[NdisWrapper] Debian 2.6.8.1-386
  • menn0
  • Laatst online: 11:44
Beste mensen, alvast beste wensen
Ik probeer met debian mijn belkin 54g pci adapter aan de praat te krijgen, dat moet via ndiswrapper.
Loaden gaat, listen gaat, maar modproben gaat mis :(
HIer het uitgebreide verslag;
No drivers installed
Linux-server:/home/home/menno/wifi# ndiswrapper -i bcmwl5a.inf
Installing bcmwl5a
Linux-server:/home/home/menno/wifi# ndiswrapper -l
Installed ndis drivers:
bcmwl5a driver present, hardware present
Linux-server:/home/home/menno/wifi# modprobe ndiswrapper
Linux-server:/home/home/menno/wifi# dmesg
Linux version 2.6.8-1-386 (joshk@trollwife) (gcc version 3.3.5 (Debian 1:3.3.5-2)) #1 Thu Nov 25 04:24:08 UTC 2004
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009f400 (usable)
BIOS-e820: 000000000009f400 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 0000000003000000 (usable)
BIOS-e820: 00000000fffe0000 - 0000000100000000 (reserved)
48MB LOWMEM available.
On node 0 totalpages: 12288
DMA zone: 4096 pages, LIFO batch:1
Normal zone: 8192 pages, LIFO batch:2
HighMem zone: 0 pages, LIFO batch:1
DMI not present.
ACPI: Unable to locate RSDP
Built 1 zonelists
Kernel command line: root=/dev/hda2 ro
No local APIC present or hardware disabled
Initializing CPU#0
PID hash table entries: 256 (order 8: 2048 bytes)
Detected 132.958 MHz processor.
Using tsc for high-res timesource
Console: colour VGA+ 80x25
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 41508k/49152k available (1332k kernel code, 7184k reserved, 729k data, 204k init, 0k highmem)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
Calibrating delay loop... 260.60 BogoMIPS
Security Scaffold v1.0.0 initialized
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
CPU: After generic identify, caps: 000001bf 00000000 00000000 00000000
CPU: After vendor identify, caps: 000001bf 00000000 00000000 00000000
Intel Pentium with F0 0F bug - workaround enabled.
CPU: After all inits, caps: 000001bf 00000000 00000000 00000000
CPU: Intel Pentium 75 - 200 stepping 0c
Checking 'hlt' instruction... OK.
Checking for popad bug... OK.
checking if image is initramfs...it isn't (ungzip failed); looks like an initrd
Freeing initrd memory: 4264k freed
NET: Registered protocol family 16
EISA bus registered
PCI: PCI BIOS revision 2.10 entry at 0xfd99c, last bus=7
PCI: Using configuration type 1
mtrr: v2.0 (20020519)
ACPI: Subsystem revision 20040326
ACPI: Interpreter disabled.
Linux Plug and Play Support v0.97 (c) Adam Belay
PnPBIOS: Scanning system for PnP BIOS support...
PnPBIOS: Found PnP BIOS installation structure at 0xc00fdfd0
PnPBIOS: PnP BIOS version 1.0, entry 0xf0000:0xab68, dseg 0xf0000
PnPBIOS: 17 nodes reported by PnP BIOS; 17 recorded by driver
PCI: Probing PCI hardware
PCI: Probing PCI hardware (bus 00)
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
devfs: 2004-01-31 Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x0
Initializing Cryptographic API
Limiting direct PCI/PCI transfers.
Activating ISA DMA hang workarounds.
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Serial: 8250/16550 driver $Revision: 1.90 $ 54 ports, IRQ sharing enabled
ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
EISA: Probing bus 0 at eisa0
Cannot allocate resource for EISA slot 5
EISA: Detected 0 cards.
NET: Registered protocol family 2
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 4096 bind 8192)
NET: Registered protocol family 8
NET: Registered protocol family 20
RAMDISK: cramfs filesystem found at block 0
RAMDISK: Loading 4264 blocks [1 disk] into ram disk... done.
VFS: Mounted root (cramfs filesystem) readonly.
Freeing unused kernel memory: 204k freed
vesafb: probe of vesafb0 failed with error -6
SCSI subsystem initialized
libata version 1.02 loaded.
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
PIIX3: IDE controller at PCI slot 0000:00:01.1
PIIX3: chipset revision 0
PIIX3: not 100% native mode: will probe irqs later
ide0: BM-DMA at 0xffa0-0xffa7, BIOS settings: hda:DMA, hdb:DMA
hda: WDC WD1000BB-00CCB0, ATA DISK drive
hdb: Pioneer DVD-ROM ATAPIModel DVD-116 0109, ATAPI CD/DVD-ROM drive
Using anticipatory io scheduler
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
hda: max request size: 128KiB
hda: 195371568 sectors (100030 MB) w/2048KiB Cache, CHS=65535/16/63, (U)DMA
/dev/ide/host0/bus0/target0/lun0: p1 p2 p3
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
Adding 979924k swap on /dev/hda1. Priority:-1 extents:1
EXT3 FS on hda2, internal journal
Real Time Clock Driver v1.12
hdb: ATAPI 40X DVD-ROM drive, 256kB Cache, (U)DMA
Uniform CD-ROM driver Revision: 3.20
Capability LSM initialized
EXT3 FS on hda3, internal journal
pcnet32.c:v1.30i 06.28.2004 tsbogend@alpha.franken.de
PCI: Setting latency timer of device 0000:00:07.0 to 64
pcnet32: PCnet/PCI 79C970 at 0x5400, 00 20 35 b1 ef c6 assigned IRQ 10.
eth0: registered as PCnet/PCI 79C970
pcnet32: 1 cards_found.
