[2k3] 2e dc wil niet repl met 1e dc qua frs
  • Duinkonijn
  • Laatst online: 14:06
Hoi ik heb van de week een 2e dc toe gevoegd aan me domein.
ik heb nu problemen dat de 2e dc geen sysvol /netlogon krijgt
dcdiag op dc1 geeft geen problemen
dcdiag op dc2 wel
Starting test: Advertising
Warning: DsGetDcName returned information for \\srv-root02.dom.loca
l, when we were trying to reach SRV-BACH01.
Server is not responding or is not considered suitable.
......................... SRV-BACH01 failed test Advertising
Starting test: KnowsOfRoleHolders
Starting test: frsevent
There are warning or error events within the last 24 hours after the
SYSVOL has been shared. Failing SYSVOL replication problems may cause
Group Policy problems.
......................... SRV-BACH01 failed test frsevent
via [rml][ Windows 2003] Data replicatie[/rml]
sonar ben ik er achter dat dc2 wel gewoon werkt alleen dat dc1 errors heeft
via http://www.microsoft.com/...f/en-us/sonar_remarks.asp
heb ik linkd uitgeprobeerd
Linkd c:\windows\sysvol\sysvol\dom.local c:\windows\sysvol\domain
dit werkt zonder problemen op dc2
maar wil niet op dc1
op frs log heb ik nu wel een error:
event id 13568
The File Replication Service has detected that the replica set "DOMAIN SYSTEM VOLUME (SYSVOL SHARE)" is in JRNL_WRAP_ERROR.
Replica set name is : "DOMAIN SYSTEM VOLUME (SYSVOL SHARE)"
Replica root path is : "c:\windows\sysvol\domain"
Replica root volume is : "\\.\C:"
A Replica set hits JRNL_WRAP_ERROR when the record that it is trying to read from the NTFS USN journal is not found. This can occur because of one of the following reasons.
[1] Volume "\\.\C:" has been formatted.
[2] The NTFS USN journal on volume "\\.\C:" has been deleted.
[3] The NTFS USN journal on volume "\\.\C:" has been truncated. Chkdsk can truncate the journal if it finds corrupt entries at the end of the journal.
[4] File Replication Service was not running on this computer for a long time.
[5] File Replication Service could not keep up with the rate of Disk IO activity on "\\.\C:".
Setting the "Enable Journal Wrap Automatic Restore" registry parameter to 1 will cause the following recovery steps to be taken to automatically recover from this error state.
[1] At the first poll, which will occur in 5 minutes, this computer will be deleted from the replica set. If you do not want to wait 5 minutes, then run "net stop ntfrs" followed by "net start ntfrs" to restart the File Replication Service.
[2] At the poll following the deletion this computer will be re-added to the replica set. The re-addition will trigger a full tree sync for the replica set.
WARNING: During the recovery process data in the replica tree may be unavailable. You should reset the registry parameter described above to 0 to prevent automatic recovery from making the data unexpectedly unavailable if this error condition occurs again.
To change this registry parameter, run regedit.
Click on Start, Run and type regedit.
Expand HKEY_LOCAL_MACHINE.
Click down the key path:
"System\CurrentControlSet\Services\NtFrs\Parameters"
Double click on the value name
and update the value.
If the value name is not present you may add it with the New->DWORD Value function under the Edit Menu item. Type the value name exactly as shown above.
For more information, see Help and Support Center at
de vraag is nu.. hoe krijg ik hem zo ver dat hij sysvol / netlogon gaat aan bieden
opgelost.
linkd wilde niet omdat er al een directory bestond met die naam
restart frs @dc1 & dc2
@dc1 dword value toegevoegd in reg. : Enable Journal Wrap Automatic Restore
waarde 1
dcdiag /fix @ dc2
w000t :D B)
[ Voor 10% gewijzigd door Duinkonijn op 20-02-2005 18:04 ]
Het is makkelijk om iemand zijn negatieve eigenschappen te benoemen, maar kan je ook de positieve eigenschappen benoemen?
