[par2] Repareren lukt niet meer
  • Jogai
  • Laatst online: 08-07 11:26
Sinds kort heb ik het volgend probleem:
Bij het gebruiken van par2cmdline lukt het niet om iets te repareren. Meestal zijn alle gerepareerde files gewoon weer damaged.
Hier de output na het 1e commando:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
#par2repair filename
par2cmdline version 0.4, Copyright (C) 2003 Peter Brian Clements.
par2cmdline comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to redistribute it and/or modify
it under the terms of the GNU General Public License as published by the
Free Software Foundation; either version 2 of the License, or (at your
option) any later version. See COPYING for details.
Loading "filename.par2".
Loaded 38 new packets
Loading "filename.vol031+30.PAR2".
Loaded 30 new packets including 30 recovery blocks
- onderbroken voor leesbaarheid -
Loading "filename.vol061+57.PAR2".
Loaded 57 new packets including 57 recovery blocks
There are 18 recoverable files and 0 other files.
The block size used was 384000 bytes.
There are a total of 1182 data blocks.
The total size of the data files is 447886597 bytes.
Verifying source files:
Target: "filename.part00.rar" - found.
Target: "filename.part01.rar" - damaged. Found 65 of 66 data blocks.
Target: "filename.part17.rar" - damaged. Found 65 of 66 data blocks.
Target: "filename.part18.rar" - found.
Scanning extra files:
Repair is required.
10 file(s) exist but are damaged.
8 file(s) are ok.
You have 1161 out of 1182 data blocks available.
You have 118 recovery blocks available.
Repair is possible.
You have an excess of 97 recovery blocks.
21 recovery blocks will be used to repair.
Computing Reed Solomon matrix.
Constructing: done.
Solving: done.
Wrote 250000000 bytes to disk
Verifying repaired files:
Target: "filename.part02.rar" - found.
Target: "filename.part15.rar" - damaged. Found 65 of 66 data blocks.
Repair Failed.
systeem:
Linux 2.6.24-sabayon
i686 AMD Athlon(TM) XP 3200+
AuthenticAMD GNU/Linux
Klik hier om op linkedIn lid te worden van de Freelance Tweakers groep.
Heb je het al geprobeerd met QuickPar (neem aan dat dat voor LiNuX ook wel bestaat)?
  • blaataaps
Doe je het als de goede user? Is er genoeg schijfruimte?
  • keesheid
  • Laatst online: 07-07 16:51
Probleem komt mij bekend voor. Ook wel eens gehad. Bij mij was het het geheugen dat niet goed meer was. Na dat te hebben vervangen ging het weer als een trein.
  • Pinjataaa
  • Laatst online: 20:58
Pinjataaa
Hit me!
1 van deze 3 proberen?
PyPar2
gpar2
PAR2GUI
  • jan99999
  • Laatst online: 07:25
Quickpar(windows) in wine installeren, wat zegt deze?
  • CrankyGamerOG
  • Laatst online: 08-07 14:11
CrankyGamerOG
Assumption is the mother.....
Offtopic
De enigste die hier relevante vragen stelt is blaataaps
sorry maar wat is het nou voor tip om een windows programma te gaan gebruiken via wine, om een probleem met een linux based prog op te lossen
Ontopic
Zoals Blaataaps al zegt, user / rechten
en wat zeggen je logfiles, mocht het bijv aan je mem liggen wat zie je bij
dmesg of cat /var/log/messages
KPN - Vodafone Ziggo Partner
  • Jogai
Het is mijn moederboard. Heb t ff op mn windows bak geprobeerd en daar hoef ik niet eens te parren. Dus aan de lijn of newsserver ligt het niet.
@Pinjataaa: volgens mij maken die veelal gebruik van par2cmdline
@Blaataaps: eerst ging het wel en ik had ook genoeg ruimte dus dat kon het niet zijn
@Def!ance: thanx, dmesg was erg handig.
Geheugen is wel goed, maar volgens mij is mijn moederbord kapot..
CrankyGamerOG schreef op woensdag 02 juli 2008 @ 15:55:
Offtopic
sorry maar wat is het nou voor tip om een windows programma te gaan gebruiken ...
Nou, hij heeft het daar uiteindelijk wel mee opgelost dus misschien is jou reply wat kort door de bocht...
  • CrankyGamerOG
CrankyGamerOG
Verwijderd schreef op donderdag 03 juli 2008 @ 10:33:
Nee omdat het oplossen van een unix/linux based probleem handiger en sneller opgelost kan worden door unix/linux te gebruiken als het hoort !
En als linux gebruiker walg ik van de gedachte om windows als diagnostich os te gebruiken omdat windows in mijn boek per definitie fout is.
Niet omdat het niet zou werken oid , maar om het feit dat je bij linux WEL ziet wat je systeem pcies doet !
Jij gaat toch ook niet naar de fietsenmaker als je auto kapot is ?
Jogai schreef op donderdag 03 juli 2008 @ 09:46:
Heb je het gedownloade product opnieuw gedownload ? en toen gekeken ?
Of waren het pcies dezelfde bestanden ?
Tevens ga je erg kort door de bocht om je mobo de schuld te geven, het kan eerder je mem zijn oid.
Wat stond er bijvoorbeeld in je dmesg -- /var/log/messages
[ Voor 41% gewijzigd door CrankyGamerOG op 05-07-2008 11:55 ]
  • Jogai
Ik ben het wel met je eens, maar mn pc gaf al een tijdje wat problemen. Ineens vastlopen bij gebruik firefox en amarok. Aangezien ik een windows laptop heb van het werk had ik wel de mogelijkheid om ff opnieuw te downloaden.
Het geheugen werkt in een andere pc prima, dus ga ik die maar eens optuigen met linux. Momenteel zit daar geen schijf in dus vandaar dat die ongebruikt hier stond.
Ben toch wel aan een nieuwe distro versie toe dus komt niet heel slecht uit.
