Spec`s van switch goed of slecht
  • knutsel smurf
  • Laatst online: 07-09 17:47
knutsel smurf
Grote Smurf zijn we er bijna ?
mij oog is gevalle op deze switch met de onderstaande specs is dit nu een goede switch voor 1056,-
als er mensen zijn die een betere weten voor ongeveer de zelfde prijs mogen die zich ook melden !! (wel 24 poorts AUB)
The FD1620-24 is a powerful, high-performance Fast Ethernet Switching Hub, with all 24 ports having 10 or 100Mbps Auto-Negotiation Operation (NWay) capabilities; which means the switch can automatically negotiate with the connected partners on the network speed and duplex.
It is ideal for micro-segmenting large networks into smaller, connected subnets for improving the performance of bandwidth demanding multimedia and imaging applications. Moreover, its 10/100Mbps Auto-Sensing ability provides an easy way to migrate from 10Mbps to 100Mbps Networks effortlessly.
With port trunking and vLAN enhanced features, users can build up a 800Mbps fat pipe between switch and switch connection that will boost the backbone bandwidth and get rid of the network looping issue. The vLAN function can separate the network traffic into groups that provide more network security, while preventing broadcast packet impact to network performance. The switch supports rich diagnostic LEDs and two status buttons on the front-panel, which show the operating status and configuration of each, individual port and of the entire system. Additionally, the RS232 Console Port can be used to easily configure the Switch Status. "Plug and Play" is the most important design concept of this system, allowing users to just plug in the cable and turn on the power, with the system working under all types of network protocols.
Features
Complies with IEEE802.3 and IEEE802.3u Standards
Twenty-four Ports for 100Base-TX and 10Base-T Connectivity
Supports NWay Protocol for Speed (10/100Mbps) and Duplex-Mode (Half/Full) Detection
One Uplink Port, for Cascading Switch to Switch or Switch-to-Hub with no Crossover Cable
19" Standard Rack-Mount Design
Supports Full and Half-Duplex Operation on all Ports
Supports Port-Trunking and vLAN Function
Operates at Maximum Packet Filtering and Forwarding Rate
Store-and-Forward Architecture filters Fragment & CRC Error Packets
Supports 1K MAC Address Entries in Entire System
3-MBytes Buffer Memory
Supports extensive LED Indicators and Status Button for Network Diagnostics
Internal Universal Switching Power Supply (100-240VAC, 50/60Hz)
FCC Class A, CE
  • yGiDoRp
  • Laatst online: 19-08 18:37
yGiDoRp
Sawasdee
Tis wel erg goedkoop, maar de term Fast Ethernet Switching Hub maakt het geen switch. Wat is het merk en type dan?
en waarvoor ga je het gebruiken ?
ik keek nog ff naar de specs, en opzich is er nix mis mee
Stay far away from the TV and turn the lights on when watching this program. Mixcloud | Facebook | SHOT
  • knutsel smurf
knutsel smurf
merk en type weet ik niet
dit zijn in iedergeval de specs en verder weet ik dus niets maar die prijs van 1056 voor dat ding is IDD erg goedkoop dus daarom vraag ik het hier
Het is één of ander :7 russisch :7 ding van het merk (???) SVEC. Kijk maar eens op http://www.svec.ru/products/fd1620-24/index.shtml waar hij in volle glorie staat. De russische uitleg staat er gelijk bij. :P
  • TheRebell
  • Laatst online: 14-09 12:04
high-performance Fast Ethernet Switching Hub: zou je weer denken dat het n hub is maar dan kan ie nooit Full-duplex zijn.
Kortom: 't zou gewoon n switch moeten zijn.
Specs zien d'r goed uit.
(heb zelf n Schneider & Koch maar geen 24 poorts.... :'( )
  • knutsel smurf
knutsel smurf
maar eh leuk dat russisch maar ik kan het dus niet lezen IEMAND ???
is er ook niemand met andere tips ofzow ???
http://www.lanode.com/tier2/fd162024.htm
http://www.lanode.co.uk/FD162024.htm
JAWEL!!!!!!! *D*D*D*D*D*D*D*D*D
http://www.svecusa.com/products/network/switch/fd1620.htm
O heb jij ff geluk! Er bestaat ook een SVECUSA! Yes!!!! }:O
  • knutsel smurf
knutsel smurf
AH dit is wat duidelijker maar dan weet ik nog steeds niet of er een betere switch is voor ongeveer de zelfde prijs en of dit nu echt een goed ding is
Op zaterdag 06 januari 2001 23:07 schreef Knutsel_smurf het volgende:
Nee maar wellicht is er nu ergens een test op te snorren op internet. Net als dat ik de sites vond via een zoekopdracht op het typenummer...........
/me geeft maar een hint hoor (maar gaat niet alles voor je doen) [img=15,15]i/s/wink.gif[/img]
