[suse 9.2] Linux drivers install probleem (kernel module)
  • Simkin
  • Laatst online: 25-10 18:08
*** PROBLEEM OPGELOST ***
Volg deze handleiding (readme): ftp://ftp.mirror.nl/pub/m...upplementary/X/ATI/suse92
Dag allemaal,
ik heb een probleem met het installeren van mijn ATI drivers voor mijn radeon 9800 pro.
Ten eerste start ik de install met:
rpm -Uh --force fglrx_6_8_0-8.8.25-1.i386.rpm
Ik krijg dan de volgende feedback:
########################################### [100%]
*** Trying to install a precompiled kernel module.
*** WARNING ***
Tailored kernel module for fglrx not present in your system.
You must go to /lib/modules/fglrx/build_mod subdir
and execute './make.sh' to build a fully customed kernel module.
Afterwards go to /lib/modules/fglrx and run './make_install.sh'
in order to install the module into your kernel's module repository.
(see readme.txt for more details.)
As of now you can still run your XServer in 2D, but hardware acclerated
OpenGL will not work and 2D graphics will lack performance.
failed.
*** Error: no kernel module build environment - please consult readme.
/sbin/ldconfig: File /usr/X11R6/lib/FGL.renamed.libGL.so.1.2 is too small, not checked.
*** Warning ***
The QT based control panel application did not load in any version.
ATI display drivers successfully installed
please run 'fglrxconfig' now
Ik ga dus naar de /lib/modules/fglrx/build_mod directory en run (als root):
./make.sh
en krijg de volgende feedback:
-bash: ./make.sh: Permission denied
Ik maak de batch file executable en run die nogmaals en krijg nu de volgende feedback:
ATI module generator V 2.0
initializing...
Error:
kernel includes at /usr/src/linux/include do not match current kernel.
they are versioned as "2.6.8-24.11-default"
instead of "2.6.8-24-default".
you might need to adjust your symlinks:
- /usr/include
- /usr/src/linux
Dus ik kijk hoe de symlink staat:
linux -> linux-2.6.8-24.11
uname -a vertelt mij:
Linux linux 2.6.8-24-default #1 Wed Oct 6 09:16:23 UTC 2004 i686 athlon i386 GNU/Linux
Ik zie dat de .11 versie daar niet achter staat, terwijl de kernel wel is geupdated via yast, geen idee of dat zou moeten..
De volgende stappen die ik uitvoerde:
export LINUXDIR=/usr/src/linux
daarna:
cd $LINUXDIR
(dat commando navigeerde me naar /usr/src/linux)
daarna:
make cloneconfig
daarna:
make prepare-all
Vervolgens ging ik weer terug naar /lib/modules/fglrx/build_mod en runde ik:
./make.sh
Die mij de volgende feedback gaf:
initializing...
cleaning...
patching 'highmem.h'...
assuming new VMA API since we do have kernel 2.6.x...
doing Makefile based build for kernel 2.6.x and higher
make -C /lib/modules/2.6.8-24-default/build SUBDIRS=/lib/modules/fglrx/build_mod/2.6.x modules
make: *** /lib/modules/2.6.8-24-default/build: No such file or directory.  Stop.
make: *** [kmod_build] Error 2
build failed with return value 2
Nu vraag ik me af wat die Error 2 inhoud, of ik iets fout doe en hoe ik dit moet oplossen :|
als ik dus naar /lib/modules/fglrx ga en sh make_install.sh run krijg ik weer de melding:
*** WARNING ***
failed.
ik krijg het niet voor elkaar om de kernel module te installeren :(
Kan iemand mij op weg helpen?
Alvast bedankt voor de moeite!
[ Voor 7% gewijzigd door Simkin op 01-02-2005 21:13 ]
  • thegve
  • Laatst online: 13-05 23:53
Ik heb precies hetzelfde probleem, eerst met Mandrake, omdat je daar geen gratis updates ben ik gisteren weer (terug dus) veranderd naar Suse.
De ATI driver zijn weer eens brak, amper 2 weken na de release van de nieuwe drivers staan alle fora al weer vol met topics als de jouwe. (tot zover het geerger).
Ik heb het nog steeds niet voor mekaar dus, maar op
ftp://ftp.mirror.nl/pub/m...pplementary/X/ATI/suse92/
staat een beschrijving (de readme) over hoe je het voor mekaar zou moeten krijgen. Hopelijk heb jij hiermee meer geluk als ik, want bij mij wil die fglrx nog steeds niet starten.
  • Simkin
Ik ben ondertussen wel al iets verder.
de stappen:
daarna:
cd $LINUXDIR
daarna:
make cloneconfig
daarna:
make prepare-all
waren in iedergeval voor mij noodzakelijk.
Toen ik daarna de make.sh en make_install runde bleek dat ik nog in init mode 5 zat,. toen ik naar init 3 ging kon ik compileren met een aantal warnings, als ik thuis kom zal ik daar een quote van posten.
Maar nadat ik fglrx config draai start X niet meer op, dan moet ik sax 2 starten en dan werkt het weer, dus ergens gaat het nog fout helaas.
Ik ga die tutorial eens goed bekijken en laat wel weten of ik iets wijzer wordt!
  • Simkin
thegve schreef op maandag 31 januari 2005 @ 22:42:
Bedankt voor de link, ik heb de instructies in de readme die op de ftp staan gevolgd, en het probleem is opgelost :D
Bedankt voor de link!
