tripledes asp naar php (2)
  • 54 views sinds 30-01-2008
Wat gaat er fout?
"Text Source String to be encrypted" op http://www.aspsimply.com/aspnet/CryptoASPX.aspx ge-encode met key "1234567890". Maar kan hem op geen enkele manier decoden....
PHP:
$key="1234567890";
//encoded: http://www.aspsimply.com/aspnet/CryptoASPX.aspx
$crypttext = "XJamKoU3knTaVgSXPI4dKDKSBBePymeh3KzL2fYcrsuJzg2vgYBMLOhNHv67QrQ1AnHdacJS4KvkS85vtBeeqa7EJFPgGbRa";
$iv_size = mcrypt_get_iv_size(MCRYPT_3DES, MCRYPT_MODE_ECB);
$iv = mcrypt_create_iv($iv_size, MCRYPT_RAND);
print " - ".mcrypt_decrypt(MCRYPT_3DES, $key, base64_decode($crypttext), MCRYPT_MODE_ECB, $iv)."<BR>";
print " - ".mcrypt_decrypt(MCRYPT_3DES, $key, base64_decode($crypttext), MCRYPT_MODE_CBC, $iv)."<BR>";
print " - ".mcrypt_decrypt(MCRYPT_3DES, $key, base64_decode($crypttext), MCRYPT_MODE_CFB, $iv)."<BR>";
print " - ".mcrypt_decrypt(MCRYPT_3DES, $key, base64_decode($crypttext), MCRYPT_MODE_OFB, $iv)."<BR>";
print " - ".mcrypt_decrypt(MCRYPT_3DES, $key, base64_decode($crypttext), MCRYPT_MODE_NOFB, $iv)."<BR>";
  • Creepy
Creepy
Tactical Espionage Splatterer
Zie Je topic is dicht en het is onterecht? Lees hier!
Neem daarnaast P&W FAQ - De "quickstart" ook nog ens door want dit gaat op deze manier echt nergens over.
"I had a problem, I solved it with regular expressions. Now I have two problems". That's shows a lack of appreciation for regular expressions: "I know have _star_ problems" --Kevlin Henney
