NOD32 Trial wil niet updaten...
  • 37 views sinds 30-01-2008
  • FlowDesign
  • Laatst online: 13:59
Ik heb Nod32 2.12.3 Trial-versie draaien maar sinds een paar dagen lukt het niet meer om te updaten. Zie Event-log:
Time    Module  Event   User
8-2-2005 21:55:48   Update  Update attempt failed (Server connection failure)   FLOW\Floris
8-2-2005 21:53:50   Update  Update attempt failed (Server connection failure)   FLOW\Floris
8-2-2005 21:52:27   Update  Update attempt failed (Server connection failure)
8-2-2005 21:40:08   Update  Update attempt failed (Server connection failure)
8-2-2005 21:36:21   Update  Update attempt failed (Server connection failure)   FLOW\Floris
8-2-2005 21:35:23   Update  Update attempt failed (Server connection failure)   FLOW\Floris
8-2-2005 20:45:09   Update  Update attempt failed (Server connection failure)
8-2-2005 19:44:25   Update  Update attempt failed (Server connection failure)
8-2-2005 18:42:37   Update  Update attempt failed (Server connection failure)   FLOW\Floris
8-2-2005 18:41:26   Update  Update attempt failed (Server connection failure)   FLOW\Floris
8-2-2005 18:39:24   Update  Update attempt failed (Server connection failure)
8-2-2005 17:38:48   Update  Update attempt failed (Server connection failure)
8-2-2005 4:28:00    Update  Update attempt failed (Server connection failure)
8-2-2005 3:33:00    Update  Update attempt failed (Server connection failure)
8-2-2005 2:32:54    Update  Update attempt failed (Server connection failure)
8-2-2005 1:32:19    Update  Update attempt failed (Server connection failure)
8-2-2005 0:32:11    Update  Update attempt failed (Server connection failure)
7-2-2005 23:31:46   Update  Update attempt failed (Server connection failure)
7-2-2005 22:28:19   Update  Update attempt failed (Server connection failure)
3-2-2005 17:30:56   Update  Function: gethostbyname, parameters: , return value: 11001
3-2-2005 17:30:56   Update  Update attempt failed (Server connection failure.)
2-2-2005 21:47:31   Kernel  The virus signature database has been updated successfully to version 1.990 (20050202).
Ik heb al wat instellingen lopen veranderen bij de Update settings, maar dat baat niet.
Ook een keer opnieuw installeren van het programma heeft geen invloed: kan nog steeds niet updaten.
Zijn er nog meer mensen die dit probleem ondervinden?
Mustang Mach-E SR RWD | MINI Countryman (F60) Cooper S (Stage 1 tuned)
  • FlowDesign
Hmmmz... vreemd.
Ik heb versie 2.12.4 geïnstalleerd en nu update ie wel.
Vaag vermoeden dat het aan hun server lag.
  • Spider.007
Spider.007
* Tetragrammaton
De error lijkt me ook vrij duidelijk ;)
Als er zoiets staat moet je er gewoon altijd vanuit gaan dat het probleem niet bij jou ligt ;) Maargoed; opgelost dus :)
Prozium - The great nepenthe. Opiate of our masses. Glue of our great society. Salve and salvation, it has delivered us from pathos, from sorrow, the deepest chasms of melancholy and hate
