[SAMBA] XP-Client kan niet lid worden van domein
  • 54 views sinds 30-01-2008
Ik heb een server opgezet met RH9 en samba 2.(7 dacht ik)
dit is mijn smb.conf
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
[global]
    workgroup = SAMBASERVER
    server string = Samba Server
    encrypt passwords = Yes
    map to guest = Bad User
    passwd program = /usr/bin/passwd %u
    passwd chat = *New*UNIX*password* %n\n *Retype*new*UNIX*password* %
    passwd chat debug = Yes
    time server = Yes
    unix extensions = Yes
    socket options = SO_KEEPALIVE IPTOS_LOWDELAY TCP_NODELAY
    printcap name = CUPS
    add user script = /usr/sbin/useradd -c machine -d /dev/null -s /bin/false  %m$
    logon script = logon.bat
    logon path = \\%L\profiles\%U
    logon drive = h:
    domain logons = Yes
    os level = 65
    preferred master = Yes
    domain master = Yes
    wins support = Yes
    printing = cups
    veto files = /*.eml/*.nws/riched20.dll/*.{*}/
    hide files = /desktop.ini/
[homes]
    comment = Home Directories
    path = /home/%U/Documents
    valid users = %S
    read only = No
    create mask = 0755
    browseable = No
[netlogon]
    comment = login service
    path = /var/data/netlogon
    write list = root
    create mask = 0644
[profiles]
    comment = roaming profiles directory
    path = /var/data/profiles
    read only = No
    create mask = 0600
    force create mode = 0600
    directory mask = 0777
    force directory mode = 0777
[open]
    comment = hier de map open
    path = /var/data/open
    read only = No
    create mask = 0600
[printers]
    comment = All Printers
    path = /var/tmp
    create mask = 0600
    printable = Yes
    browseable = No
[print$]
    comment = Printer Drivers
    path = /var/lib/samba/drivers
    write list = @ntadmin root
    force group = ntadmin
    create mask = 0664
    directory mask = 0775
als ik de xp client lid wil maken van het domein dan krijg ik deze melding: "Er kan geen verbinding worden gemaakt met een domeincontroller in het domein SAMBASERVER"
ik doe dit in: (rechtermuisknop)Deze computer>(tabblad)Computernaam>Netwerk ID
maar ik ben niet zeker wat ik hier moet invullen, ik moet deze 3 dingen invullen:
-Gebruikersnaam
-Wachtwoord
-Domein
ik kies dan voor:
-Root
-***password***
-Sambaserver
Ik heb root als sambagebruiker toegevoegd. ik krijg de melding ook als ik met een andere gebruikersnaam inlog.
Het ip van de server is 10.0.0.129
als ik \\10.0.0.129 doe dan kom ik gewoon in de share mappen. maar als ik \\sambaserver doe dan niet.
ik denk dat dit wel duidelijk is om te zien of ik ergens iets fout heb gedaan
  • Dennis
  • Laatst online: 07:24
Heb je je client ook als computer-account toegevoegd aan Samba?
Bij computernaam heb ik als omschrijving "testuspc" deze gebruiker bestaat in samba.
Ik log met windows in als "administrator", moet ik dan de user "administrator" toevoegen aan samba?
[ Voor 16% gewijzigd door Verwijderd op 09-02-2005 15:51 ]
ik heb net dit gedaan:
/usr/sbin/useradd -g 100 -d /dev/null -c testuspc -s /bin/false testuspc
en
passwd -l testuspc
was dat de bedoeling? ik kan nu nog steeds niet lid worden, moet ik deze machine soms koppelen aan een user
*edit* ik heb de registry hack ook al gedaan "signorseal=0"
[ Voor 12% gewijzigd door Verwijderd op 09-02-2005 16:07 ]
  • Dennis
Je moet "useradd -c" gebruiken als je computers aan een samba-domein wilt toevoegen. Heb je dat gedaan? :)
  • Bas!
  • Laatst online: 26-07 22:06
(jarig!)
Computer accounts voegt samba automatisch toe as je je aanmeldt via netwerkid en je doet dit met root (of iets gelijkwaardigs)
Hoe heet je server eigenlijk. Ik vind je domeinnaam namelijk vreemd.
Samba pakt standaard je hostname als je geen computernaam opgeeft
[ Voor 36% gewijzigd door Bas! op 09-02-2005 18:27 ]
Uhhh ik had laatst hetzelfde probleem. Ik moest met aanmelden even de windows firewall uitzetten. Vervolgens aanmelden op domein en....tadaa (werkte bij mij in ieder geval)
mijn server heet "fabian-linux-testbak"
het domein heb ik zelf sambaserver genoemd
mijn client heet "testuspc"
  • Zwerver
Sorry hoor, maar als je even een search doet krijg je zo ontzettend veel howto's over samba+windows xp, als je die nou eens doorneemt... Want het ziet er duidelijk naar uit dat je bepaalde basisdingen gewoon niet gedaan hebt.
Woonachtig Down Under. Ik negeer je insults niet, maar tegen de tijd dat ik ze lees zijn ze meestal niet relevant meer
