar heb ik nog niet echt over na gedacht... opzich geen gek idee.
  • RobIII
RobIII
Admin Devschuur®
^ Romeinse Ⅲ ja!
(overleden)
Naar mijn idee is een welgevormde RegEx beter op zijn plaats hier dan door het bestand heen jassen met allerlei reads. Ik heb (toevallig) zojuist wat code geplaatst wat hier wel wat van weg heeft: [rml]RobIII in "[ VB6] carriage return & line feed wissen..."[/rml]
Je ziet op regel 12 een replace staan en daarna wordt het bestand weer weggeschreven. Die replace zou ik vervangen door een RegEx (Regular Expression) Replace en vervolgens het bestand wegschrijven als CSV, of desgewenst gewoon een Excel.Application object aanzwengelen en de data erin "pasten".
Wat betreft de RegEx kan ik je wel nog een beetje op weg helpen:
Visual Basic:
    Dim oRegEx as object
    Set oRegEx = fCreateObject("VBScript.RegExp")
    With oRegEx
        .IgnoreCase = True
        .Global = True
        .Pattern = "<(.|\n)+?>"
        MyString = .Replace(myString, ",")
    End With
    Set oRegEx = Nothing
Ik denk dat het pattern ( "<(.|\n)+?>" ) of de replace value ( "," ) misschien nog wat bijgeschaafd moet worden, maar allez you get my drift heh? :D
Waarschijnlijk heb je dan een tikkie sneller programma :+
De "uiteindelijke" code zou dus iets worden als:
Visual Basic:
    Dim FF As Integer
    Dim sTMP As String
    'Bestand in 1 klap inlezen
    FF = FreeFile                   'Vrije file handle
    Open "C:\blabla\myfile.txt" For Binary As #FF
    sTMP = String(LOF(FF), Chr(0))  'Init string op lengte bestand
    Get #FF, , sTMP                 'Lees bestand in string
    Close #FF                       'Klaar met lezen, handle vrijgeven
    With oRegEx
        .IgnoreCase = True
        .Global = True
        MyString = .Replace(sTMP, ",")
    End With
    'sTMP hier wegschrijven naar bestand (zie linkje in mijn post) of naar
    'een Excel.Application object gooien (m.b.v. een "Paste" method
    'of iets dergelijks of door de juiste .Cells te zetten)
[ Voor 46% gewijzigd door RobIII op 09-03-2005 03:23 ]
Je eigen tweaker.me redirect
Over mij
  • sopsop
  • Laatst online: 16-10 09:02
sopsop
[v] [;,,;] [v]
inhakend op de regexp methode,
Het lijkt mij dan handiger om een match te maken op <tr>xxx</tr> en <td>xxxx</td>
En dat met twee regexpjes, In quasi pseude code:
Visual Basic:
29
30
31
32
i = 0
    With oRegEx
        .IgnoreCase = True
        .Global = True
        .Pattern = "\<tr\>\n?(.*?)\n?\<\/tr\>"
        .Global = True
        .IgnoreCase = True
        Set Matches = .Execute(regstr)
        For Each Match in Matches
             ' dit is nu 1 string met de <tr></tr> erin
             ' nieuwe regexp
             redim preserve regel(i)
             Set oRegEx2 = fCreateObject("VBScript.RegExp")
             With oRegEx2
                .IgnoreCase = True
                .Global = True
                .Pattern = "\<td\>\n?(.*?)\n?\<\/td\>"
                .Global = True
                .IgnoreCase = True
                Set Matches2 = .Execute(regstr)
                For Each Match2 in Matches2
                    '  en hier heb je dus je <td></td> waarden
                    regel(i) = regel(i) & ";" & Match2.Value
                    ' je zou ook een 2 dimensionale array kunnen gebruiken, dan hoef je geen ";" als scheiding te gebruiken.
                Next
            End With
            Set oRegEx2 = Nothing
            i = i + 1
        next
    End With
  • kippy
boppert schreef op woensdag 09 maart 2005 @ 11:19:
Visual Basic:
29
30
31
32
i = 0
    With oRegEx
        .IgnoreCase = True
        .Global = True
        .Global = True
        .IgnoreCase = True
             ' nieuwe regexp
             With oRegEx2
                .IgnoreCase = True
                .Global = True
                .Global = True
                .IgnoreCase = True
                Next
            End With
            i = i + 1
        next
    End With
dank dank, ik zal het vanmiddag meteen even uitproberen.
