Mobile XP op dit mobo??
  • 49 views sinds 30-01-2008
Hoi,
Kan dit mobile XP op een MSI K7N2 Delta2-LSR nForce2 werken?
En kan ik dan ook ON-THE-FLY in windows Multiplyer verhogen?
Erg belangrijk voor mij!
Ok, bedankt.
EDIT:::::
Mobiles work great for overclocking on the K7N2 boards. But here is the thing MSI has not released a bios that supports them so no matter what it will never detect the auto settings and you can never run the stock settings. In short the 13 multi is the highest you will ever see. If you did leave it at auto it will boot at 100FSB and a multiplier of 6 or 8 = 600 or 800Mhz.
Either way you have to raise the FSB just to reach stock MHz (1833) My suggestion is stick with a supported CPU until you upgrade your ram.
quote:
The model number is not the speed, although with the mobile, people have reported success in reaching the model number as their overclock (2500+ overclocked to 2.5GHz)
I can almost reach it on my mobile 2500+ Im maxed out at 2475Mhz 198 X 12.5 but i just stick with 200 X 12 = 2400Mhz (Vcore 1.650v)
[ Voor 63% gewijzigd door Verwijderd op 19-01-2005 00:40 ]
