[ASP.NET] 'DataGridPageChangedEventArgs' is not defined
Ik ben bezig met ASP.NET en VB.NET mijn 1ste webpagina te maken. Ik heb al een aantal tutorials doorgenomen en ben nu op het volgende probleem gestuit.
ik heb de volgende code:
datagrid.vb (code behind)
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
Imports System.Data
Imports System.Data.OleDB
Public Class datagrid
    Inherits System.Web.UI.Page
    Protected WithEvents DataGridBooks as System.Web.UI.WebControls.DataGrid
    Private Sub Page_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        If Not Page.IsPostBack Then
            BindData()
        End If
    End Sub
    Private sub BindData()
        Dim ds As Dataset
        Dim objConnection As OleDbConnection
        Dim strSQLQuery As String
        Dim objCommand as OleDbDataAdapter
        'set up connection
        objConnection = new OleDbConnection("Provider=Microsoft.Jet.OLEDB.4.0; data source=" & server.mappath("book-dvd.mdb"))
        'Sql syntax
        strSQLQuery = "select * from books"
        'open connection
        objCommand = new OleDbDataAdapter(strSQLQuery, objConnection)
        'fill dataset
        ds = new DataSet()
        objCommand.Fill(ds, "books")
        'select data view and bind to server control
        DataGridBooks.DataSource = ds.Tables("books").DefaultView
        DataGridBooks.DataBind()
    end sub
    Sub DataGridBooks_PageChanger(Source As Object, E As DataGridPageChangedEventArgs)
        ' Set the CurrentPageIndex before binding the grid
        DataGridBooks.CurrentPageIndex = E.NewPageIndex
        BindData()
    End Sub
End Class
en datagrid.aspx
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
<%@ Page Language="vb" AutoEventWireup="false" Src="datagrid.vb" Inherits="datagrid"%>
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML>
  <HEAD>
    <title>Datagrid test</title>
  </HEAD>
  <body>
      <form id="frmDatagrid" method="post" runat="server">
      <asp:datagrid id="DataGridBooks"
         runat="server"
         ItemStyle-Font-Size="x-small"
         HeaderStyle-Font-Bold="True"
         HeaderStyle-Font-Size="x-small"
         AlternatingItemStyle-BackColor="#EFEFEF"
         Cellpadding="4"
         BorderWidth="1"
         AutoGenerateColumns="False"
         BorderStyle="Solid"
         GridLines="Horizontal"
         BorderColor="#404040"
         Font-Names="Verdana,Arial,sans-serif"
         Font-Size="11px"
         AllowPaging="True"
         PageSize="10"
         PagerStyle-Mode="NumericPages"
         OnPageIndexChanged="DataGridBooks_PageChanger">
        <AlternatingItemStyle BackColor="#E0E0E0"></AlternatingItemStyle>
        <ItemStyle Font-Size="X-Small"></ItemStyle>
        <HeaderStyle Font-Size="X-Small"
           Font-Bold="True"
           ForeColor="White"
           BackColor="Teal"></HeaderStyle>
        <Columns>
          <asp:TemplateColumn>
            <HeaderTemplate>
              <b>Books</b>
            </HeaderTemplate>
            <ItemTemplate>
              <table border="1" Cellpadding="4" Cellspacing="0" Width="100%" style="FONT-SIZE: 11px; FONT-FAMILY: Verdana, Arial, sans-serif">
                <tr>
                  <td colspan="4">
                    <b>
                      <%# Container.DataItem("Titel") %>
                    </b>
                  </td>
                </tr>
                <tr>
                  <td width="25%" valign="top"><b>ID:</b></td>
                  <td width="25%" valign="top" nowrap>
                    <%# Container.DataItem("ID") %>
                  </td>
                  <td width="25%" valign="top"><b>Picture:</b></td>
                    <%# Container.DataItem("Picture") %>
                  </td>
                </tr>
                <tr>
                  <td width="25%" valign="top"><b>Author:</b></td>
                    <%# Container.DataItem("Author") %>
                </tr>
                <tr>
                  <td width="25%" valign="top"><b>Misc:</b></td>
                  <td width="25%" valign="top" colspan="3">
                    <%# Container.DataItem("Gerne") %>
                    <br>
                    <%# Container.DataItem("Type") %>
                    <br>
                  </td>
                </tr>
              </table>
            </ItemTemplate>
          </asp:TemplateColumn>
        </Columns>
      </asp:datagrid>
     </form>
  </body>
</HTML>
Wanneer ik deze code uitvoer (ik gebruik geen VS.NET, maar doe alles met de hand), krijg ik de volgende foutmelding:
Compiler Error Message: BC30002: Type 'DataGridPageChangedEventArgs' is not defined.
Source Error:
Line 37: end sub
Line 38:
Line 39: Sub DataGridBooks_PageChanger(Source As Object, E As
Line 40: ' Set the CurrentPageIndex before binding the grid
Line 41: DataGridBooks.CurrentPageIndex = E.NewPageIndex
Nu snap ik eerlijk gezegd niet waar dit mis op gaat. moet ik hier ook een:
van maken? en zo ja, hoe moet ie dan genoemd worden?
Het grote nadeel van tutorials is dat ze ook weinig uit leggen (ik ben dan ook van plan om een boek te gaan kopen, maar ben er nog niet over uit welk) wat doet namelijk die regel? (die van protected WithEvents ...)
Ik hoop dat iemand me kan helpen. Het zal waarschijnlijk iets simpels zijn, maar ik zie het niet.
  • whoami
De class DataGridPageChangedEventArgs is gedefinieerd in de namespace System.Web.Ui.WebControls en die heb je nergens ge-import.
Dus, import die namespace of schrijf de class voluit (met z'n FQN):
System.Web.Ui.WebControls.DataGridPageChangedEventArgs.
redelijk basic eigenlijk
https://fgheysels.github.io/
