Heb keuze van case gemaakt namelijk de Coolermaster Centurion Case
Nu nog mobo , zit met deze 2 in mijn gedachten.
Abit :
Processor:
- Supports AMD-K7 Duron™/Athlon™/Athlon™ XP Socket A with 200/266/333MHz FSB Processors
Chipset:
- NVIDIA nForce2 SPP chipset with MCP2-T
- Supports Advanced Configuration and Power Management Interface (ACPI)
- Accelerated Graphics Port connector supports AGP 8X/4X (0.8V/1.5V)
Memory:
- Three 184-pin DIMM sockets
- Supports 3 DIMM DDR 200/266/333 (Max. 3GB)
- Supports 2 DIMM DDR 400 (Max. 2GB)
Serial ATA (Optional):
- On board Serial ATA PCI Controller
- Supports SATA data transfer rates 150MB/s (1.5G bps)
Audio:
- 6-Channel AC 97 CODEC on board
- Professional digital audio interface supports 24-bit S/PDIF Out
- Supports real time AC-3 Encode by Soundstorm™ Technology
System BIOS:
- SoftMenu™ Technology
- Award Plug and Play BIOS
LAN:
- On board 10/100Mb LAN Physical layer interface
- 10/100Mb Operation supports ACPI & Wake on LAN
IEEE 1394:
- Supports IEEE 1394a at 100/200/400MB/s transfer rate
Internal I/O Connectors:
- 1 x AGP8X/4X slot, 5 x PCI slots
- 1 x Floppy Port supports up to 2.88MB
- 2 x Ultra DMA 33/66/100/133 Connectors
- 2 x Serial ATA 150 Connectors
- 2 x USB headers, 2 x IEEE1394a header
- 1 x CD-IN, 1 x IrDA
Back Panel I/O:
- 1 x PS/2 Keyboard, 1 x PS/2 mouse
- 2 x Serial, 1 x Parallel
- 1 x S/PDIF Out port
- Audio connectors (Front Speaker, Line-in, Mic-in, Center/Sub, Surround Speaker)
- 2 x USB, 1 x RJ-45 LAN Connector
Miscellaneous:
- ATX form factor
- Hardware monitoring - Including Fan speeds, Voltages, System environment temperature
OF
Asus :
CPU
AMD Duron/AMD Athlon/AMD AthlonXP 3200+ processors
CPU Socket
Socket A
Chipset
Northbridge: NVIDIA nForce2 Ultra 400
Southbridge: NVIDIA nForce2 MCP-T
Memory
Dual-channel memory architecture
3 x 184-pin DDR DIMM sockets for up to 3GB memory
Supports PC3200/PC2700/PC2100/PC1600 unbuffered non-ECC DDR DIMMs
Expansion slots
5 x PcI
1 x AGP Pro/8X (1.5V only)
1 x ASUS proprietary Wi-Fi slot
Storage
2 x UltraDMA 133/100/66/33
2 x Serial ATA with RAID 0, 1 support
Audio
MCP-T southbridge integrated Audio Processor Unit (APU) + Realtek ALC650 6-channel audio CODEC
LAN
Marvel 88E8001 Gigabit LAN
MCP-T southbridge integrated controller MAC + Realtek 8201BL LAN PHY
Form Factor
ATX form factor: 12 in x 9.6 in (30.5 cm x 24.5 cm)
Support CD contents
Device drivers
ASUS PC Probe
I’m In Touch Remote Access Application
Trend Micro PC-cillin 2002 anti-virus software
ASUS LiveUpdate Utility
IEEE 1394
MCP-T southbridge integrated IEEE1394a controller + Realtek 8801B PHY
Special Features
ASUS Q-Fan Technology
ASUS POST Reporter
ASUS C.O.P (CPU Overheating Protection)
Power Loss Restart
CPU Throttle
Rear Panel I/O Ports
1 x parallel port
1 x serial port
1 x PS/2 keyboard port
1 x PS/2 mouse port
1 x S/PDIF in/out port
1 x surround L/R audio jack
1 x CNTR/LFE audio jack
1 x audio I/O port
1 x Gigabit RJ-45 Port
1 x Fast Ethernet RJ-45 port
4 x USB 2.0 ports
USB 2.0 connector supports additional 2 USB 2.0 ports
Game/MIDI connector
CPU/Power/Chassis fan connectors
2 x IDE connectors
20-pin ATX connector
2 x SATA connectors
2 x 1394 connectors
Chassis intrusion connector
Infrared module connector
CD / AUX / Modem connector
Front panel audio connector
Serial port 2 connector
S/PDIF connector
BIOS Features
4Mb Flash ROM, Award BIOS, PnP, DMI2.0, Green
Industry standard
PCI 2.2, USB 1.1/2.0
Manageability
DMI 2.0, WOL, WOR, Chassis Intrusion
asus komt 91€ en abit 85€
Grtz
Abit :
Processor:
Chipset:
Memory:
Audio:
System BIOS:
LAN:
IEEE 1394:
Back Panel I/O:
Miscellaneous:
- ATX form factor
OF
Asus :
CPU
CPU Socket
Socket A
Chipset
Memory
Expansion slots
5 x PcI
Storage
Audio
LAN
Form Factor
Support CD contents
Device drivers
ASUS PC Probe
IEEE 1394
Special Features
ASUS POST Reporter
Power Loss Restart
CPU Throttle
1 x parallel port
1 x serial port
1 x PS/2 mouse port
1 x audio I/O port
4 x USB 2.0 ports
Game/MIDI connector
2 x IDE connectors
2 x SATA connectors
2 x 1394 connectors
S/PDIF connector
BIOS Features
Industry standard
Manageability
Grtz
