[debian] Syslogd spuugt schijf vol met usb cardreader logs
  • VROEM!
  • Laatst online: 18-05-2025
VROEM!
broembroem!
Ik heb een usb cardreader geinstalleerd en sinds ik dat apparaat heb worden de logs zo snel aangevuld dat syslogd 3% CPU continue vreet (op een dual PIII 1GHz) 8)7.
Zodra ik mijn systeem een paar uur aan heb bevriest X en is de schijf vol met ongeveer 2GB aan logs.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
usb-storage: *** thread sleeping.
usb-storage: queuecommand called
usb-storage: *** thread awakened.
usb-storage: Command TEST_UNIT_READY (6 bytes)
usb-storage:  00 60 00 00 00 00
usb-storage: Bulk Command S 0x43425355 T 0x2254 L 0 F 0 Trg 0 LUN 3 CL 6
usb-storage: usb_stor_bulk_transfer_buf: xfer 31 bytes
usb-storage: Status code 0; transferred 31/31
usb-storage: -- transfer complete
usb-storage: Bulk command transfer result=0
usb-storage: Attempting to get CSW...
usb-storage: usb_stor_bulk_transfer_buf: xfer 13 bytes
usb-storage: Status code 0; transferred 13/13
usb-storage: Bulk status result = 0
usb-storage: Bulk Status S 0x53425355 T 0x2254 R 0 Stat 0x1
usb-storage: -- transport indicates command failure
usb-storage: Issuing auto-REQUEST_SENSE
usb-storage: Bulk Command S 0x43425355 T 0x80002254 L 18 F 128 Trg 0 LUN 3 CL 6
usb-storage: usb_stor_bulk_transfer_buf: xfer 18 bytes
evbug.c: Event. Dev: isa0060/serio0/input0, Type: 4, Code: 4, Value: 20
evbug.c: Event. Dev: isa0060/serio0/input0, Type: 1, Code: 20, Value: 0
evbug.c: Event. Dev: isa0060/serio0/input0, Type: 0, Code: 0, Value: 0
usb-storage: Status code 0; transferred 18/18
usb-storage: Bulk data transfer result 0x0
usb-storage: Bulk Status S 0x53425355 T 0x80002254 R 0 Stat 0x0
usb-storage: -- Result from auto-sense is 0
usb-storage: -- code: 0x70, key: 0x2, ASC: 0x3a, ASCQ: 0x0
usb-storage: Not Ready: Medium not present
usb-storage: scsi cmd done, result=0x2
evbug.c: Event. Dev: isa0060/serio0/input0, Type: 4, Code: 4, Value: 28
evbug.c: Event. Dev: isa0060/serio0/input0, Type: 1, Code: 28, Value: 1
Heeft iemand enig idee waarom dit met zo'n frequentie gedaan moet worden? Het gebeurt echt honderden keren per seconde.
Oh voor ik het vergeet: Er zit geen stick in de reader.
ieeeepppppp :P
  • Osiris
Waarschijnlijk heb je ergens in je kernel extra debug info bij USB aangezet.. Ff je kernel opnieuw compilen zonder die debug-meuk lijkt me :)
  • VROEM!
VROEM!
broembroem!
Stond inderdaad aan. Had ik zelf moeten kunnen bedenken.
Maar dat je nu pagina's vol berichten van een enkele seconde krijgt is ook weer een beetje overkill lijkt me |:(
Update: Met nieuwe kernel zonder usb debug is het toch nog hetzelfde. Meer suggesties zijn dus welkom, ik puzzel ondertussen de config nog eens extra door :)
Nou, het enige dat aan extra debug uit bleek te staan was iets generieks in de kernel. Voor de rest stond het overal aan. In wat voor bui ik dat gedaan heb 8)7. Ik denk trouwens dat uiteindelijk iets met scsi de veroorzaker is, aangezien scsi emulatie gebruikt wordt voor die usb opslag apparaten B)
Zo maar weer even rebooten... kijken wat de nieuwe brengt.
[ Voor 69% gewijzigd door VROEM! op 17-02-2005 23:05 ]
ieeeepppppp :P
  • VROEM!
VROEM!
broembroem!
Kleine update: Dit loste het probleem niet op, het blijkt dat er binnen usb ook nog verbose debug aan stond bij usb-storage. Mogelijk was dit het probleem, straks meer....
Dit was idd het probleem B)
[ Voor 8% gewijzigd door VROEM! op 18-02-2005 09:35 ]
ieeeepppppp :P
