[MSI K8N Neo2] S-ATA Raid probleem
  • Jilvoos
  • Laatst online: 30-10 19:41
Ok aangezien alle [Ervaringen] topics zijn gesloten (alle 5 dacht ik) maak ik hier even een aparte topic van.
Allereerst mijn config:
MSI K8N NEO2-54G (Bios v1.4)
AMD 64 3200+ @ Stock
2x 256Mb TwinX PC4000 @ 200mhz
2x 80gb Maxtor S-ATA (Port 3 en 4, ik wil overclocken)
Radeon 9700Pro @ stock
NEC 3500AG (geeft problemen met bord)
Nlite 811S (geen idee of het problemen geeft)
S-ATA Raid drivers van nForce 5.10
Dan mijn probleem:
Allereert doe ik dit
1. Hook up the drive to serial port 1/2/3/4. There has been issues around with people using SATA port 1 and 2 in regards to overclockability. If possiblealways use SATA port 3 or 4 unless doing a Raid 0+1 or 1 where 4 are required.
2. Very first thing we will do is boot into the BIOS and go into “Standard CMOS Features”
3. Check to make sure your drive is located on what SATA channel you have the drive plugged into
4. Go into “Integrated Peripherals”
5. Press ENTER on “Onboard Devices”
6. Press ENTER on “RAID Config”
7. Locate the “SATA1/4 RAID” make sure whatever port it is plugged into is enabled.
8. Return to “Onboard Devices” menu
9. Locate the SATA1/SATA2 – SATA3/SATA4 and enable the option that corresponds with your drive.
10. From here we will exit/save
11. Upon posting you will now see the NVIDIA Raid Bios and press F10 to enter.
12. Here you will see your new drive located on the left side of the 2 panels “Free Disks” and “Array Disks”.
13. Simply hit the right arrow key and the drive will shoot over from the left to the right side.
14. Make sure the “RAID Mode” is Stripping and Striping Block at 64k or Optimal. Hit F7 (Finish)
15. You will now see an “Array List”; as long as the drive is listed as healthy we are good.
16. CTRL-X to Exit. The computer should reboot.
17. We need to go directly into the bios right after the system posts.
18. Go into “ Advanced BIOS Features”
*NOTE*
When you have a serial hard drive hooked up to this motherboard ahd have arrived at this point you will be able to go into “Hard Disk Boot Priority”. Please go in here and you will see NVIDIA Stripe here. Please make sure this is the top #1 option with your page up/down to select this.
19. You will want first boot device to be CD-ROM for Windows XP/2k installs.
20. You will want the second boot device to read HARD DRIVE; this corresponds to the “Hard Disk Boot Priority List”.
21. Save/Exit
22. As most of you know when you enter the Setup for Win2k/WinXP you will need to hit F6 to load additional drivers for other SCSI devices.
23. When you arrive at the “Press S” menu please make sure you load BOTH of the NVIDIA SCSI/Storage drivers.
This means you will load "NVIDIA RAID CLASS DRIVE" hit <Enter> then hit S again and select "Nvidia Nforce Storrage Controller" hit <Enter>
You must do this step or windows has no idea what you want it to search for in regards to possible storage space.
From here you should be able to complete the install of Windows XP/2K fine. You can go into the bios and make “hard drive” first boot if you wish now.
Zoals MSI dat zelf heeft aangegeven.
Maar op het moment dat de setup klaar is met het laden van de drivers, gaat het beeld zwart en daar blijft hij haken. Als ik bij het selecteren van de drivers alleen de NVIDIA RAID Classic drivers installeer gaat de setup wel door na het laden, ik kan ook harde schijf formateren (aangezien ik die storage controller niet heb geinstalleerd zie ik echter wel 2 schijven). Als ik dat gedaan heb restart de pc om vervolgens de setup te beginnen. Dit geberut niet, omdat hij bij het verifiëren van de DMI POOL DATA een schrijfleesfout geeft, waardoor ik weer moet restarten. Ik kan dus op geen enkele manier gebruik maken van S-ata RAID. Als ik namelijk geen raid gebruik loopt alles perfect...
Ik hoop dat jullie ideeën hebben. Alvast bedankt
_/-\o_
  • BalusC
BalusC
Carpe diem
I/O controller issue: Processors, Mobo's & Geheugen > Opslagmedia & I/O Controllers
Overigens: ervaringentopics zijn in de eerste instantie bedoeld om ervaringen uit te wisselen en niet om problemen erin te posten ;)
  • Jilvoos
Ja stom, sorry en bedankt :D
  • KILLorBE
  • Laatst online: 28-06-2024
Werkt het wel (RAID dus) als je port 1+2 gebruikt?
Misschien kun je de boel dan eerst installeren op port 1+2 en ze daarna aan port 3+4 hangen?
  • Jilvoos
Hahaha dat ik daar zelf niet aan heb gedacht, het werkt namelijk perfect. Nu ff de boel weer aansluiten op 3 en 4 en overklokken maar...
Heej hartstikke bedankt _/-\o_
