• dupondje
  • Laatst online: 05-06 21:03
dupondje
Powa 2 Tha PPL :)
Mio P360 & P560
Algemeen
Design
Afbeeldingslocatie: http://www.portablegear.nl/media/visuals/nieuws/groot/nav-mio-p360-p560-collage-groot.gif
Specificaties
Hardware
CPUSamsung 2443 - 400Mhz
GPS Chipset20-channel SiRFstarIII
TMCYes (External/Optional)
Memory / ROM512MB to 4GB (Depends on Region)
Memory / RAM64MB
Memory SlotSD/MMC (SD/IO compatible)
Color Display3.5" Anti-glare TFT Touchscreen
Resolution320 x 240
Display OrientationLandscape/Portrait
BatteryLithium-Ion
Battery Capacity1350mAh
Battery Life4.5hrs (With active GPS)
Bluetooth Technology Enkel Bij P560V2.0
Wi-Fi Enkel Bij P560802.11b+g
USBV2.0
MicrophoneYes (Built-in)
SpeakerYes (Built-in)
Earphone Jack2.5mm
Depth17.8mm (0.6")
Width72mm (2.9")
Height115 (4.6")
Weight170g (5.9oz)
Software
Operating SystemWindows Mobile® 6 Classic
Navigation SoftwareVaries by region
Video PlayerYes
Picture ViewerYes
Audio PlayerYes
Microsoft Office MobileYes
CalculatorYes
CalendarYes
Contacts SynchronizationYes
Other Preinstalled SoftwareVaries by region
De Mio P360
Design
Afbeeldingslocatie: http://www.mio.com/images/spec_p360_global.jpg
  1. [ol]1.Power Button[/ol] [ol]2.Map Application Button[/ol] [ol]3.Joystick[/ol] [ol]4.Contacts[/ol] [ol]5.3.5" LCD Touchscreen[/ol] [ol]6.GPS Antenna[/ol] [ol]7.Cold Boot On/Off[/ol] [ol]8.Earphone Jack[/ol] [ol]9.Mini-USB Connector[/ol] [ol]10.Microphone[/ol] [ol]11.Stylus[/ol] [ol]12.Speaker[/ol] [ol]13.SD/MMC Slot[/ol]
Functies
Afbeeldingslocatie: http://www.mio.com/images/f40_gpsantenna.jpg20-channel SiRFstarIII GPS Receiver
The latest SiRFstarIII GPS receiver provides accurate navigation in challenging environments. Whether you're downtown or out in the countryside, trust SiRFstarIII to keep track of where you are.
Afbeeldingslocatie: http://www.mio.com/images/CN_f17_multimedia.jpgRich Multimedia
MP3 player, video player, picture viewer, it's all there to keep you entertained on the go. Never have a dull moment wherever you happen to be.
Afbeeldingslocatie: http://www.mio.com/images/CN_f04_mobile.jpgWindows Mobile® 6
Take advantage of new security, scalability and manageability improvements in addition to Outlook Mobile®, Office Mobile® and other Windows® applications.
Afbeeldingslocatie: http://www.mio.com/images/CN_f07_touchscreen.jpgEasy-to-view Display
The crisp 3.5" LCD color display provides navigation information at a glance, even in dimly lit environments.
Afbeeldingslocatie: http://www.mio.com/images/CN_f28_slimdesign.jpgSlim Design
The slim and light-weight design makes it extremely portable. It's easy to move from car to car, carry in a bag or slip into a pocket.
Afbeeldingslocatie: http://www.mio.com/images/feature_55_sdmmc.jpgExpandable Functionality with SD/MMC Memory Slot
SD/MMC memory card slot for additional map data and multimedia content.
Afbeeldingslocatie: http://www.mio.com/images/CN_f38_accessories.jpgComplete Accessories
All accessories needed for a great experience are in the box. Including mounts, chargers and more.
Meer Informatie
http://www.mio.com/gps-navigation-products-p360-overview.htm
Pricewatch
http://tweakers.net/pricewatch/170729/mio-p360.html
Mio P560
Design
Afbeeldingslocatie: http://www.mio.com/images/spec_p560_global.jpg
  1. [ol]1.Wireless LED Indicator[/ol] [ol]2.Bluetooth LED Indicator[/ol] [ol]3.Power Button[/ol] [ol]4.Map Application Button[/ol] [ol]5.Joystick[/ol] [ol]6.Contacts[/ol] [ol]7.3.5" LCD Touchscreen[/ol] [ol]8.GPS Antenna[/ol] [ol]9.Cold Boot On/Off[/ol] [ol]10.Earphone Jack[/ol] [ol]11.Mini-USB Connector[/ol] [ol]12.Microphone[/ol] [ol]13.Stylus[/ol] [ol]14.Speaker[/ol] [ol]15.SD/MMC Slot[/ol]
Functies
Afbeeldingslocatie: http://www.mio.com/images/CN_f51_wifi.jpgIntegrated Wi-Fi
Browse the web, receive data updates for your applications, access your Outlook® email, and connect to wireless networks with Wi-Fi connectivity.
