Hoofdcategorieën
Topicacties
[SOL] Probleem installeren ClamAV 0.93.3
Reageer Nieuw Topic
www.vidastudios.nl
Allen,
Ik wil graag clamav installeren op een Sun Solaris machine.
Server:
SunOS sgs-fs1 5.10 Generic_118855-36 i86pc i386 i86pc
Als ik ./configure wil doen krijg ik het volgende:
checking build system type... i386-pc-solaris2.10
checking host system type... i386-pc-solaris2.10
checking target system type... i386-pc-solaris2.10
creating target.h - canonical system defines
checking for a BSD-compatible install... config/install-sh -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... config/install-sh -c -d
checking for gawk... no
checking for mawk... no
checking for nawk... nawk
checking whether make sets $(MAKE)... no
checking for gawk... (cached) nawk
checking whether ln -s works... yes
checking whether make sets $(MAKE)... (cached) no
checking for style of include used by make... none
checking for gcc... gcc
checking for C compiler default output file name...
configure: error: C compiler cannot create executables
See `config.log' for more details.
Nu kijk ik in config.log en dan zien ik onderstaand:
configure:3491: gcc conftest.c >&5
gcc: installation problem, cannot exec `as': No such file or directory
configure:3494: $? = 1
configure:3532: result:
configure: failed program was:
| /* confdefs.h. */
| #define PACKAGE_NAME "clamav"
| #define PACKAGE_TARNAME "clamav"
| #define PACKAGE_VERSION "0.93.3"
| #define PACKAGE_STRING "clamav 0.93.3"
| #define PACKAGE_BUGREPORT "http://bugs.clamav.net/"
| #define PACKAGE PACKAGE_NAME
| #define VERSION "0.93.3"
| /* end confdefs.h. */
| int
| main ()
| return 0;
configure:3539: error: C compiler cannot create executables
MIJN PATH:
/sbin:/usr/sbin:/usr/bin:/usr/sfw/bin:/usr/sfw/sbin:/usr/ccs/bin:/usr/openwin/bin:/usr/dt/bin:/opt/sfw/bin:/opt/sfw/sbin:/usr/local/bin
Wat kan ik hieraan doen? Ik heb me wezenloos gezocht maar niks gevonden wat hielp.
http://www.vidastudios.nl
www.vidastudios.nl
deze pagina had ik inderdaad al gezien maar hielp niet.
which gcc:
/usr/bin/gcc
which cc:
/usr/bin/cc
Enig idee?
www.vidastudios.nl
iemand enig idee?
Officieel ele fan
Reg. datum: 01 juli 2001
as == Gnu Assembler, maar ik vraag me af of clamav niet gewoon met Sun Studio overweg kan, heb je dat al geprobeerd? (eventueel met CC=cc CPP=CC ./configure draaien)
61=jiskefet | 06-15275070
God, root, what is difference? | Dell | Talga Vassternich | IBM zuigt
www.vidastudios.nl
Geeft helaas dezelfde melding.
Ik heb nog een andere identieke server en hier ging het installeren wel goed. Maar aan de pckinfo te zien zijn te packages gelijk.
lastig dit.
VNU Media logo Powered by True
© 1998 - 2008 Tweakers.net - Alle rechten voorbehouden
Uitgever van:
