Wireless en ndiswrapper lukt niet
  • MandaloR
  • Laatst online: 07-05-2024
Ik ben nu al een aantal dagen bezig met het installeren van mijn asus wl-100g kaartje op mijn alpha 2780 laptop. Na wat gekloot was ´t me eindelijk gelukt om de pcmcia-cs te starten en draaien. Drivers (Win2K 3.60.7.0) via ndiswrapper geinstalleerd, zonder problemen.
Installed ndis drivers:
bcmwl5  driver present, hardware present
Daarna
nautilus:/home/mandalor/downloads# modprobe ndiswrapper
FATAL: Module ndiswrapper not found.
Geen module dus. Source uitgepakt en proberen te compilen met de volgende error |:(
29
30
31
nautilus:/home/mandalor/downloads/tmp/ndiswrapper# make
make -C driver
make[1]: Entering directory `/home/mandalor/downloads/tmp/ndiswrapper/driver'
make -C /lib/modules/2.6.10/build SUBDIRS=/home/mandalor/downloads/tmp/ndiswrapper/driver \
        NDISWRAPPER_VERSION=1.1rc1 \
        EXTRA_VERSION=@050220 modules
make[2]: Entering directory `/usr/src/linux-2.6.10'
  CC [M]  /home/mandalor/downloads/tmp/ndiswrapper/driver/hal.o
  CC [M]  /home/mandalor/downloads/tmp/ndiswrapper/driver/iw_ndis.o
  CC [M]  /home/mandalor/downloads/tmp/ndiswrapper/driver/loader.o
  CC [M]  /home/mandalor/downloads/tmp/ndiswrapper/driver/misc_funcs.o
  CC [M]  /home/mandalor/downloads/tmp/ndiswrapper/driver/ndis.o
  CC [M]  /home/mandalor/downloads/tmp/ndiswrapper/driver/ntoskernel.o
  CC [M]  /home/mandalor/downloads/tmp/ndiswrapper/driver/pe_linker.o
  CC [M]  /home/mandalor/downloads/tmp/ndiswrapper/driver/proc.o
  CC [M]  /home/mandalor/downloads/tmp/ndiswrapper/driver/wrapper.o
  CC [M]  /home/mandalor/downloads/tmp/ndiswrapper/driver/usb.o
  CC [M]  /home/mandalor/downloads/tmp/ndiswrapper/driver/divdi3.o
  LD [M]  /home/mandalor/downloads/tmp/ndiswrapper/driver/ndiswrapper.o
  Building modules, stage 2.
  MODPOST
*** Warning: "wireless_send_event" [/home/mandalor/downloads/tmp/ndiswrapper/driver/ndiswrapper.ko] undefined!
  CC      /home/mandalor/downloads/tmp/ndiswrapper/driver/ndiswrapper.mod.o
  LD [M]  /home/mandalor/downloads/tmp/ndiswrapper/driver/ndiswrapper.ko
make[2]: Leaving directory `/usr/src/linux-2.6.10'
make[1]: Leaving directory `/home/mandalor/downloads/tmp/ndiswrapper/driver'
make -C utils
make[1]: Entering directory `/home/mandalor/downloads/tmp/ndiswrapper/utils'
cc -Wall -g -DNDISWRAPPER_VERSION=\"1.1rc1\"    -c -o loadndisdriver.o loadndisdriver.c
gcc -o loadndisdriver loadndisdriver.o
make[1]: Leaving directory `/home/mandalor/downloads/tmp/ndiswrapper/utils'
En hier is waar ik niet meer verder kom. Na menig google zoek werk, gooi ik mijn hoop bij 1 van jullie linux guru´s. In de hoop dat iemand mij kan helpen. Dit is namelijk ´t enigste wat mij en wifi onder linux nog tegen houdt :(
Ik draai debian unstable
kernel 2.6.10
(nog meer info nodig, meld ´t ff...)
jB
  • tweakerbee
  • Laatst online: 01-11 20:18
tweakerbee
dus..?
