INSTRUCTiONS:
Using $ony's CD/DVD Generator v1.50 software rebuild your SECOND SIGHT DVDR image by first
finding and coping to your desktop the CM_DVPAL.PSS file from the disc using Windows Explorer.
This file should be around 800k in size. Next, find and delete the following three files from
the TRAILERS directory: CM_DV.PSS (10.98Mb), SSFIN.PSS (41.20Mb), and SSFINPAL.PSS (42.64Mb).
Now, rename and copy your extracted CM_DVPAL.PSS file (800k) to match each of the three file
names you deleted from the TRAILERS directory and replace the files in the TRAILERS directory.
In summary, this is what you should now have:
CM_DV.PSS (10.98Mb) replaced with renamed CM_DVPAL.PSS (800Kb)
SSFIN.PSS (41.20Mb) replaced with renamed CM_DVPAL.PSS (800Kb)
SSFINPAL.PSS (42.64Mb) replaced with renamed CM_DVPAL.PSS (800Kb)
Once done, begin to drag and drop the files into CD/DVD Gen in the order below when rebuilding,
for example, CDVDSTM.IRX would go in first (LBA should be 1638000) and the last file will be
SYSTEM.CNF in your image.
Finally, under the VOLUME tab for Disc Name use SLES 52670 for PAL. This 'modified' new image
will now work perfectly with Swap Magic v2.0 DVD Disc thanks to AceOSpades of PS2Ownz.com site.
Enjoy!
WWW.SWAPMAGiCFiX.COM
1638000 , \MODULES\CDVDSTM.IRX
1638017 , \MODULES\ICON.SYS
1638018 , \MODULES\IOP.IMG
1638150 , \MODULES\LIBSD.IRX
1638164 , \MODULES\MCMAN.IRX
1638211 , \MODULES\MCSERV.IRX
1638215 , \MODULES\MSIFRPC.IRX
1638219 , \MODULES\MTAPMAN.IRX
1638225 , \MODULES\PADMAN.IRX
1638247 , \MODULES\PFS.IRX
1638272 , \MODULES\SDRDRV.IRX
1638277 , \MODULES\SIO2MAN.IRX
1638281 , \MODULES\SMAP.IRX
1638290 , \MODULES\STREAM.IRX
1638356 , \MODULES\SYS_NET.ICO
1639695 , \PAK\ANIM\GUN\AKSU.PAK
1639713 , \PAK\ANIM\GUN\BATON.PAK
1639718 , \PAK\ANIM\GUN\DARTGUN.PAK
1639729 , \PAK\ANIM\GUN\KNIFE.PAK
1639739 , \PAK\ANIM\GUN\M16.PAK
1639760 , \PAK\ANIM\GUN\MACHINE.PAK
1639767 , \PAK\ANIM\GUN\MAKAROV.PAK
1639781 , \PAK\ANIM\GUN\MISC.PAK
1639815 , \PAK\ANIM\GUN\NSA45.PAK
1639829 , \PAK\ANIM\GUN\NSASMG.PAK
1639841 , \PAK\ANIM\GUN\PISTOL.PAK
1639856 , \PAK\ANIM\GUN\SATURDAY.PAK
1639879 , \PAK\ANIM\GUN\SAWNOFF.PAK
1639915 , \PAK\ANIM\GUN\SHOTGUN.PAK
1639955 , \PAK\ANIM\GUN\SRIFLE.PAK
1639980 , \PAK\ANIM\GUN\WICEDART.PAK
1640153 , \PAK\ANIM\LV52\JVS1_CS.PAK
1640185 , \PAK\ANIM\LV52\JVS2_CS.PAK
1640218 , \PAK\ANIM\LV52\LV52.PAK
1640237 , \PAK\ANIM\LV52\TK2_CS.PAK
1640358 , \PAK\ANIM\LV60\LV60.PAK
1640764 , \PAK\ANIM\LV60\REVISIT.PAK
