Eerste Open Office 2.0 Beta Candidate uit !!
  • Jk_W
Jk_W
I Think...
Ik heb dat hij fijn werkt! Ik ben een groot OoO fan....
Eens gaan testen...kijken wat er nou in de praktijk is verbeterd, Ik hoop grammatica controle...
  • simon
  • Laatst online: 16:04
Is er qua uiterlijk eigenlijk veel veranderd, ben nog wat afwachtend voordat ik ga testen. Grammatica controle kon toch al met de juiste libs?
Simon schreef op dinsdag 01 maart 2005 @ 22:23:
Ja !! Het belangrijkste is native widgets (voor Win32 alleen voor XP) Uit de nieuwe features lijst:
Native system theme integration (native widget rendering)
To enhance integration of OpenOffice.org with the underlying operating system, all user interface elements (such as buttons and scrollbars) will have the same look as those used in most other 'native' applications for that platform. OpenOffice.org will react on-the-fly to changes of the desktop theme, so when the user changes the desktop colors or theme, OpenOffice.org will adjust its own appearance to match.
Native system theme integration will be available for Gnome (version 2.4 or higher), Microsoft (R) Windows (including XP and future versions), and KDE (version 3.2 and higher) desktop environments. On Windows XP the 'Windows XP Style' must be chosen under Settings - Control Panel - Display - Appearance to achieve the correct look.
Theme integration will be the default for desktop environments that support it (listed above). Systems (for example, Windows 98/ME/2000, CDE) that do not support it will see no visual change in OpenOffice.org. On supported systems OpenOffice.org will always adopt the theme of the system and cannot choose not to do so.