Wellicht dat het strak volgen van deze howto helpt?
http://www.madwifi.net/In...apper/ndiswrapper-0.7.txt
weet zelf amper wat van linux, afgezien van het feit dat rtfh (read the fine howto) vaak een must is.
[ Voor 31% gewijzigd door tweakerbee op 20-02-2005 17:05 ]
You can't have everything. Where would you put it?
  • smokalot
  • Laatst online: 15-01 22:00
smokalot
titel onder
heb je ook make install gedaan? kun je in /lib/modules/2.6.10/drivers/ de module vinden? insmod [bestand.ko] werkt wel? eerst depmod uitgevoerd (of opnieuw opgestart, dan doet ie dat ook)?
It sounds like it could be either bad hardware or software
  • MandaloR
smokalot schreef op zondag 20 februari 2005 @ 18:18:
make install had ik al gedaan
nautilus:/home/mandalor/downloads/tmp/ndiswrapper-1.0# make install
make -C driver install
make[1]: Entering directory `/home/mandalor/downloads/tmp/ndiswrapper-1.0/driver'
make -C /lib/modules/2.6.10/build SUBDIRS=/home/mandalor/downloads/tmp/ndiswrapper-1.0/driver \
        NDISWRAPPER_VERSION=1.0 \
        EXTRA_VERSION= modules
  MODPOST
*** Warning: "wireless_send_event" [/home/mandalor/downloads/tmp/ndiswrapper-1.0/driver/ndiswrapper.ko] undefined!
mkdir -p /lib/modules/2.6.10/misc
install -m 0644 ndiswrapper.ko /lib/modules/2.6.10/misc
/sbin/depmod -a
make[1]: Leaving directory `/home/mandalor/downloads/tmp/ndiswrapper-1.0/driver'
make -C utils install
make[1]: Entering directory `/home/mandalor/downloads/tmp/ndiswrapper-1.0/utils'
install -D -m 755 loadndisdriver /sbin/loadndisdriver
install -D -m 755 ndiswrapper /usr/sbin/ndiswrapper
install -D -m 755 ndiswrapper-buginfo /usr/sbin/ndiswrapper-buginfo
NOTE: Windows driver configuration file format has changed since 1.0-rc2. You must re-install Windows drivers if they were installed before.
make[1]: Leaving directory `/home/mandalor/downloads/tmp/ndiswrapper-1.0/utils'
mkdir -p -m 0755 /usr/share/man/man8
install -m 644 ndiswrapper.8 /usr/share/man/man8
daar geeft ie ook weer die error aan!!
in /lib/modules/2.6.10/misc vindt ik nu wel "ndiswrapper.ko". depmod uitgevoerd en daarna modprobe
nautilus:/home/mandalor/downloads/tmp/ndiswrapper-1.0# modprobe ndiswrapper
FATAL: Error inserting ndiswrapper (/lib/modules/2.6.10/misc/ndiswrapper.ko): Unknown symbol in module, or unknown parameter (see dmesg)
dmesg geeft ´t volgende weer:
ndiswrapper: Unknown symbol wireless_send_event
jB
  • MandaloR
MandaloR321 schreef op zondag 20 februari 2005 @ 19:33:
ok lui, via die laatst gegeven error heb ik nog eens zitten googlen en kwam op de volgende link uit http://ndiswrapper.sourceforge.net/phpwiki/index.php/FAQ...stom stom stom |:( dat ik daar niet eerder gekeken had :X
* If you get the compilation error "Unknown symbol: wireless_send_event" you will need to enable the CONFIG_NET_RADIO option and recompile your kernel
dit gedaan, even ndiswrapper hercompiled met de nieuwe kernel en et voila...een werkende wifi verbinding :D
(aan de moderators: dit topic kan wat mij betreft gesloten worden)
jB
