[Prob] Asus A8N-SLI + Raid0 + Win2000
  • kalizec
  • Laatst online: 25-08 18:47
Wellicht kan iemand me helpen met het onderstaande probleem.
De oplossing die Asus-handleiding aandracht werkt namelijk helaas niet.
Heb gisteren mijn Asus A8N-SLI binnengekregen samen met de rest van het spul.
Nu wil ik graag Windows2000 op een Raid0 installeren waarvan ook geboot moet worden.
Dit is volgens een van de meegeleverde handleidingen (CD) niet mogelijk met Windows2000 pre SP3.
Ze bieden de volgende oplossing aan:
NVIDIA Corporation 113
Use the NVRAIDMAN Tool
Use the NVRAID Tool (nForce Driver Version 5.xx) to convert the boot volume to a RAID array. The following are step by step instructions:
1 Install Windows 2000 on a selected hard drive.
2 Download and install Windows 2000 Service Pack 4 from Microsoft’s website.
3 Reboot the system
4 Press the DEL key as the system is rebooting to enter into the system BIOS.
5 Select Integrated Peripherals menu.
6 Select the RAID Config menu.
7 Enable RAID for the selected drive (the one containing the Windows 2000 operating system).
8 Press F10 to exit and save settings in the system BIOS. This action reboots the System.
9 Press F10 as the system is rebooting to go into the RAID ROM. The system directs you into the NVIDIA RAID Utility.
10 Select Striping under RAID Mode.
11 Press TAB to go into the Free Disk menu.
12 Use the Right Arrow key to add the desired disk.
13 Press F7 to finish.
14 Select N (NO) when asked to Clear Disk Data.
15 Press Ctrl-X to exit. The system reboots into Windows 2000.
16 Install the NVIDIA nForce Driver Package while in Windows 2000.
17 Reboot the system.
18 Go to START>Programs>Nvidia Corporation and select NVRAID Manager. You should see the single disk RAID array (in striping mode) that was created from the boot disk.
19 Select the single boot disk RAID Array by clicking on it.
20 Select Convert Array under the System Tasks. The Convert Array wizard is displayed.
21 Select Next.
22 Select the desired type of RAID array you want to convert.
23 Select Next. You are prompted to select the desired Free Disk(s) to add to the bootable RAID array.
24 Click Finish. At this point, NVRAID starts converting the single disk RAID array into a multi-disk RAID array in a bootable format. Note: Conversion may take 1–2 hours depending on disk size.
Nu heb ik dit geprobeerd en loop tegen het probleem aan dat na stap 15 aan het einde van POST er niet geboot wordt. Het systeem blijft dan gewoon stil en lijkt ergens op te wachten, echter heb ik geen flauw idee waarop. Er verschijnen geen meldingen oid.
Heb de bootinstellingen gecontroleerd en die staan gewoon ok. Hij ziet de enkele schijf ook gewoon als een Stripe array. Maar booten dus ho maar.
Zet ik de boel weer terug (haal ik die disk dus terug uit de Raidset), dan kan ik wel weer gewoon booten met de Win2000+SP4 install. Iemand ideeën?
Relevante Systeem specs
Asus A8N-SLI (originele bios, Asus heeft voor de non-deluxe versie nog geen nieuwe releases gedaan).
Winchester 3000+
2x512MB TwinMOS
Asus EN6600GT
2x IBM 30GB DTLA (Moeten Raid0 gaan draaien, dit hebben ze in mijn vorige systeem ook altijd gedaan).
Sil 0680 ATA133 controller voor meer PATA aansluitingen (DVD±RW, etc).
Core i5-3570K/ASRock Z75 Pro3/Gigabyte Radeon HD7850/Corsair XMS3 2x4GB/OCZ Vertex2 64GB/3x640GB WD Black/24" B2403WS Iiyama x2/Nec 7200S
Ik heb gisteren de nodige installatie-problemen gehad, en ik heb het zo opgelost (was wel wat anders, maar goed :P)
1) Maak via de RAID-setup (voor boot) de RAID-0 aan
2) Maak driver-diskettes aan voor nvraid en Silicon controller (via mainboard CD)
3) Boot met windows install-CD, druk op F6 om extra controllers toe te voegen
4) Voeg nvidia en silicon controllers toe
5) installeren maar...
[ Voor 4% gewijzigd door Verwijderd op 02-02-2005 17:33 ]
  • kalizec
Verwijderd schreef op woensdag 02 februari 2005 @ 17:32:
-Idem Maar dat kan ook niet anders.
Heb geen Deluxe, dus idem, maar geen Silicon.
Idem, echter loopt de boel hier vervolgens vast omdat Win2000 Setup vervolgens geen array ziet maar twee losse schijfen.
Welk OS + Schijven op welke controller heb jij gebruikt en is dat array ook waarvan je boot?
Voor de duidelijkheid, dit hele topic is dus omdat de oplossing die Asus / Nvidia aandracht voor het probleem met F6 + disks, ook niet werkt.
[ Voor 10% gewijzigd door kalizec op 02-02-2005 17:48 ]
  • kalizec
Owk, na een paar keer "heen en weer" installeren van de Nforce Drivers, werkt de door Nvidia gepresenteerde oplossing toch.
Ik denk dat het 'niet werken van de oplossing' lag aan de warrige manier waarop je die Nforce drivers allemaal kunt installeren.
Immers, als je ze al geinstalleerd hebt, en vervolgens de Raid-controller aanzet, moet je ze dus verwijderen en dan herinstalleren (Nforce). En dat is alles behalve duidelijk.
Hij is nu bezig met het converteren. Dus hopelijk boot ie zodadelijk nog en dan is het opgelost.
[edit]
Ok, dat converteren van 5GB duurt dus ruim 4 uur.
Weet dus waar je aan begint.
[ Voor 11% gewijzigd door kalizec op 02-02-2005 22:35 . Reden: Klaar met converten ]
  • kalizec
En na een paar uur soepeltjes draaien met een stuk of 4 reboots, werkt de boel niet meer. W2k komt nu weer met de standaardmelding van dat hij de raiddrivers niet meer kan openen.
Gevolg, partitie is weer unbootable.
Ben het nu zat, heb XP + SP2 slipstream geinstalleerd.
En ook die krijg ik niet stabiel geinstalleerd om te booten vanaf Raid0.
Na 4 afgebroken installatie pogingen maar opgegeven.
Mijn voorlopige conclusie. De raid-drivers zijn gaar.
WinXP + SP2 slipstream op WD800JB geïnstalleerd en de programma's op de Raid 0 gezet.
Mijn advies is in ieder geval om het gewoon niet te proberen. Het is op het moment gewoon bijna niet te doen. Tot er een betere driver uit komt denk ik dat je je 20 uur uitproberen en installen wel beter kunt besteden.
