Direct3D mip-map filtering
  • TrasherXL
  • Laatst online: 21-11-2025
TrasherXL
Bicky burger for life
Via een d3d9.dll proxy kan ik voor sommige dx9 games de direct3d calls afvangen. Ik wil in de render phase een stukje custom code uitvoeren, en dat lukt ook. Het doel is dat ik de frontbuffer in een texture prop en daar dan de mip-maps van laat genereren door de hardware. Alles lukt, behalve de auto generatie van de mipmap sublevels (tot 1x1 pixel), dat gaat mis. Dwz, de levelcount blijft 1.
M'n kaart support 100% auto-gen mipmap. Iemand een idee?
C++: custom.cpp
29
30
31
32
33
34
35
36
37
38
39
void CustomActions::Screenshot(void)
    IDirect3DSurface9* frontbuf = NULL;
    D3DDISPLAYMODE dMode;
    volatile DWORD levelCount = 0;
    HRESULT res = S_OK;
    //Capture FrontBuffer to a (off-screen) Surface
    m_pDevice->GetDisplayMode(0, &dMode);
    res = m_pDevice->SetSamplerState(0, D3DSAMP_MIPFILTER, D3DTEXF_LINEAR);
    m_pDevice->CreateOffscreenPlainSurface(dMode.Width, dMode.Height, D3DFMT_A8R8G8B8, D3DPOOL_SCRATCH, &frontbuf, NULL); //D3DFMT_A8R8G8B8
    res = m_pDevice->GetFrontBufferData(0,frontbuf);
    if (res != D3D_OK)
      frontbuf->Release();
      return;
    //Save the captured frontbuffer to an in-memory file
    LPD3DXBUFFER buf;
    res = D3DXSaveSurfaceToFileInMemory(&buf, D3DXIFF_DIB, frontbuf, NULL, NULL);
    //Create a Texture from the in-memory file and enable mip-map generation
    IDirect3DTexture9 * pMipMap = NULL;
    D3DXIMAGE_INFO imgInfo;
    res = D3DXCreateTextureFromFileInMemoryEx(m_pDevice, buf->GetBufferPointer(), buf->GetBufferSize(), dMode.Width, dMode.Height, 0 /* do all mipmap levels*/, D3DUSAGE_AUTOGENMIPMAP, D3DFMT_A8R8G8B8, D3DPOOL_MANAGED,
                                         D3DX_FILTER_LINEAR, D3DX_FILTER_LINEAR , 0xFF000000, &imgInfo, NULL, &pMipMap);
    if  (res == D3D_OK) {
        pMipMap->AddDirtyRect(NULL);
        pMipMap->GenerateMipSubLevels(); //this should force mip-map generation
        levelCount = pMipMap->GetLevelCount(); //we would like this to be > 1
        pMipMap->Release();
ASUS Commando | Core2Duo E6600 @ 3Ghz air-cooled | Geforce 8800GTX | Raid-0 | 4 GB DDR2-800
  • .oisyn
  • Laatst online: 22:45
.oisyn
Moderator Devschuur®
Demotivational Speaker
Waarom roep je pMipMap->GenerateMipSubLevels() aan? De D3DXCreateTextureFromFileInMemoryEx() call zou het al moeten doen (aangezien je D3DUSAGE_AUTOGENMIPMAP meegeeft). Als mipmap filter wil je overigens D3DX_FILTER_BOX gebruiken.
.edit: nee wacht, D3DXCreateTextureFromFileInMemoryEx support de usage flag D3DUSAGE_AUTOGENMIPMAP helemaal niet. Wat gebeurt er als je gewoon 0 meegeeft als usage flag?
[ Voor 27% gewijzigd door .oisyn op 06-11-2009 00:20 ]
  • TrasherXL
TrasherXL
Dat maakt geen verschil. De call naar GenerateMipSublevels is expres gedaan om het af te dwingen.
Als ik voor beide calls de normale calls zonder 'Ex' gebruik werkt het wel, maar belachelijk traag.
Het lijkt zelfs of het in software gedaan word, die mipmaps.
