Apache Log
Ik heb een Apache version 2.0.51 + php 4.3.10 ( FC2 )
Daar krijg ik wat gekke log files, teminste in mijn ogen gek.
29
30
31
32
33
34
35
[Fri Feb 25 10:51:30 2005] [warn] child process 8114 still did not exit, sending a SIGTERM
[Fri Feb 25 10:51:30 2005] [warn] child process 8115 still did not exit, sending a SIGTERM
[Fri Feb 25 10:51:30 2005] [warn] child process 8116 still did not exit, sending a SIGTERM
[Fri Feb 25 10:51:30 2005] [warn] child process 8117 still did not exit, sending a SIGTERM
[Fri Feb 25 10:51:30 2005] [warn] child process 8118 still did not exit, sending a SIGTERM
[Fri Feb 25 10:51:30 2005] [warn] child process 8119 still did not exit, sending a SIGTERM
[Fri Feb 25 10:51:30 2005] [warn] child process 8120 still did not exit, sending a SIGTERM
[Fri Feb 25 10:51:30 2005] [warn] child process 8121 still did not exit, sending a SIGTERM
[Fri Feb 25 10:51:30 2005] [warn] child process 8132 still did not exit, sending a SIGTERM
[Fri Feb 25 10:51:30 2005] [warn] child process 8136 still did not exit, sending a SIGTERM
[Fri Feb 25 10:51:30 2005] [warn] child process 8146 still did not exit, sending a SIGTERM
[Fri Feb 25 10:51:30 2005] [warn] child process 8148 still did not exit, sending a SIGTERM
[Fri Feb 25 10:51:30 2005] [warn] child process 8149 still did not exit, sending a SIGTERM
[Fri Feb 25 10:51:30 2005] [warn] child process 8150 still did not exit, sending a SIGTERM
[Fri Feb 25 10:51:31 2005] [notice] caught SIGTERM, shutting down
[Fri Feb 25 10:51:32 2005] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Fri Feb 25 10:51:33 2005] [notice] Digest: generating secret for digest authentication ...
[Fri Feb 25 10:51:33 2005] [notice] Digest: done
PHP Warning:  Unknown(): in Unknown on line 0
[Fri Feb 25 10:51:33 2005] [notice] mod_python: Creating 32 session mutexes based on 150 max processes and 0 max threads.
[Fri Feb 25 10:51:34 2005] [notice] Apache configured -- resuming normal operations
Mijn vraag gaat over dit stukje
ik zou graag willen weten hoe ik die meldingen kan oplossen.
van child process 8150 still did not exit sending a SIGTERM
en de php Warning Unknow
Grtz!
Lijkt alsof daar apache herstart wordt. Door cron of zo....
aha, ik zal er zometeen is naar kijken! alvast bedankt
  • Boudewijn
Boudewijn
omdat het kan
iets in /var/log/messages??
of hoe dat dan ook in FC heet
Ik heb even gekeken. en ik ben eruit.
ik gebruik webmin om sites toe te voegen met alles er op en eraan.
als ik nu op apply in webmin bij apache module druk krijg ik die fouten..
in iedergeval bedankt voor het meedenken :)
topic kan dicht!