8139too Fast Ethernet driver 0.9.27
eth1: RealTek RTL8139 at 0x5000, 00:50:22:94:d5:98, IRQ 9
eth1: Identified 8139 chip type 'RTL-8139C'
usbcore: registered new driver usbfs
usbcore: registered new driver hub
USB Universal Host Controller Interface driver v2.2
uhci_hcd 0000:00:01.2: Intel Corp. 82371SB PIIX3 USB [Natoma/Triton II]
uhci_hcd 0000:00:01.2: irq 15, io base 00005420
uhci_hcd 0000:00:01.2: new USB bus registered, assigned bus number 1
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
NET: Registered protocol family 17
eth1: link up, 100Mbps, full-duplex, lpa 0x45E1
ip_tables: (C) 2000-2002 Netfilter core team
ip_conntrack version 2.1 (384 buckets, 3072 max) - 296 bytes per conntrack
NET: Registered protocol family 10
Disabled Privacy Extensions on device c02ca840(lo)
IPv6 over IPv4 tunneling driver
eth0: no IPv6 routers present
eth1: no IPv6 routers present
ndiswrapper version 0.12 loaded (preempt=yes,smp=no)
ndiswrapper (import:235): Unknown symbol: ntoskrnl.exe:_allmul
ndiswrapper (import:235): Unknown symbol: ntoskrnl.exe:WRITE_REGISTER_USHORT
ndiswrapper (import:235): Unknown symbol: ntoskrnl.exe:WRITE_REGISTER_ULONG
ndiswrapper (import:235): Unknown symbol: ntoskrnl.exe:strncpy
ndiswrapper (import:235): Unknown symbol: ntoskrnl.exe:_aulldiv
ndiswrapper (import:235): Unknown symbol: ntoskrnl.exe:KeInitializeEvent
ndiswrapper (import:235): Unknown symbol: ntoskrnl.exe:IoBuildSynchronousFsdRequest
ndiswrapper (import:235): Unknown symbol: ntoskrnl.exe:IofCallDriver
ndiswrapper (import:235): Unknown symbol: ntoskrnl.exe:KeWaitForSingleObject
ndiswrapper (import:235): Unknown symbol: ntoskrnl.exe:sprintf
ndiswrapper (import:235): Unknown symbol: HAL.dll:KeStallExecutionProcessor
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisReadPcmciaAttributeMemory
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisWritePciSlotInformation
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisFreeMemory
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisAllocateMemoryWithTag
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisWritePcmciaAttributeMemory
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NDIS_BUFFER_TO_SPAN_PAGES
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisQueryBuffer
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisAdjustBufferLength
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisFreeBuffer
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisMFreeSharedMemory
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisQueryBufferOffset
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisMFreeMapRegisters
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisAcquireSpinLock
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisReleaseSpinLock
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisMSynchronizeWithInterrupt
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisReadConfiguration
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisReadNetworkAddress
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisCloseConfiguration
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisOpenConfigurationKeyByName
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisWriteConfiguration
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisAnsiStringToUnicodeString
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisInitAnsiString
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisWriteErrorLogEntry
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisSetTimer
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisMSetPeriodicTimer
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisMCancelTimer
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisMMapIoSpace
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisMQueryAdapterResources
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisMUnmapIoSpace
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisFreeSpinLock
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisFreeBufferPool
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisFreePacketPool
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisMDeregisterAdapterShutdownHandler
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisMDeregisterInterrupt
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisAllocateBuffer
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisAllocatePacket
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisMInitializeTimer
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisGetCurrentSystemTime
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisMSetAttributesEx
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisMRegisterInterrupt
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisMRegisterAdapterShutdownHandler
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisAllocateBufferPool
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisAllocatePacketPool
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisMAllocateMapRegisters
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisAllocateSpinLock
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisReadPciSlotInformation
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisMGetDeviceProperty
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisMRegisterMiniport
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisInitializeWrapper
ndiswrapper (import:235): Unknown symbol: NDIS.SYS:NdisMAllocateSharedMemory
ndiswrapper (load_driver:2034): unable to prepare driver 'bcmwl5a'
Wat gaat er fout? via google bar weinig te vinden over deze erorr meldingen. Ik gebruik ndiswrapper 0.12
  • Naj_Geetsrev
  • Laatst online: 21-07-2025
Welke driver gebruik je? (win9x, win2k of winxp. Wil soms nogal wat uitmaken, ik moet namenlijk de win2k drivers gebruiken :))
- edit: volgens mij gebruik je de zelfde drivers als ik, probeer de win2k drivers maar :) -
[ Voor 28% gewijzigd door Naj_Geetsrev op 20-12-2004 21:58 ]
  • menn0
ik heb de driver van Dell gebruikt bcmwl5a.inf
die wordt aangeraden op ndiswrappers wiki forrum.
Ik zal ook even win2k belkin proberen.
//edit ook die van belkin en de bcmwl5.inf van dell geven probleem:
ndiswrapper (load_driver:2034): unable to prepare driver 'bcmwl5'
[ Voor 95% gewijzigd door menn0 op 20-12-2004 23:27 ]
  • Wilke
  • Laatst online: 07:59
Kun je de informatie niet even samenvatten? Het is niet alsof iemand 1000+ regels zooi gaat doorlezen.
Probeer op z'n minst zelf uit te vinden wat relevant zou kunnen zijn voor je zo'n hoop zooi post.
  • zomertje
  • Laatst online: 17-02 12:22
zomertje
Barisax knorretje
Probeer anders ook eens een 2.4 kernel. Wie weet werkt het daar wel beter. Ik heb ook hele rare dingen gezien met Wifi en Ndiswrapper. Het blijft behelpen
het ultieme jaargetijde.... | #!/usr/bin/girl | Art prints and fun
