Okee, ik heb begrepen dat er meerdere versies van Linux zijn. Kan iemand uitleggen wat de verschillen tussen de versies zijn?
Bij voorbaat dank.
Bij voorbaat dank.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
| final:
- Fix more loopback deadlocks (Andrea Arcangeli)
- Make Alpha with Nautilus chipset and
Irongate chipset configuration compile
correctly (Michal Jaegermann)
rc2:
- Fix potential oops with via-rhine (Andrew Morton)
- sysvfs: mark inodes as bad in case of read
failure (Christoph Hellwig)
- NTFS bugfixes (Anton Altaparmakov)
- Fix Netfilter oops (Edward Killips)
- Direct IO error handling fix (Masaroni Goto)
- Fix loop device deadlock (Andrea Arcangeli)
- Make some erroneously global spinlocks
static (David C. Hansen)
- Avoid i810 driver from oopsing with 830ME (Robert Love)
- Reiserfs fixes (Oleg Drokin/Chris Mason)
- Fix VM "not-swapping" issue with lowmem
machines (Rik van Riel)
- Make kernel try a bit harder to shrink caches
instead swapping out (me)
- Make NCR5380 compile builtin (Erik Andersen)
- More __devexit_p fixes (Daniel T. Chen)
- devfs bugfixes (Richard Gooch)
rc1:
- Finish MODULE_LICENSE fixups for fs/nls (Mark Hymers)
- Console race fix (Andrew Morton/Robert Love)
- Configure.help update (Eric S. Raymond)
- Correctly fix Direct IO bug (Linus Benedict Torvalds)
- Turn off aacraid debugging (Alan Cox)
- Added missing spinlocking in do_loopback() (Alexander Viro)
- Added missing __devexit_p() in i82092
pcmcia driver (Keith Owens)
- ns83820 zerocopy bugfix (Benjamin LaHaise)
- Fix VM problems where cache/buffers didn't get
freed (me)
pre8:
- ext3 quota fix (Neil Brown)
- Add __devexit_p() to ISDN driver (Kai Germaschewski)
- Declare missing function on fdomain.h (Eyal Lebedinsky)
- Add Sony Vaio PCG-Z600NE to broken APM
reporting blacklist (Kai Germaschewski)
- ns83820 driver update (Benjamin LaHaise)
- pas16 driver cleanup (Alan Cox)
- disable console flush on secondary CPUs on
IA64 (Andrew Morton)
- fix typo on parport's ChangeLog (Tim Waugh)
- fix use count for multiple queued requests on
closed fd (Douglas Gilbert)
- Check return value of get_user() on
set_vesa_blanking (Jeff Garzik)
- Remove asm/segment.h include from nbd (Jeff Garzik)
- Guard sysrq.h against multiple inclusion (Jeff Garzik)
- Minor PCI skeleton changes (Jeff Garzik)
- Add via rhine MMIO to Configure.help (Jeff Garzik)
- Jeff Garzik is not the via82cxxx driver
maintainer anymore: "No time, no hardware". (Jeff Garzik)
- Remove old tulip documentation (Jeff Garzik)
- Avoid direct IO's "misunderstanding" of which
block device it should use (Masanori Goto)
- Remove mcheck_init() call from processor
dependant code and put it in unified codepath (Dave Jones)
- Netfilter bugfixes (Harald Welte)
pre7:
- More USB updates (Greg KH)
- Add missing checks on shmat() (Christoph Rohland)
- ymfpci update (Pete Zaitcev)
- Add aacraid driver (Alan Cox)
- Actually apply some of the Alan's changes
which were on pre6 changelog. (silly me)
- Clean up t128 SCSI driver (Alan Cox)
- Clean up dtc SCSI driver (Alan Cox)
- Undo lcall patch from -pre6 (me)
- More ISDN updates (Kai Germaschewski)
pre6:
- ISDN fixes (Kai Germaschewski)
- Eicon driver updates (Kai Germaschewski)
- Fix multithread coredump deadlock (Manfred Spraul)
- Support /dev/kmem access to vmalloc space (Marc Boucher)
- ext3 fixes/enhancements (Andrew Morton)
- Add IT8172G driver to Config.in/Makefile (Giacomo Catenazzi)
- Create __devexit_p() function and use that on
drivers which need it to make it possible to
use newer binutils (Keith Owens)
- Make PCMCIA compile without PCI support (Paul Mackerras)
- Use copy_user_highpage instead copy_highpage
on COW path. (David S. Miller)
- Cacheline align some more performance
critical spinlocks (Anton Blanchard)
- sonypi driver update (Michael C.B. Ashley/Bob Donnelly)
- direct render for some SiS cards (Torsten Duwe/Alan Cox)
- full handling of the NFSv3 'jukebox' feature (Trond Myklebust)
- NFS performance improvements (Trond Myklebust)
- More parport fixes (Tim Waugh)
- Fix lots of core NCR5380 bugs (Alan Cox)
- NCR5380/PAS driver update (Alan Cox)
- Add aacraid to the SCSI list (Alan Cox)
- fdomain driver fixes (Alan Cox)
pre5:
- 8139too fixes (Andreas Dilger)
- sym53c8xx_2 update (Gerard Roudier)
- loopback deadlock bugfix (Jan Kara)
- Yet another devfs update (Richard Gooch)
- Enable K7 SSE (John Clemens)
- Make grab_cache_page return NULL instead
ERR_PTR: callers expect NULL on failure (Christoph Hellwig)
- Make ide-{disk-floppy} compile without
PROCFS support (Robert Love)
