Ik heb webmin geinstalleerd en nu wil ik virtualmin installeren. Ik wil gebruik maken van sendmail.
Virtualmin geeft deze foutmelding:
No address mapping (virtusers) file was found in your Sendmail configuration. Your may need to add the appropriate feature your Sendmail M4 and re-build the configuration.
Dus ik naar Sendmail M4 en dit geprobeerd:
divert(-1)dnl
# $Sendmail: debproto.mc,v 8.13.2 2004-12-16 01:32:38 cowboy Exp $
# Copyright (c) 1998-2004 Richard Nelson. All Rights Reserved.
# cf/debian/sendmail.mc. Generated from sendmail.mc.in by configure.
# sendmail.mc prototype config file for building Sendmail 8.13.2
# Note: the .in file supports 8.7.6 - 9.0.0, but the generated
# file is customized to the version noted above.
# This file is used to configure Sendmail for use with Debian systems.
# If you modify this file, you will have to regenerate /etc/mail/sendmail.cf
# by running this file through the m4 preprocessor via one of the following:
# * `sendmailconfig`
# * `make`
# * `m4 /etc/mail/sendmail.mc > /etc/mail/sendmail.cf`
# The first two options are preferred as they will also update other files
# that depend upon the contents of this file.
# The best documentation for this .mc file is:
# /usr/share/doc/sendmail-doc/cf.README.gz
divert(0)dnl
define(`_USE_ETC_MAIL_')dnl
include(`/usr/share/sendmail/cf/m4/cf.m4')dnl
VERSIONID(`$Id: sendmail.mc, v 8.13.2-1 2004-12-16 01:32:38 cowboy Exp $')
OSTYPE(`debian')dnl
DOMAIN(`debian-mta')dnl
dnl # Items controlled by /etc/mail/sendmail.conf - DO NOT TOUCH HERE
undefine(`confHOST_STATUS_DIRECTORY')dnl #DAEMON_HOSTSTATS=
dnl #
dnl # General defines
dnl #
dnl # SAFE_FILE_ENV: [undefined] If set, sendmail will do a chroot()
dnl # into this directory before writing files.
dnl # If *all* your user accounts are under /home then use that
dnl # instead - it will prevent any writes outside of /home !
dnl # define(`confSAFE_FILE_ENV', `')dnl
dnl #
dnl # Daemon options - restrict to servicing LOCALHOST ONLY !!!
FEATURE(`no_default_msa')dnl
dnl DAEMON_OPTIONS(`Family=inet6, Name=MTA-v6, Port=smtp, Addr=::1')dnl
DAEMON_OPTIONS(`Family=inet, Name=MTA-v4, Port=smtp, Addr=127.0.0.1')dnl
dnl DAEMON_OPTIONS(`Family=inet6, Name=MSP-v6, Port=submission, Addr=::1')dnl
DAEMON_OPTIONS(`Family=inet, Name=MSP-v4, Port=submission, Addr=127.0.0.1')dnl
dnl #
dnl # Be somewhat anal in what we allow
define(`confPRIVACY_FLAGS',dnl
`needmailhelo,needexpnhelo,needvrfyhelo,restrictqrun,restrictexpand,nobodyreturn,authwarnings')dnl
dnl #
dnl # Define connection throttling and window length
define(`confCONNECTION_RATE_THROTTLE', `15')dnl
define(`confCONNECTION_RATE_WINDOW_SIZE',`10m')dnl
dnl #
dnl # Features
dnl #
dnl # The access db is the basis for most of sendmail's checking
FEATURE(`access_db', , `skip')dnl
dnl #
dnl # The greet_pause feature stops some automail bots - but check the
dnl # provided access db for details on excluding localhosts...
FEATURE(`greet_pause', `1000')dnl 1 seconds
dnl #
dnl # Delay_checks allows sender<->recipient checking
FEATURE(`delay_checks', `friend', `n')dnl
dnl #
dnl # If we get too many bad recipients, slow things down...
define(`confBAD_RCPT_THROTTLE',`3')dnl
dnl #
dnl # Stop connections that overflow our concurrent and time connection rates
FEATURE(`conncontrol', `nodelay', `terminate')dnl
FEATURE(`ratecontrol', `nodelay', `terminate')dnl
dnl #
dnl # Default Mailer setup
MAILER_DEFINITIONS
MAILER(`local')dnl
MAILER(`smtp')dnl
dnl # Masquerading options
FEATURE(`always_add_domain')dnl
MASQUERADE_AS(`molenvliet.xs4all.nl')dnl
FEATURE(`allmasquerade')dnl
FEATURE(`masquerade_envelope')dnl
FEATURE(`virtusertable')dnl
Maar dan krijg ik bij rebuilden deze melding:
Failed to build configuration :
NONE:0: m4: ERROR: EOF in string
Wat kan ik hier aan doen om virtualmin werkend te krijgen?
divert(-1)dnl
# * `make`
divert(0)dnl
OSTYPE(`debian')dnl
dnl #
dnl #
dnl #
dnl #
dnl #
dnl #
dnl # Features
dnl #
dnl #
dnl #
dnl #
dnl #
dnl #
MAILER_DEFINITIONS
MAILER(`local')dnl
MAILER(`smtp')dnl