1640765 , \PAK\ANIM\LV61\LV61.PAK
1640821 , \PAK\ANIM\LV61\LV61HELI.PAK
1641186 , \PAK\ANIM\LV63\CRRC_CS.PAK
1641321 , \PAK\ANIM\LV63\JFBD_CS.PAK
1641528 , \PAK\ANIM\LV63\LV63.PAK
1641594 , \PAK\ANIM\LV63\SE_CS.PAK
1641719 , \PAK\ANIM\LV63\SEJI_CS.PAK
1641735 , \PAK\ANIM\LV66\LV66.PAK
1641803 , \PAK\ANIM\LV66\LV66_CSA.PAK
1641903 , \PAK\ANIM\LV66\LV66_CSC.PAK
1642034 , \PAK\ANIM\LV67\LV67.PAK
1642035 , \PAK\ANIM\LV68\LV68_CS1.PAK
1642212 , \PAK\ANIM\LV68\LV68_CS2.PAK
1642371 , \PAK\ANIM\LV68\LV68_CS3.PAK
1642474 , \PAK\ANIM\LV68\LV68_CS4.PAK
1642564 , \PAK\ANIM\LV68\LV68_CSH.PAK
1642596 , \PAK\ANIM\LV68\LV68_GO.PAK
1642687 , \PAK\ANIM\LV68\LV68_ROA.PAK
1642780 , \PAK\ANIM\LV70\LV70.PAK
1643097 , \PAK\ANIM\LV72\LV72.PAK
1643319 , \PAK\ANIM\LV75\LV75.PAK
1643433 , \PAK\ANIM\LV76\LV76.PAK
1643499 , \PAK\ANIM\LV77\LV77.PAK
1643643 , \PAK\ANIM\LV77\LV77_CCS.PAK
1643917 , \PAK\ANIM\LV77\LV77_KCS.PAK
1644000 , \PAK\ANIM\LV77\LV77_PCS.PAK
1644190 , \PAK\ANIM\LV77\LV77_SCS.PAK
1644329 , \PAK\ANIM\LV77\PRCS.PAK
1644647 , \PAK\ANIM\LV78\LV78.PAK
1644666 , \PAK\ANIM\LV78\LV78_FRE.PAK
1644757 , \PAK\ANIM\LV78\LV78_RAD.PAK
1644827 , \PAK\ANIM\LV78\LV78_RAI.PAK
1644864 , \PAK\ANIM\LV78\LV78_VIS.PAK
1644886 , \PAK\ANIM\LV80\ARCS.PAK
1645165 , \PAK\ANIM\LV80\LV80.PAK
1645173 , \PAK\ANIM\LV80\NRCS.PAK
1645207 , \PAK\ANIM\LV80\PKCS.PAK
1645256 , \PAK\ANIM\LV80\PRCS.PAK
1645343 , \PAK\ANIM\LV81\ATOZ.PAK
1645373 , \PAK\ANIM\LV81\JMHS.PAK
1645474 , \PAK\ANIM\LV81\LIFT.PAK
1645508 , \PAK\ANIM\LV81\LV81.PAK
1645522 , \PAK\ANIM\LV81\MTOZ.PAK
1645631 , \PAK\ANIM\LV81\NTOZ.PAK
1645663 , \PAK\ANIM\LV81\WBCS.PAK
1645676 , \PAK\ANIM\LV81\ZTOA.PAK
1645706 , \PAK\ANIM\LV81\ZTOM.PAK
1645820 , \PAK\ANIM\LV81\ZTON.PAK
1638373 , \PAK\ANIM\ANIMG2.PAK
1639599 , \PAK\ANIM\CHAIR.PAK
1639624 , \PAK\ANIM\GANG.PAK
1639657 , \PAK\ANIM\GORILLAS.PAK
1639994 , \PAK\ANIM\INSECT.PAK
1640000 , \PAK\ANIM\JAYNESAD.PAK
1640023 , \PAK\ANIM\JAYNESEW.PAK
1640078 , \PAK\ANIM\KID.PAK
1640121 , \PAK\ANIM\LOON.PAK
1645850 , \PAK\ANIM\MIP.PAK
1645860 , \PAK\ANIM\NSA.PAK
1645884 , \PAK\ANIM\SKELG2.PAK
1645891 , \PAK\ANIM\WICE.PAK
1645959 , \PAK\ARCADE\L_101.PAK
1647006 , \PAK\ARCADE\L_101M.PAK
1650730 , \PAK\ARCADE\L_103.PAK
1651536 , \PAK\ARCADE\L_103M.PAK
1652404 , \PAK\ARCADE\L_104.PAK
1652444 , \PAK\ARCADE\L_104M.PAK
1655554 , \PAK\CSA\E\A0END.PAK
1656200 , \PAK\CSA\E\A0ENDS.PAK
1658202 , \PAK\CSA\E\A1END.PAK
1659168 , \PAK\CSA\E\A1ENDS.PAK
1660670 , \PAK\CSA\E\A2END.PAK
