Dell Dimension 3000 upgraden
Na het installeren van de game Lost van Ubisoft (uitgekomen 02-08) kreeg ik bij het opstarten van de game de melding dat er een aantal componenten niet aan de eisen voldeden.
Is het de moeite om deze PC te upgraden?
Na een check op de site van Ubisoft kwam er het volgende resultaat:
CPU Speed Minimum: 2.4 GHz You Have: 2.39 GHz PASS
System RAM Minimum: 1 GB You Have: 510.0 MB FAIL: Sorry, your computer does not meet this minimum requirement.
Operating System Minimum: Windows Vista / XP You Have: Microsoft Windows XP Home Edition (Build Service Pack 22600) PASS
Video Card Minimum: 128 MB DirectX 9.0c-compliant, Shader 3.0-enabled video card (ATI Radeon x1300+ / NVIDIA GeForce 6600+)
You Have: NVIDIA(GeForce4 MX 440) FAIL: Sorry, your video card does not meet this minimum requirement. Upgrade to a more powerful video card will make all your applications look better.
Video Card Features - Minimum attributes of your Video Card
Video RAM: Required - 128 MB , You have - 64.0 MB
Video Card 3D Acceleration: Required - Yes , You have - No
Video HW Transform & Lighting: Required - Yes , You have - No
Vertex Shader Ver.: Required - 3.0 , You have - 0.0
Pixel Shader Ver.: Required - 3.0 , You have - 0.0
Video Card Driver Version (DirectX) Your driver version number is: 6.14.10.4396
DirectX Version Minimum: 9.0c You Have: 9.0c PASS
Sound Card Minimum: Yes You Have: SoundMAX Digital Audio PASS
Sound Card Driver Version Your driver version number is: 5.10
Free Disk Space Minimum: 5 GB You Have: 13.2 GB PASS
En het volgende wordt aanbevolen:
CPU Recommended: 3.5 GHz Pentium 4 or Athlon XP 3500+ You Have: Intel(R) Celeron(R) CPU 2.40GHz
CPU Speed Recommended: 3.5 GHz You Have: 2.39 GHz is minimum FAIL: Sorry, your CPU Speed does not meet this recommended requirement.
System RAM Recommended: 2 GB You Have: 510.0 MB FAIL: Sorry, your computer does not meet this recommended requirement.
Operating System Recommended: Windows Vista / XP
Video Card Recommended: 256 MB DirectX 9.0c-compliant, Shader 3.0-enabled video card (ATI Radeon x1300+ / NVIDIA GeForce 6600+)
You Have:NVIDIA(GeForce4 MX 440) FAIL: Sorry, your video card does not meet this recommended requirement. Upgrading to a more powerful video card will make all your applications look better.
Video Card Features - Minimum attributes of your Video Card Video RAM: Required - 256 MB
You have - 64.0 MB
DirectX Version Recommended: 9.0c You Have: 9.0c PASS
Sound Card Recommended: Yes You Have: SoundMAX Digital Audio PASS
Sound Card Driver Version Your driver version number is: 5.10 FYI: Your sound card driver version is provided for your information, but it is not part of this analysis. But proper sound card driver versions are important to the proper operation of your product.
Free Disk Space Recommended: 5 GB You Have: 13.2 GB PASS
DVD Recommended: 4x DVD-ROM You Have: HL-DT-ST DVDRAM GSA-H10A PASS, but the Speed could NOT be analyzed.
Volgens deze test is mijn CPU minimaal.
System RAM zou ge-upgrade kunnen worden naar 2 G zie:
http://www.memorystock.co...ber=null&bbproduct=0TC666
De vraag is nu: Gaan voor het maximum of is 1 Gig ook voldoende.(2 x 512 MB)
Wat de videokaart betreft: aanbevolen wordt NVIDIA GeForce 6600+, maar dit is een PCI-e kaart en die kan volgens mij niet in een gewoon PCI-slot?
Er zijn nog wel gewone PCI kaarten met 256MB met TV-out verkrijgbaar.
De vraag is nu:
Geeft een upgrade van het RAM en de videokaart geen problemen met de CPU, want die is minimaal?
(moet je aan een 3 jaar oude PC nog zoveel vertimmeren?)
Wie geeft me raad?
  • Taarmen
  • Laatst online: 08-07 08:47
Naast dat je in het verkeerde sub-forum een topic heb gestart, mogen deze topics niet meer. Lees de FAQ maar eens goed.
Maar om kort antwoord op je vraag te geven, ram upgraden helpt wel wat maar ga dan gelijk voor 2GB. Kijk wel eerst of dit in je pc past. Een beter idee is om je hele pc te upgraden, moederbord, cpu, werkgeheugen en video kaart. En dan maar hopen dat dit in je dell kast past.
Ik zou een hele nieuwe PC kopen. ;)
Dat past inderdaad niet waarschijnlijk moet je een AGP videokaart hebben.
Sorry voor het verkeerd plaatsen in sub-forum, is dat nog te verhelpen?
En wat mijn videokaart betreft: Er zijn op mijn PC geen AGP mogelijkheden.
Jemowa
  • darkpluisje
  • Laatst online: 04-04 08:52
zou wel in een pci slot kunnen maar dan moet je de achterkant eruit vijlen
  • Annihlator
  • Laatst online: 01-07 18:15
pci-e kaarten kunnen niet in gewone pci-sloten hoor.
Met gewone pci-kaarten kan je helaas niet sterker krijgen als een Fx5800 van Nvidia, das dus niet genoeg. het wordt dus vrijwel automatisch een nieuw moederbord dan en dus ook vaak weer processor, geheugen en de rest.
Mijn specs
  • Fish
Fish
How much is the fish
fish mompeld iets met nieuwe pc of spel terugbrengen
Iperf
