network trouble with linux and windows
  • 57 views sinds 30-01-2008
  • grooverider134
  • Laatst online: 08-01-2022
hoi people ;) , first of all my apologies for posting in english but i'm an exhancge student and my dutch still sucks but i need sum serious help so... _/-\o_ i have a problem which is driving me crazy |:( 8)7 with my network, i have been trying to find help on the net for weeks now, but couldn't find any helpful sites relating to my problem so i thought i'd try posting it on here. I tried to include all the information i have but i'm a linux n00b sort of... anyways i have a network with three computers
machine#1: 10.0.0.1 windows 2000 prof
machine#2: 10.0.0.3 linux suse 9.0 with samba Version 2.2.8a-SuSE
machine#3: 10.0.0.4 windows 2000 prof
all machines can ping each other and both windows machines can read each others shares and the shares of the linux machine, in linux i can also mount the shares of machine #1 but not the ones of machine #3 althought when doing:
smbclient -L machinename -U user
i can see the shares of machine#3 but when i try to mount them with e.g.
mount -t smbfs -o username=xxx,password=xxxx //machinename/SGC/ /test
it does not work, neither when i specify workgroup, ip or more options i get the following error:
16025: tree connect failed: ERRDOS - ERRnosuchshare (You specified an invalid share name)
SMB connection failed
the number 16025 changes btw, and if u think i have a typo in my mount command because it says invalid share name, that is not the problem, i have checked that many times, and mounting shares from machine#1 is no problem, that works fine.
smbclient -L machine3 -U user gives this:
added interface ip=10.0.0.3 bcast=10.0.0.255 nmask=255.255.255.0
Got a positive name query response from 127.0.0.1 ( 10.0.0.4 )
Password:
Domain=[WEBCHILLA] OS=[Windows 5.0] Server=[Windows 2000 LAN Manager]
Sharename Type Comment
E$ Disk Default share
ftp6 Disk
IPC$ IPC Remote IPC
G$ Disk Default share
F$ Disk Default share
SGC Disk
G Disk
ADMIN$ Disk Remote Admin
H$ Disk Default share
C$ Disk Default share
Grooverider Disk Education Corner
ftp3 Disk
Server Comment
Workgroup Master
smbclient -L machine#1 -U user gives this:
Password:
ftp1 Disk
IPC$ IPC Remote IPC
D$ Disk Default share
Funky Disk
Series Disk
Software Disk
Server Comment
Workgroup Master
as you can see there is a difference in this line with the problem machine:
both computers have the same username/password which is also added in linux, rights and privelges are also checked and ok, i set in both windows computer to never be masterbrowser or domain controller and testparm shows this:
Load smb config files from /etc/samba/smb.conf
Processing section "[homes]"
Processing section "[printers]"
Processing section "[print$]"
Processing section "[documents]"
Processing section "[chinaconnection desktop]"
Processing section "[htmlstuff]"
Processing section "[funkmaster home]"
Processing section "[glftpdtest]"
Processing section "[my azz]"
Processing section "[Deep Space Nine]"
Processing section "[geexbox]"
Loaded services file OK.
WARNING: You have some share names that are longer than 8 chars
These may give errors while browsing or may not be accessible
to some older clients
Press enter to see a dump of your service definitions
my log.nmbd has this error:
[2005/01/27 17:04:05, 0] nmbd/nmbd_browsesync.c:find_domain_master_name_query_fa il(358)
find_domain_master_name_query_fail:
Unable to find the Domain Master Browser name WEBCHILLA<1b> for the workgroup WEBCHILLA.
Unable to sync browse lists in this workgroup.
my smb.conf looks like this:
# Samba config file created using SWAT
# from 0.0.0.0 (0.0.0.0)
# Date: 2005/01/07 17:54:11
# Global parameters
[global]
workgroup = WEBCHILLA
server string = ChinaConnection
interfaces = eth1
encrypt passwords = Yes
map to guest = Bad User
time server = Yes
unix extensions = Yes
socket options = SO_KEEPALIVE TCP_NODELAY IPTOS_LOWDELAY
printcap name = CUPS
os level = 128
preferred master = Yes
domain master = No
wins support = Yes
printing = cups
[homes]
comment = Home Directories
invalid users = geexbox
valid users = %S
read only = No
create mask = 0640
directory mask = 0750
browseable = No
[printers]
comment = All Printers
path = /var/tmp
create mask = 0600
printable = Yes
browseable = No
[print$]
comment = Printer Drivers
path = /var/lib/samba/drivers
write list = @ntadmin,@root
force group = ntadmin
create mask = 0664
directory mask = 0775
[documents]
comment = documents
path = /home/funkmaster/Documents/
read only = No
comment = ChinaConnection Desktop
path = /home/funkmaster/Desktop/
read only = No
[htmlstuff]
comment = susi share
path = /home/funkmaster/public_html/
read only = No
[funkmaster home]
comment = funkmaster home
read only = No
[glftpdtest]
path = /prison/glftpd/site
guest account =
valid users = funkmaster,funky1,@root,@users
read only = No
[my azz]
comment = argh
path = /home/funkmaster/ftp
read only = No
and so on...
i have no idea what the problem is, I would appreciate some tips on what could be wrong very very much thx in advance :*)
  • Koffie
  • Laatst online: 01-09 17:48
Koffie
Koffiebierbrouwer
Braaimeneer
Sorry, this topic is locked until further notice; I want to discuss this with some other crew-members.
Braaikamer - Smoke&BBQ
  • Kees
  • Laatst online: 13:24
Kees
Serveradmin / BOFH / DoC
Although this topic is still locked, here the solution:
You need to specify your share without the leading /, an example:
kees# smbmount //server/Media/ test
Password:
Anonymous login successful
1594: tree connect failed: ERRDOS - ERRnosuchshare (You specified an invalid share name)
root@iris(pts/11):/home/kees
kees# smbmount //server/Media test
Password:
