[exchange] Exmerge loopt stuk bij meer dan 16834 items
Wanneer ik met Exmerge een mailbox wil exporteren uit Exchange 5.5 (windows 2000 server). Loopt Exmerge stuk nadat er 16384 items zijn verwerkt en in een PST file zijn gezet.
De volgende foutmelding verschijnt dan:
"Operation Completed. Errors were encounterd. Fore more details please refer to the log file C:\exmerge.log"
En dat doe ik dan ook uiteraard:
[09:23:06] Logging Level: None
[09:23:06] Reading settings from file 'D:\EXMERGE\EXMERGE.INI'.
[09:23:06] Reading list of subjects for messages to be selected from file ''
[09:23:06] Reading list of attachment names for messages to be selected from file ''
[09:23:06] List of folders to be ignored has been read. 0 folders in the list.
[09:23:06] Current machine locale ID is 0x409
[09:23:06] Operating System Version 5.0 (Build 2195)
[09:23:06] Incorrect registry value data type for 'Software\Microsoft\Exchange\Setup\ExchangeServerAdmin'.
[09:23:55] Error parsing DN '' (CADRoutines::GetExchange5xServerNameInfo)
[09:23:55] 'NL-ASD-EXCH2' is running Exchange Server 5.x
[09:24:12] Using attribute 'PR_MESSAGE_DELIVERY_TIME' for date operations.
[09:24:12] Only copying messages created between 01/01/1900   00:00:00, and 01/31/2005   23:59:59.
[09:24:12] Archiving data from the source store. The program will copy data from the source store to the target store, and then delete the data in the source store.
[09:24:12] Associated folder data will NOT be copied to the target store.
[09:24:12] Using 'English (US)' (0x409) as the default locale (Code page 1252)
[09:24:12] All mailboxes will be processed, regardless of locale
[09:24:12] Initializing worker thread (Thread0)
[10:02:51] Errors encountered copying the messages in folder '\Inbox'. One or  more messages may not have been copied.
[10:02:52] Number of messages processed for mailbox 'MAILBOX': 37135
[10:17:07] Total number of folders processed in the source store: 28
[10:17:07] 4 mailboxes successfully processed. 0 mailboxes were not successfully processed. 20578 non-fatal errors encountered.
[10:17:07] Process completion time:  0:00:52:54
Zoals er word aangegegeven zijn er 37135 items verwerkt, echter staan er maar 16383 in de PST file.
Er staan wel wat meldingen in van berichten die niet gearchiveerd kunnen worden.
Maar als ik nogmaals Exmerge draai neemt ie ze wel mee omdat het aantal dan onder de 16384 ligt. Vreemd genoeg. Ik mis uiteindelijk geen enkel bericht.
Verder blijft alles gewoon draaien.
Doe ik vervolgens nog een keer een exmerge dan worden er weer 16384 items in een nieuwe .PST file gezet (aan dezelfde toevoegen lukt niet).
Daarna kan ik zo'n pst file wel weer aan outlook toevoegen en alles samenvoegen, maar das zonde van de tijd lijkt mij.
Het lijkt er dus op dat Exmerge niet meer dan 16384 berichten kan verwerken.
Kent iemand dit probleem en weet iemand hier een oplossing voor? Google leverde helaas niks concreets op.
Want dit is best lastig als je grote mailboxen moet archiveren.
  • collin
  • Laatst online: 03-09 14:37
collin
Who da man !!
Ik heb met Exmerge wel eens 50 mailboxen geexporteerd, waarbij ik zeker weten veel meer items gebackupped heb dan 16384 items. Exmerge is een migratietool tussen Exchange servers, dus het lijkt me wel de bedoeling dat je er flink wat mee kan verstouwen :)
Staan er in die mailbox genaamd MAILBOX 37000+ items in 1 en dezelfde map? Wellicht is dat de bottleneck. Maar dat kan ik me ook niet voorstellen.
Mijn iRacing profiel
Als het over meerdere boxen verspreid is, dan is het ook geen probleem.
De box die hier ge-exmerged word bevat alleen maar items in de inbox.
Deze keer zaten d'r bijna 40.000 in.
collin schreef op dinsdag 01 februari 2005 @ 16:45:
Ook mag je pst niet groter dan 2 Gb worden......dacht ik zo.
Daat zit ie nadat ie vast liep nog niet aan. De PST file was toen zo'n 650MB.
  • collin
collin
Who da man !!
Hij maakt ook per mailbox een PST aan, dus een mailbox van 2GB zal ook problemen geven idd, maar hij gooit dus niet alle mailboxen in 1 PST.
Je probleem is bekend trouwens:
As many exchange admins do, I from time to time use exmerge for quick / simple backup routines of a mailbox.
I was trying to export a mailbox that had a log entry going to it every few seconds and had a total of 120k messages in it. I decided the easiest way to let someone deal with deleting these was to stop the new messages, export them to a pst, and let them delete the ones that should be deleted on their local box. For some reason it seemed very slow deleting on exchange (possibly exchange doesn't deal well with 120k messages in a single folder, inbox).
The exmerge completed fine, just with some warnings that went to the log file.
The warnings were: Error copying message with subject ... in folder '\Inbox'. (MAPI_W_PARTIAL_COMPLETION)
The .PST file had 16383 or 16384 (I don't recall which) items in the inbox, however it didn't have the 120,000 I expected.
This seems to be a limit either in the PST file format, on in exmerge.
I haven't had time yet to confirm if this is a known issue or a bug, however some searches didn't turn up any known issues.
Steve Radich - Troubleshooting, Colocation, Development and more..
BitShop, Inc. - http://www.bitshop.com
bron: http://www.aspdeveloper.net/tiki-view_blog.php?blogId=4
Aangezien 16384 een mooi octaal getal is (decimaal weergegeven) (2^13 dacht ik), zal dat dan wel een hardcoded limiet zijn. Of een bug :|
Kortom: autoarchive aanzetten :P
Kan je BTW wel vanuit Outlook zoveel items exporteren naar een PST? Dat zou dan wel gek zijn..
Yep, als je een lege pst file aanmaakt (gewoon een nieuwe personal folder) en dan lekker een heel zooi items erheen sleept gaat het prima. Alleen kun je op dat moment je outlook niet gebruiken.
Autoarchive heeft geen zin, omdat er geen gebruiker inlogt bij die mailbox.
[ Voor 17% gewijzigd door Verwijderd op 02-02-2005 09:20 ]