1661627 , \PAK\CSA\E\A2ENDS.PAK
1663129 , \PAK\CSA\E\A3END.PAK
1663576 , \PAK\CSA\E\A3ENDS.PAK
1664328 , \PAK\CSA\E\A4END.PAK
1664739 , \PAK\CSA\E\A4ENDS.PAK
1667491 , \PAK\CSA\E\A5END.PAK
1667908 , \PAK\CSA\E\A5ENDS.PAK
1671035 , \PAK\CSA\E\A6END.PAK
1671935 , \PAK\CSA\E\A6ENDS.PAK
1674312 , \PAK\CSA\E\A7END.PAK
1676075 , \PAK\CSA\E\A7ENDS.PAK
1677952 , \PAK\CSA\E\A8END.PAK
1679477 , \PAK\CSA\E\A8ENDS.PAK
1681604 , \PAK\CSA\E\A9END.PAK
1682973 , \PAK\CSA\E\A9ENDS.PAK
1692350 , \PAK\CSA\S\A0START.PAK
1693310 , \PAK\CSA\S\A0STARTS.PAK
1695687 , \PAK\CSA\S\A1START.PAK
1696508 , \PAK\CSA\S\A1STARTS.PAK
1697885 , \PAK\CSA\S\A2START.PAK
1698727 , \PAK\CSA\S\A2STARTS.PAK
1700104 , \PAK\CSA\S\A3START.PAK
1700821 , \PAK\CSA\S\A3STARTS.PAK
1701698 , \PAK\CSA\S\A4START.PAK
1702167 , \PAK\CSA\S\A4STARTS.PAK
1704294 , \PAK\CSA\S\A5START.PAK
1705491 , \PAK\CSA\S\A5STARTS.PAK
1708618 , \PAK\CSA\S\A6START.PAK
1709673 , \PAK\CSA\S\A6STARTS.PAK
1711675 , \PAK\CSA\S\A7START.PAK
1712793 , \PAK\CSA\S\A7STARTS.PAK
1717670 , \PAK\CSA\S\A8START.PAK
1718417 , \PAK\CSA\S\A8STARTS.PAK
1720419 , \PAK\CSA\S\A9START.PAK
1720768 , \PAK\CSA\S\A9STARTS.PAK
1721145 , \PAK\CSB\E\B1END.PAK
1724111 , \PAK\CSB\E\B1ENDS.PAK
1733363 , \PAK\CSB\E\B2END.PAK
1734799 , \PAK\CSB\E\B2ENDS.PAK
1737801 , \PAK\CSB\E\B3END.PAK
1738448 , \PAK\CSB\E\B3ENDS.PAK
1740575 , \PAK\CSB\E\B4END.PAK
1742309 , \PAK\CSB\E\B4ENDS.PAK
1744811 , \PAK\CSB\E\B5END.PAK
1745068 , \PAK\CSB\E\B5ENDS.PAK
1745570 , \PAK\CSB\E\B7END.PAK
1747230 , \PAK\CSB\E\B7ENDS.PAK
1751982 , \PAK\CSB\E\B8END.PAK
1752776 , \PAK\CSB\E\B8ENDS.PAK
1754528 , \PAK\CSB\S\B1START.PAK
1754948 , \PAK\CSB\S\B1STARTS.PAK
1757325 , \PAK\CSB\S\B2START.PAK
1759121 , \PAK\CSB\S\B2STARTS.PAK
1764248 , \PAK\CSB\S\B3START.PAK
1764710 , \PAK\CSB\S\B3STARTS.PAK
1767962 , \PAK\CSB\S\B4START.PAK
1769146 , \PAK\CSB\S\B4STARTS.PAK
1771398 , \PAK\CSB\S\B5START.PAK
1772336 , \PAK\CSB\S\B5STARTS.PAK
1777588 , \PAK\CSB\S\B7START.PAK
1779737 , \PAK\CSB\S\B7STARTS.PAK
1783114 , \PAK\CSB\S\B8START.PAK
1785022 , \PAK\CSB\S\B8STARTS.PAK
1788649 , \PAK\CSC\FRONT.PAK
1789238 , \PAK\CSC\FRONTS.PAK
1791990 , \PAK\CSC\OUTRO.PAK
1793862 , \PAK\CSC\OUTROS.PAK
1798864 , \PAK\CSC\TROLLA.PAK
1799214 , \PAK\CSC\TROLLAS.PAK
1800466 , \PAK\CSC\TROLLB.PAK
1801061 , \PAK\CSC\TROLLBS.PAK
1802563 , \PAK\CSC\TROLLC.PAK
1803032 , \PAK\CSC\TROLLCS.PAK
1804159 , \PAK\CSC\TROLLD.PAK
1804891 , \PAK\CSC\TROLLDS.PAK
1807018 , \PAK\CSC\TROLLE.PAK