  • RobIII
RobIII
Admin Devschuur®
^ Romeinse Ⅲ ja!
(overleden)
Visual Basic:
    With oRegEx
        next
    End With
Zorg dan in ieder geval dat je niet elke keer een regex instantieert in die lus :X Tevens zie ik niet waarom je nou met arrays zou gaan moeten werken :? Die zul je dan trouwens ook nog eens god-weet-hoe-vaak moeten redimmen om "mee te groeien" naar het juiste aantal elementen (of je moet vantevoren weten hoeveel waardes je hebt, of je moet een belachelijk groot dimmen en maar hopen dat 't past :X ) Je hebt dus inderdaad gekozen voor Redim Preserve maar behalve dat dat nogal geheugenfragmentatie oplevert is het dus ook niet erg efficiënt. Replace dan meteen met die regex alle waarden. Dat is nou juist waar die dingen zo sterk in zijn. Kwestie van het juiste pattern vinden :Y)
Oh, en fCreateObject is natuurlijk je eigen functie die CreateObject "vervangt" met wat error-handling enzo neem ik aan, maar dat moet je er dan wel even bij vermelden ;)
[ Voor 114% gewijzigd door RobIII op 09-03-2005 11:40 ]
Over mij
  • kippy
Zorg dan in ieder geval dat je niet elke keer een regex instantieert in die lus Tevens zie ik niet waarom je nou met arrays zou gaan moeten werken Die zul je dan trouwens ook nog eens god-weet-hoe-vaak moeten redimmen om "mee te groeien" naar het juiste aantal elementen (of je moet vantevoren weten hoeveel waardes je hebt, of je moet een belachelijk groot dimmen en maar hopen dat 't past )
Ik weet hoe veel waardes er iedere keer zijn dus dit is niet echt een probleem. Ik weet nammelijk anders niet hoe ik iedere keer de waarde in een ander vakkie kan krijgen.
  • kippy
Kan ik ook in een keer een Excel template of gewoon Excel bestand, op een "on button event" naar een van te voren ingegeven plek in een ander Excel document plakken.
Het idee is: wanneer iemand op de button "voeg meet zooi toe" drukt dat ze een menutje krijgen waar ze de kollom en rij kunnen bepalen. als ze dan op enter drukken of iet dergelijk wordt de template geladen en op de ingevoerde plaats gedumpt. Hierna kunnen ze nog de metingen toevoegen.
Ik heb wel een idee voor de rest, maar geen idee hoe ik een template op een bepaalde plek kan plakken (met de rest van de cellen ook nog goed uitgelijnd)
  • RobIII
RobIII
Admin Devschuur®
^ Romeinse Ⅲ ja!
(overleden)
kippy schreef op woensdag 09 maart 2005 @ 13:39:
Je vraagt wel érg veel nu. Je wil vanalles, maar ik heb het idee dat je geen flauw benul hebt waar je mee bezig bent (NOFI). Dat is niet erg, we hebben het allemaal moeten leren. Maar doe het dan rustig aan en stapje voor stapje.
Probeer eens met VB(A) te kijken of je een Excel bestand kunt openen, ga dan eens kijken of je uberhaupt iets er in kunt krijgen en ga dan kijken hoe je het op de juiste plek krijgt met de juiste uitlijning etc. Het Excel.Application object en alles daaronder is prima gedocumenteerd, er is zat over te vinden op het web en zelfs met de Macro-recorder moet je een heel eind kunnen komen.
Het is niet de bedoeling dat we alles gaan voorkauwen hier.
[ Voor 6% gewijzigd door RobIII op 09-03-2005 13:49 ]
Over mij
  • kippy
Ja sorry sorry. ik zit zelf niet op te letten wat ik doe.
Tis alleemaal vrij simpel, alleen mensen willen steeds dat ik het anders doe. maar het is mij al gelukt. zal nog alleen maar "moeilijke" dingen vragen :P
maar toch bedankt, denk dat ik ff pauze moet gaan houden
