ATEN CS-1742: 2 Port Dual-View KVM Switch
Op zoek naar een KVM switch waar 2 monitoren op gehangen konden worden, kwam ik het volgende tegen..
The Master View Dual-View CS-1742 USB KVM Switch brings dual head video functionality to ATEN's USB KVM switch technology. Now, two dual head computers can be accessed and controlled from a single console that consists of a USB keyboard, USB mouse, and two VGA, SVGA, or Multisync monitors. In addition, the CS-1742 incorporates a two port USB hub that allows each of the computers to share any USB peripherals connected to the hub on a one computer at a time basis. Recognizing the importance of sound, the switches are also audio enabled. A single microphone can provide audio input to each of the computers, and you can listen to the audio output of each computer on a single set of speakers (on a one-at-a-time basis). Multi-button mouse support via drivers
Features:
  • Allows one keyboard, mouse speaker, mic and two displays to control two dual display computers.
  • Integrated USB Hub - one USB port at front for convenient link of flash drive or digital camera
  • Multiplatform compatibility MAC, SUN, PC(Windows, Linux and moust others)
  • Bi-directional switching and flexible interoperatibility permits independent PC, peripheral and audio functionality
  • Supports 2048 x 1536 maximum display resolution
  • Programmable hotkey operations
  • Flash upgradeable
  • Multi-button mouse support via drivers
  • Supports multimedia USB keyboards
Specs:
Afbeeldingslocatie: http://pictureposter.allbrand.nu/pictures/God/schema.JPG
Wat plaatjes:
Afbeeldingslocatie: http://www.aten.com/data/items/cs_1742_front.jpg
Afbeeldingslocatie: http://www.aten.com/data/items/cs_1742_back.jpg
Afbeeldingslocatie: http://www.aten.com/data/items/cs_1742_diagram.gif
Linkje:
http://www.aten.com/02-p-item.php?id=661
Hij staat nog niet in de Pricewatch en met Google issie ook niet echt te vinden helaas.
Ik heb iig een paar vragen.
Die max resolutie, is dat de resolutie per scherm of de gezamelijke resolutie van de 2 schermen?
Ik heb een CRT en een TFT, gaat dat goed samen op zo'n switch?
En de hamvraag; waar kan ik um kopen?
  • KeeZ
  • Laatst online: 25-04-2022
KeeZ
Deze plek is te koop.
dat lijkt me ook wel interresant... kan ik ook eindelijk mijn powerbook eens optimaal benutten én mijn dual screen behouden...
Weet iemand of dit ding al ergens verkrijgbaar is.
  • janniet
  • Laatst online: 26-08 15:05
janniet
www.eynstein.nl
kijk maar even, ik heb even niet verder gezocht
[ Voor 65% gewijzigd door janniet op 23-11-2005 01:28 ]
