• Christiano007
  • Laatst online: 07:26
Christiano007
Ich bin der champion
De Muzio JMH 1000 met 4 GB geheugen is de nieuwste hard disk speler van Muzio. Verkrijgbaar in het zilver en zwart. Met tekst reader, 64K Kleuren LCD scherm 1,5 inch, Foto bestanden kijken is mogelijk, voice recording en eenvoudige bediening. Een echte TOPSPELER met hoge geluidskwaliteit en voorzien van een stevige cache. De speler laadt op via de USB poort.
Afbeeldingslocatie: http://www.mp3discount.nl/pics/muzio/jmh1000_1.jpg
Afbeeldingslocatie: http://www.mp3discount.nl/pics/muzio/jmh1000_2.gif
MUZIO armed with 1.5inch LCD screen and 65K color OLED will show you live like Display.
USB 2.0 Support
It's been much shorter to transfer data with USB 2.0. Get faster with MUZIO!
Host & Device Function (HD)
No matter whatever device you have! HD functioned MUZIO will transfer any data from any Digital Devices such as Camera, Camcorder, MP3 P...etc. without PC. Enjoy your digital life with evolved MUZIO. Dual Eaephone(Couple Eaephone)
Good song but can not share. What a pity it is!
MUZIO II is providing Dual Earphone Jack (Couple Earphone Jack). Feel the music sound together with your lover or friend
Perfect OGG file Support
MUZIO II fully supports OGG (Ogg Vorbis), the next generation file format of MP3, which has higher compress rate and better sound quality than MP3 format. From now on, let's be OGG player!
SRS, TruBass, WOW
SRS and Magnificent TruBass Sound! Feel the plentiful Bass and 3D stereophonic sound of MUZIO H1000.
Extended Play Speed Control Range MUZIO JMH1000 provides Speed Control Function with the range of 70%~130% by 10%. It will make you easier to learn the language.
Auto Image Slide
Transfer the image from your digital camera by MUZIO USB Host & Device Function directly and enjoy your pictures on JPEG, BMP through MUZIO Image Slide.
Text Viewer
The memo input on PC Memo pad will be able to see on MUZIO.
MP3 Encoding
Direct Encoding. Get the file from the analogue devices like LP, CD, Cassette and play through MUZIO!
Voice Recording Function
Do not want to lose the great lecture? Do not worry with MUZIO II. MUZIO clearly records in MP3 or TVF file formats and VOR Function that make the device work upon the sound recognition will save the memory and the power.
Audio Play List
Be a picky! MUZIO will make you a picky with Audio Play list.
Users can select the files whatever they want on Audio File Navigation Mode and save them into Play List so that they can listen only the selected ones.
Big Size Built In Li-Polymer Battery
Hardware Specifications Muzio JHM-1000
LCD CSTN-LCD 1.5 inch
128 by 128 dots, 65,535 color CSTN-LCD
Storage 1 inch 4 Giga Byte (UMS Support)
Ear-Phone port Dual Earphone (Line-In port & Ear-Phone port)
Ear-Phone Powers Output: 12mW/12mW (left/right)
Line-In port Multiple Use (Earphone & Line-In)
MIC Support
USB USB 2.0 Slave Support (mini type B)
USB 1.1 Host Support (mini type B receptacle)
Interface 1 x LED
10 x Buttons
1 x Holder
1 x USB port
1 x Power Connector
2 x IO ports
Battery Lithium-Polymer 3.7V 1000mA
Size 53.5 x 92.5 x 23 mm
Weight Approximately 100~120g
Power Charge Recharging by USB Power or External AC Charger
Battery Built-in Lithium-Polymer Battery
Charge USB port charge, AC adaptor(optional)
Capacity 4G
Size 53.5mm x 95.5mm x 23mm
Software Spec
File System FAT32
Audio File Support MP3, ASF, OGG, WMA
ID3 Tag display Support
Lyric Support Support
Audio play list Support
Playing Speed Control 70%~130% (Controlled in 10%)
Auto Play Support
Resume Support
Fade-In Support
UMS Support Support
Recording Type Encoding by MP3
Recording Sources Voice Recording (VAD Support)
Recording External Sound Sources (Direct Encoding, Sync Support)
Support Image files BMP, JPEG
Automatic Image Viewer Support
Text Viewer Support
Firmware Upgrade Support
EQ Mode 6 Band
3D sound effect SRS/WOW
Navigation Browser Support by Each Mode
Animation Intro, Outtro Support
Play Mode A to B, Intro, Single (One Song), All, Directory, Random Support
Multi Language Support Main Languages Support
Muzio JMH 1000 4 Gb: €219,-
Lijkt me toch een mooi spelertje, 4GB voor 220 euro!
Alleen nu is mij niet duidelijk hoeveel uur de speler kan spelen
Ter land, ter zee en in de kroeg
  • kemphaas
  • Laatst online: 28-10 14:28
Lijkt me idd een leuke speler. cker met kleurenscherm erbij voor 220 is nie duur
Werk hard als je tijd hebt, dan heb je tijd als je hard moet werken.
  • Christiano007
Christiano007
Ik had een mailtje gestuurd met hoelang de batterijduur was
De batterijduur van de Muzio is 16 uur.
waar is deze te koop??
  • Wutroe
  • Laatst online: 21:41
Te koop op: http://www.mp3discount.nl/
Specificaties van fabrikant: http://www.muzio.co.kr/eng/product/jmh1000.asp
Daar staan ook foto's van een zwarte versie, die ziet er nog een stuk strakker uit wat mij betreft!
[ Voor 36% gewijzigd door Wutroe op 20-01-2005 16:19 ]
  • Christiano007
Christiano007
De levertijd is 2 weken, maar ze kunnen sneller leveren zeggen ze.
