Hi,
Now we are getting somewhere =)
Msi K8nNeo2 W54g bios 1.51b
1x Athlon64 3500+ 130nm
2x Twinmos Twister 512MB Cas2
1x Asus Radeon x800pro non vivo
2x WD Raptor 740 74GB Raid0 Array
2x Maxtor DiamondMax9 120GB Raid0 Array
1x Maxtor DiamondMax9 200GB Single
1x SoundBlaster Audigy2 ZS
2x LiteOn 1633s Dual layer DVD Writers
1x Tagan480w PSU using grounded cable + walloutlet
NO Floppydrive
Windows2k3 Build 3790 standard corporate; fully critical patched up to 15/12/04
Paging file striped on both Raid0 arrays
Using only the Administrator account
Nvidia forceware Chipset driver 5.10 . Firewall + manager not installed
Omega’s Radeon drivers “wxp-w2k-8-08-041111a-019253e” 4.12b
Creative supplied drivers
Had enough?
Some advanced report info by “everest” utility is attached in a txt file format!
Regards, and thanks in advance; Wouter
Van: euro.tech@amd.com [mailto:euro.tech@amd.com]
Verzonden: Wednesday, December 15, 2004 14:01
Aan: MIJNEMAIL; euro.tech@amd.com
Onderwerp: RE: SRNo:{1-17799911} CPG-ENG-SPT (DO NOT MODIFY THIS)
Dear Wouter,
I am currently investigating the situation.
Can you please provide me with your system configuration? (e.g. Motherboard, Processor, Memory etc...)
Kind regards
Christoph Dobroschke
AMD Technical Services, Europe
Tel +44-1276-803299
Fax +44-1276-803298
Web
http://www.amd.com/eurosupport
Advanced Micro Devices (UK) Ltd
AMD House
Frimley Business Park
Frimley
Surrey
GU16 7SL
United Kingdom
This message contains information which may be confidential and proprietary. Unless you are the addressee (or authorized to receive for the addressee), you may not use, forward, transmit, copy or disclose in any form to anyone the message or any information contained in the message.
-----Original Message-----
Sent: Friday, December 10, 2004 5:52 PM
To: Tech, Euro
Subject: RE: SRNo:{1-17799911} CPG-ENG-SPT (DO NOT MODIFY THIS)
Goodmorning Mr Rosendal,
I really appreciate your help but I am getting the idea that this is not going to work out... I'm really looking forward to using cool n' quiet on my 2003 installation. However, the .NET framework patch did not work. Also I'm having a hard time believing a patch for sharepoint is going to fix this issue. I assume the MsSharepoint patch is only for people running sharepoint.? ( Which I am not ).
So can you please: A: Tell me it is Not possible, or B: Pass this on to someone who knows how to get this working.. Don't get me wrong, you are very customer friendly and have a quick response time but I'm having the idea this is not going to work out... I do sincerily apologise for being so rude but I really want to get this working.
Regards, Wouter
Verzonden: Friday, December 10, 2004 16:56
Aan: MIJN ADRES@zonnet.nl
CC: euro.tech@amd.com
Dear Mr. Wouter
Yes it would be a good idea to try installing the Sharepoint Service Pack as well this should actually solve the issue.
Sincerely,
Mads Rosendal
Technical Support Engineer
Spain: 900 99 71 21 (Número Gratuito)
France: 0800 908 621 (Numéro Vert)
Germany: +49 89 450 53199
Italy: 800 877 224
United Kingdom: +44 1276 803 299
Sent: Friday, December 03, 2004 5:45 PM
To: Tech, Euro
Which one are you talking about ? If I open the link , 2 packs are available:
Microsoft .NET Framework 1.1 Service Pack 1 for Windows Server 2003
and
Windows SharePoint Services Service Pack 1 (SP1)
I installed the 1st one , this didn't resolve the issue. The other one probably requires Sharepoint to be installed. When installing Sharepoint IIS is required.
If you would be so kind as to let me know wheter you are talking about Sharepoint, I will install it as soon as possible.
Regards and thanks for your fast response so far,
Wouter
