[Ervaringen] Pioneer HDD & DVD Recorder DVR-920H-S
  • 387 views sinds 30-01-2008
Heeft iemand al ervaringen met de DVR-920H-S van Pioneer?
Afbeeldingslocatie: http://www.pioneer.nl/images/products/dvdrecorder/pioneer/1100696205992dvr920_detailpage.jpg
Backpanel
Het lijkt me een geweldig produkt maar volgens mij zeer duur, ik las ongeveer 2000 Euro op sommige sites.
Wat info:
Key Features DVR-920H-S
Mega-capacity 250 GB Hard Disk Drive
Up to 55x High-Speed Copy from HDD to DVD
EPG (Guide Plus+)
HDMI, Full Digital connection
Full digital 10-bit precision signal processing
High-quality design in black acrylic
Playback DVR-920H-S
Media DVD-Video/DVD-R/DVD-RW/CD/SVCD/VCD/CD-R/CD-RW
MP3 Yes
WMA Yes
JPEG Photo Viewer Yes
Advanced Disc Navigator (DiscNavi) (VR mode/Video mode) Yes/Yes
Seamless Playback (VR/Video mode) Yes/No
Commercial Skip / Back Yes/Yes
Chase Playback, Playback with Recording (VR mode/Video mode) Yes/No
1.5x view (scan1) Yes
Recording DVR-920H-S
Media (VR/Video mode) DVD-RW / DVD-R, DVD-RW
PAL/NTSC Yes/Yes
Max. Recording Time FINE: +/- 1 hour
SP: +/- 2 hours
LP: +/- 4 hours
EP: +/- 6 hours
SLP: +/- 8 hours
MN: +/- 1-6 hours
32 steps
Variable Bit Rate Recording Yes
Easy Timer Yes
ShowView Yes
VPS/PDC Yes/Yes
Auto Start Recording Yes
One Touch Recording Yes
Direct TV Recording Yes
Number of events 32/month
Linear PCM Recording (Audio) Yes (FINE, MN32)
Editing DVR-920H-S
HDD Input Title Name, Easy Title Input, Erase Title, Erase Chapter, Erase section, Accuracy: Frame, Chapter Mark
VR Mode Input Disc name, Input Title Name, Easy Title Input, Erase Title, Erase Chapter, Erase section, Playlist, Accuracy: Frame, Chapter Mark, Undo
Video Mode Input Disc name, Input Title Name, Wall Paper Samples (Title menu) (Finalization), Easy Title Input, Erase Title, Accuracy: Title, Chapter Mark: 10 min/15min/No seperation, Undo
Picture Quality DVR-920H-S
Digital Noise Reduction Component Frame DNR PRO
5-Line Comb Filter Y/C Separation Yes
Pure Cinema Progressive Scan (for PAL) Yes
Video DAC 14-bit/108 MHz
Digital Timebase Corrector Yes
Picture Creation Yes
HDD Functions DVR-920H-S
Group Yes
Maximum number of titles 999
One Touch Copy Yes (HDD to DVD, DVD to HDD)
High Speed Copy Yes (HDD to DVD, DVD to HDD)
Rate Conversion Copy Yes (HDD to DVD, DVD to HDD)
Optimized Copy Yes (HDD to DVD)
Disc Backup Yes
Auto Replace Recording Yes
Resume (by Title) Yes
Recovery Recording Yes
Advanced Disc Navigator (DiscNavi) Playback Yes
Seamless Playback Yes
Chase Playback, Playback with Recording Yes
Hard Disk Drive 250 GB
Recording Mode: Max. Recording Time FINE: +/- 54 hour
SP: +/- 108 hours
LP: +/- 216 hours
EP: +/- 324 hours
SLP: +/- 433 hours MN: +/- 54-433 hours
32 steps
Max recording
time per title: 420 min
Convenience DVR-920H-S
Disc History Yes
Auto Clock set up Yes
Set up Navigator Yes
Channel preset download Yes
Tuner DVR-920H-S
System PAL-B/G, I, D/K
SECAM-L/L', B/G, D/K
Connections Terminals DVR-920H-S
Input 1 SCART (AV connector 2)
RGB Input via Euro-SCART
1 RCA (Audio/Video): 2 (1 in front, 1 in rear)
1 S-Video: 2 (1 in front, 1 in rear)
Output 1 SCART (AV connector 1)
RGB Output via Euro-SCART
HDMI Video Output
1 RCA (Audio/Video)
1 S-Video
Digital Audio (Optical/Coaxial)
G-LINK (STB Control)
DV Terminal (IEEE1394) IN/OUT
System Remote Control Terminal IN
Miscellaneous DVR-920H-S
Dimensions (W x H x D) 420 x 87 x 357 mm
Weight 7.9 kg
Power requirements AC 220 - 240 V, 50/60 Hz
Power consumption 62 Watt
Power consumption in standby mode 0.7 Watt
Remote Control Yes
  • Bart
  • Laatst online: 07-10 13:49
Mooi ding ja met grote capaciteit. Alleen die prijs... :(
I'm not deaf, I'm just ignoring you.
  • Grrrrrene
Mjah, maar kijk 's wat een gemiddelde DVD speler kost met _zulke_ goede beeld en geluidskwaliteit? Dit is gewoon een DVD recorder waar niet alleen een grote HD in zit en veel opname/editing functies op zitten, maar waar ook over de pure beeldkwaliteit nagedacht is :)
Tsja, ik kan verder weinig melden over dit apparaat, behalve dat ikzelf een Pioneer DVD/HD recorder heb en hij heel goed bevalt :)
Ik ben van plan er een te kopen maar heb nog een paar kleine vraagjes:
  • Ik heb wel eens gehoord dat als je opneemt via 'showview' of wellicht via EPG je het apparaat daarna in standby moet zetten, daar ie anders niet kan beginnen. Is dat omdat er maar één zo'n kabelingang is?
  • Jammer dat hij alleen DVD-R speelt en niet ook DVD+R, dat ligt zeker aan het feit dat Pioneer medeontwikkelaar is/was van die standaard?
  • Weet iemand of er nog andere HDD DVD spelers van Pioneer op de markt gaan komen met kleinere harddisken? Het is wel lekker dat die zo groot is, maar die prijs is gewoon te duur.
Ik zit er nu net aan te denken dat ik de meeste DVDs gebackupped heb op DVD+R. Daar gaat hij al :( of ik moet eerst alles terug branden op -R
[ Voor 4% gewijzigd door Verwijderd op 14-02-2005 08:59 ]
Verwijderd schreef op maandag 14 februari 2005 @ 08:58:
Pioneer ondersteund niet officieel de + standaard, maar als je het gaat proberen pakken alle pioneer speler/recorders van de laatste 2 jaar zeker 95% van de + schijfjes. Heb zelf de afgelopen jaren diverse dvd-spelers in bezit gehad of geprobeerd van pioneer en mijn ervaring is dat ze al mijn +r schijfjes ondersteuning. Misschien dat de spelers niet ieder merk slikken, maar Pioneer zet het express niet neer dat ze het lezen vanwege het feit dat ze het niet 100% garanderen.
Dat is goed om te lezen. Ik ken nog iemand die een Pioneer onlangs gekocht heeft. Ga het meteen eens vragen.
De Pioneer DVR-433H, Pioneer DVR-530H, Pioneer DVR-630H... De goedkoopste begint bij 400 euro en heeft 80 GB (de DVR-433 dus)
Volgens de specs speelt de pioneer wel alle plus en min smaken, maar het branden (volgens de specs) is inderdaad alleen op min varianten.