1807788 , \PAK\CSC\TROLLES.PAK
1810540 , \PAK\MUSICG2.PAK
1978131 , \PAK\OB\81ASYLUM.PAK
1978579 , \PAK\OB\81END.PAK
1979161 , \PAK\OB\81MEDFAC.PAK
1980084 , \PAK\OB\81NSA.PAK
1980407 , \PAK\OB\81START.PAK
1980618 , \PAK\SOUNDSG2.PAK
2088820 , \PAK\STORY\L_52_ST.PAK
2097029 , \PAK\STORY\L_60_ST.PAK
2101002 , \PAK\STORY\L_61_ST.PAK
2106057 , \PAK\STORY\L_62_ST.PAK
2109156 , \PAK\STORY\L_63_ST.PAK
2114404 , \PAK\STORY\L_66_ST.PAK
2121306 , \PAK\STORY\L_67_ST.PAK
2128069 , \PAK\STORY\L_68_ST.PAK
2133692 , \PAK\STORY\L_70_ST.PAK
2139540 , \PAK\STORY\L_71_ST.PAK
2145048 , \PAK\STORY\L_72_ST.PAK
2147393 , \PAK\STORY\L_75_ST.PAK
2152395 , \PAK\STORY\L_76_ST.PAK
2157468 , \PAK\STORY\L_77_ST.PAK
2162369 , \PAK\STORY\L_78_ST.PAK
2165851 , \PAK\STORY\L_80_ST.PAK
2170062 , \PAK\STORY\L_81_ST.PAK
2179424 , \PAK\STORYMEM\L_52_STM.PAK
2182909 , \PAK\STORYMEM\L_60_STM.PAK
2185351 , \PAK\STORYMEM\L_61_STM.PAK
2188078 , \PAK\STORYMEM\L_62_STM.PAK
2191282 , \PAK\STORYMEM\L_63_STM.PAK
2194883 , \PAK\STORYMEM\L_66_STM.PAK
2198246 , \PAK\STORYMEM\L_67_STM.PAK
2201062 , \PAK\STORYMEM\L_68_STM.PAK
2204723 , \PAK\STORYMEM\L_70_STM.PAK
2207779 , \PAK\STORYMEM\L_71_STM.PAK
2211044 , \PAK\STORYMEM\L_72_STM.PAK
2214951 , \PAK\STORYMEM\L_75_STM.PAK
2217750 , \PAK\STORYMEM\L_76_STM.PAK
2221368 , \PAK\STORYMEM\L_77_STM.PAK
2224685 , \PAK\STORYMEM\L_78_STM.PAK
2228260 , \PAK\STORYMEM\L_80_STM.PAK
2231368 , \PAK\STORYMEM\L_81_STM.PAK
2235130 , \PAK\VM\LV52_RAW.PAK
2235139 , \PAK\VM\LV60_RAW.PAK
2235142 , \PAK\VM\LV61_RAW.PAK
2235146 , \PAK\VM\LV62_RAW.PAK
2235149 , \PAK\VM\LV63_RAW.PAK
2235174 , \PAK\VM\LV66_RAW.PAK
2235182 , \PAK\VM\LV67_RAW.PAK
2235218 , \PAK\VM\LV68_RAW.PAK
2235231 , \PAK\VM\LV70_RAW.PAK
2235244 , \PAK\VM\LV71_RAW.PAK
2235250 , \PAK\VM\LV72_RAW.PAK
2235258 , \PAK\VM\LV75_RAW.PAK
2235266 , \PAK\VM\LV76_RAW.PAK
2235269 , \PAK\VM\LV77_RAW.PAK
2235291 , \PAK\VM\LV78_RAW.PAK
2235315 , \PAK\VM\LV80_RAW.PAK
2235327 , \PAK\VM\LV81_RAW.PAK
2235343 , \PAK\VM\SCRS_RAW.PAK
2235344 , \TRAILERS\CM_DV.PSS
2235745 , \TRAILERS\CM_DVPAL.PSS
2236146 , \TRAILERS\SSFIN.PSS
2236547 , \TRAILERS\SSFINPAL.PSS
2236948 , \TRAILERS\STNGC.PSS
2237357 , \TRAILERS\STNGCPAL.PSS
2237766 , \TRAILERS\STNGF.PSS
2238847 , \TRAILERS\STNGFPAL.PSS
2239912 , \SLES_526.70
2242016 , \SYSTEM.CNF
kijk ik moet dit doen en daarvoor heb ik dat Sony cd/dvd creator nodig ik weet namelijk geen ander programma voor dit? vooral niet hoe je dat LBA nummer moet veranderen enzo!