- Another ymfpci update (Pete Zaitcev)
- indent NCR5380.{c,h}, g_NCR5380.{c,h}, plus
NCR5380 fix (Alan Cox)
- SPARC32/64 update (David S. Miller)
- Fix atyfb warnings (David S. Miller)
- Make bootmem init code correctly align
bootmem data (David S. Miller)
- Networking updates (David S. Miller)
- Fix scanning luns > 7 on SCSI-3 devices (Michael Clark)
- Add sparse lun hint for Chaparral G8324
Fibre-SCSI controller (Michael Clark)
- Really apply sg changes (me)
- Parport updates (Tim Waugh)
- ReiserFS updates (Vladimir V. Saveliev)
- Make AGP code scan all kinds of devices:
they are not always video ones (Alan Cox)
- EXPORT_NO_SYMBOLS in floppy.c (Alan Cox)
- Pentium IV Hyperthreading support (Alan Cox)
pre4:
- Added missing tcp_diag.c and tcp_diag.h (me)
pre3:
- Enable ppro errata workaround (Dave Jones)
- Update tmpfs documentation (Christoph Rohland)
- Fritz!PCIv2 ISDN card support (Kai Germaschewski)
- Really apply ymfpci changes (Pete Zaitcev)
- USB update (Greg KH)
- Adds detection of more eepro100 cards (Troy A. Griffitts)
- Make ftruncate64() compliant with SuS (Andrew Morton)
- ATI64 fb driver update (Geert Uytterhoeven)
- Coda fixes (Jan Harkes)
- devfs update (Richard Gooch)
- Fix ad1848 breakage in -pre2 (Alan Cox)
- Network updates (David S. Miller)
- Add cramfs locking (Christoph Hellwig)
- Move locking of page_table_lock on expand_stack
before accessing any vma field (Manfred Spraul)
- Make time monotonous with gettimeofday (Andi Kleen)
- Add MODULE_LICENSE(GPL) to ide-tape.c (Mikael Pettersson)
- Minor cs46xx ioctl fix (Thomas Woller)
pre2:
- Remove userland header from bonding driver (David S. Miller)
- Create a SLAB for page tables on i386 (Christoph Hellwig)
- Unregister devices at shaper unload time (David S. Miller)
- Remove several unused variables from various
places in the kernel (David S. Miller)
- Fix slab code to not blindly trust cc_data():
it may be not valid on some platforms (David S. Miller)
- Fix RTC driver bug (David S. Miller)
- SPARC 32/64 update (David S. Miller)
- W9966 V4L driver update (Jakob Jemi)
- ad1848 driver fixes (Alan Cox/Daniel T. Cobra)
- PCMCIA update (David Hinds)
- Fix PCMCIA problem with multiple PCI busses (Paul Mackerras)
- Correctly free per-process signal struct (Dave McCracken)
- IA64 PAL/signal headers cleanup (Nathan Myers)
- ymfpci driver cleanup (Pete Zaitcev)
- Change NLS "licenses" to be "GPL/BSD" instead
only BSD. (Robert Love)
- Fix serial module use count (Russell King)
- Update sg to 3.1.22 (Douglas Gilbert)
- ieee1394 update (Ben Collins)
- ReiserFS fixes (Nikita Danilov)
- Update ACPI documentantion (Patrick Mochel)
- Smarter atime update (Andrew Morton)
- Correctly mark ext2 sb as dirty and sync it (Andrew Morton)
- IrDA update (Jean Tourrilhes)
- Count locked buffers at
balance_dirty_state(): Helps interactivity under
heavy IO workloads (Andrew Morton)
- ide-scsi locking fix (Christoph Hellwig)
pre1:
- Change USB maintainer (Greg Kroah-Hartman)
- Speeling fix for rd.c (From Ralf Baechle's tree)
- Updated URL for bigphysmem patch in v4l docs (Adrian Bunk)
- Add buggy 440GX to broken pirq blacklist (Arjan Van de Ven)
- Add new entry to Sound blaster ISAPNP list (Arjan Van de Ven)
- Remove crap character from Configure.help (Niels Kristian Bech Jensen)
- Backout erroneous change to lookup_exec_domain (Christoph Hellwig)
- Update osst sound driver to 1.65 (Willem Riede)
- Fix i810 sound driver problems (Andris Pavenis)
- Add AF_LLC define in network headers (Arnaldo Carvalho de Melo)
- block_size cleanup on some SCSI drivers (Erik Andersen)
- Added missing MODULE_LICENSE("GPL") in some (Andreas Krennmair)
modules
- Add ->show_options() to super_ops and
implement NFS method (Alexander Viro)
- Updated i8k driver (Massimo Dal Zoto)
- devfs update (Richard Gooch) |
PSN: Houtvlot
Hoort dit niet in de FAQ?Op donderdag 10 januari 2002 17:06 schreef dinges het volgende:
hier het verschil tussen 2.4.16 en 2.4.17
1 [changelog]
Is dat zo? Ik hoor dat Windows2000/XP stabieler is als Windows 95.Op donderdag 10 januari 2002 19:06 schreef BlueAngelGoT het volgende:
Win95, omdat dat nog het stabielste is
LOL!!!Op donderdag 10 januari 2002 17:06 schreef dinges het volgende:
1 [Een lange changelog]
[zeer flauw]Is Linux legaal te downen of begrijp ik dat verkeerd?
[deze advertentieruimte is te koop]
ik geef gewoon wat hij wil hebbenOp donderdag 10 januari 2002 17:44 schreef ewasx het volgende:
Leuk zo'n changelog, maar dat is absoluut niet wat die kerel wilde hebben en dat weet jij ook. Beetje flauw hoor.
PSN: Houtvlot
