[PHP] parse error in html code
  • 51 views sinds 30-01-2008
  • Tubbietje
  • Laatst online: 06-10 22:40
Beste tweakers,
het is vast een simpel probleem, maar ik kom er maar niet uit hoe ik de volgende htmlcode in php kan laten weergeven.
Hij geeft problemen met de blauwe tekst hieronder, door de ' denkt ie dat ie de code al moet afbreken denk, maar hoe kan ik nu oplossen dat ik niet de volgende foutmelding krijg op deze regel (72)?
Parse error: parse error, unexpected T_STRING, expecting ',' or ';' in /var/www/pcaid/head.php on line 72
PHP:
echo '<td>[img]"layout/pixel_blue.gif"[/img][img]"layout/pixel_white.gif"[/img]<a href="index.php" onMouseOut="MM_swapImgRestore()" onMouseOver="MM_swapImage('Home','','layout/menu_home2nd.gif',1)">[img]"layout/menu_home.gif"[/img]</a>[img]"layout/pixel_white.gif"[/img]<a href="phpBB2/index.php" target="_new" onMouseOver="MM_swapImage('Forum','','layout/menu_diensten2nd.gif',1)" onMouseOut="MM_swapImgRestore()">[img]"layout/menu_diensten.gif"[/img]</a>[img]"layout/pixel_white.gif"[/img]<a href="links.php" onMouseOut="MM_swapImgRestore()" onMouseOver="MM_swapImage('Links','','layout/menu_tarieven2nd.gif',1)">[img]"layout/menu_tarieven.gif"[/img]</a>[img]"layout/pixel_white.gif"[/img]<br><a href="tarieven.php" onMouseOut="MM_swapImgRestore()" onMouseOver="MM_swapImage('Tarieven','','layout/menu_contact2nd.gif',1)">[img]"layout/menu_contact.gif"[/img]</a>[img]"layout/pixel_white.gif"[/img]<a href="contact.php" onMouseOut="MM_swapImgRestore()" onMouseOver="MM_swapImage('Contact','','layout/menu_software2nd.gif',1)">[img]"layout/menu_software.gif"[/img]</a>[img]"layout/pixel_white.gif"[/img]<a href="#" onMouseOut="MM_swapImgRestore()" onMouseOver="MM_swapImage('Image17','','layout/menu_howto2nd.gif',1)">[img]"layout/menu_howto.gif"[/img]</a>[img]"layout/pixel_white.gif"[/img][img]"layout/pixel_blue.gif"[/img]</td>';
Thanx already :)
Intel Core i7 4770K + 8x LG 24EB23 | New iPad 16GB WiFi | Xiaomi Mi Mix 2 | Microsoft Surface Pro 3 i5 128GB
  • gorgi_19
  • Laatst online: 14:10
gorgi_19
Kruimeltjes zijn weer op :9
Je moet de single quotes in MM_swapImage iig gaan escapen :)
Digitaal onderwijsmateriaal, leermateriaal voor hbo
  • Tubbietje
gorgi_19 schreef op woensdag 02 februari 2005 @ 20:16:
Precies...daar was ik dus achter...alleen had ik dat wat moeilijker uitgelegd hierboven, maar hoe kan ik deze nu verwijderen zonder functionaliteit van mijn code te verliezen?
  • gorgi_19
gorgi_19
Tarod schreef op woensdag 02 februari 2005 @ 20:20:
Zie http://www.google.com/sea...q=Escape+PHP+single+quote, en dan de eerste link :) Dan kom je op http://www.codedemons.net...-Escape-and-Concatenation uit en staat het allemaal redelijk uitgelegd :)
Deze gaat iig dicht; je hebt de juiste zoekwoorden, de juiste foutmelding en de relevante code :) Met deze info moet je er verder zelf uit kunnen komen :)
[ Voor 13% gewijzigd door gorgi_19 op 02-02-2005 20:22 ]
