Ik heb een probleem met het upgraden van packages van een Ubuntu 12.04 LTS server en weet niet waar te starten om dit op te lossen.
Heeft iemand tips om dit te troubleshooten?
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
| ~$ sudo apt-get upgrade -y Reading package lists... 0% Reading package lists... 100% Reading package lists... Done Building dependency tree... 0% Building dependency tree... 0% Building dependency tree... 50% Building dependency tree... 50% Building dependency tree... 86% Building dependency tree Reading state information... 0% Reading state information... 2% Reading state information... Done Calculating upgrade... Done The following packages have been kept back: linux-cloud-tools-virtual linux-headers-generic linux-headers-virtual linux-image-extra-virtual linux-image-generic linux-image-virtual linux-virtual 0 upgraded, 0 newly installed, 0 to remove and 7 not upgraded. 6 not fully installed or removed. After this operation, 0 B of additional disk space will be used. Setting up linux-cloud-tools-common (3.13.0-36.63) ... start: Job failed to start invoke-rc.d: initscript hv-kvp-daemon, action "start" failed. dpkg: error processing package linux-cloud-tools-common (--configure): subprocess installed post-installation script returned error exit status 1 dpkg: dependency problems prevent configuration of linux-cloud-tools-3.13.0-34: linux-cloud-tools-3.13.0-34 depends on linux-cloud-tools-common; however: Package linux-cloud-tools-common is not configured yet. dpkg: error processing package linux-cloud-tools-3.13.0-34 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of linux-cloud-tools-3.13.0-34-generic: linux-cloud-tools-3.13.0-34-generic depends on linux-cloud-tools-3.13.0-34; however: Package linux-cloud-tools-3.13.0-34 is not configured yet. dpkg: error processing package linux-cloud-tools-3.13.0-34-generic (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of linux-cloud-tools-virtual: linux-cloud-tools-virtual depends on linux-cloud-tools-3.13.0-34-generic; however: Package linux-cloud-tools-3.13.0-34-generic is not configured yet. dpkg: error processing package linux-cloud-tools-virtual (--configure): dependenNo apport report written because the error message indicates its a followup error from a previous failure. No apport report written because the error message indicates its a followup error from a previous failure. No apport report written because MaxReports is reached already No apport report written because MaxReports is reached already No apport report written because MaxReports is reached already cy problems - leaving unconfigured dpkg: dependency problems prevent configuration of hv-kvp-daemon-init: hv-kvp-daemon-init depends on linux-cloud-tools-virtual | linux-cloud-tools; however: Package linux-cloud-tools-virtual is not configured yet. Package linux-cloud-tools is not installed. Package linux-cloud-tools-virtual which provides linux-cloud-tools is not configured yet. dpkg: error processing package hv-kvp-daemon-init (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of walinuxagent: walinuxagent depends on hv-kvp-daemon-init; however: Package hv-kvp-daemon-init is not configured yet. dpkg: error processing package walinuxagent (--configure): dependency problems - leaving unconfigured Errors were encountered while processing: linux-cloud-tools-common linux-cloud-tools-3.13.0-34 linux-cloud-tools-3.13.0-34-generic linux-cloud-tools-virtual hv-kvp-daemon-init walinuxagent E: Sub-process /usr/bin/dpkg returned an error code (1) |