Afbeeldingslocatie: http://www.mio.com/images/CN_f06_bluetooth.jpgWireless Synchronization with Bluetooth® Technology
Throw your cables and enjoy the freedom of wireless synchronization. Contacts, calendar events, emails, tasks, notes, general files and media can all be transferred with minimum effort by Bluetooth® technology.
Meer Informatie
http://www.mio.com/gps-navigation-products-p560-overview.htm
Pricewatch
http://tweakers.net/pricewatch/170730/mio-p560.html
Ervaringen
Iedereen die een van beide toestellen heeft gekocht, voel u vrij om u ervaring te delen met andere gebruikers.
Opmerkingen
Opmerkingen / Fouten / Aanpassingen die moeten gebeuren, pm me maar :)
  • Ginz
Ginz
Trek Superfly 5 powered
Leuk toestel en hulde voor je startpost!
"It's nice to be important, but it's more important to be nice"
"You like it now, but you'll learn to love it later"
  • FicoF
  • Laatst online: 17-06 10:46
Lijkt mij een zeer nette PDA. De NL website geeft alleen nog geen informatie over deze PDA, ik neem aan dat dat nog komt?
Verder ben ik benieuwd naar wat voor houder er bij zit voor in de auto, of het synchronicheren met outlook direct kan (of moet ik MS Office geinstalleerd hebben?) en is hij NL-talig?
  • alwinus
  • Laatst online: 06-07 15:47
alwinus
Tweaked
Ik heb sinds kort de P560. Hij is gewoon nederlandstalig en er zit een carhouder bij die vrij eenvoudig is maar goed vast zit. Er zit wel een oplader bij voor in de auto en een usb kabel. Helaas geen oplader voor in stopcontact maar gelukkig had ik die nog liggen van een oude smartphone.
Ik heb er nog niet heel veel mee gedaan. Navigatie werkt prima (TomTom 6 en Navigon). Synchroniseren gaat met Outlook, heb ik nog niet gebruikt. Wifi werkt prima evenals BT. Ik ben tot nu toe zeer tevreden.
Hij staat wel op de internationale website van mio. Kan daar vanuit hier niet bij (gelukkig wel op tweakers >:)
  • dupondje
dupondje
Powa 2 Tha PPL :)
Goed om te horen dat GPS perfect werkt :) Want bij de vorige toestellen P350 & P550 leken er veel problemen te zijn om een snelle gps sync te hebben.
  • alwinus
alwinus
Tweaked
de eerste keer kan lang duren. Maar daarna geen enkel probleem meer. Je kan ook een document downloaden met satelliet kalibratie gegevens om de GPS locatie sneller te vinden (3 dagen geldig en moet dan weer vernieuwd worden)
  • FicoF
alwinus schreef op woensdag 20 februari 2008 @ 09:11:
Tnx. Dus deze PDA+tomtom6+SD kaart (€450,-) en je hebt een compleet systeem.. :9
edit: Iemand ook ervaring met MioMaps Europe hierop geinstallleerd? Zoals deze aanbieding? Is veel goedkoper maar heb geen ervaring daarmee.
[ Voor 17% gewijzigd door FicoF op 20-02-2008 19:12 ]
  • alwinus
alwinus
Tweaked
MioMaps schijnt ook goed te werken. Ik denk niet dat het onder doet voor TomTom maar heb het zelf nog niet geprobeerd.
  • FicoF
Toch maar gekozen voor de TT6. Ik heb hem besteld, als i khem binnen heb kan ik misschien enkele nuttige aanvullingen geven in dit topic.
  • ArieR
  • Laatst online: 18:36
Mijn ouders zijn sinds kort ook eigenaar van de P360. Ze draaien nu iGo als navigatie wat overigens ook perfect werkt om te navigeren, ze draaien dit echter niet zonder reden. TomTom 6.0 draait echt voor geen meter, installeren gaat prima tot ik mijn woonplaats moet invullen. Dan is het ineens zo traag als....jullie weten wel! ;)
Eerst dacht ik dat het aan het kaartje lag, er zit een 4GB Apacer SDHC kaart in maar het wisselen met een 1GB (regulier) SD-kaartje bleef dit euvel. Ik heb inmiddels menig fora afgespeurd maar niets kunnen vinden, alleen of bepaalde grootte van kaartjes werkten.
Op de TomTom site staat dat dit model ook nog niet compatibel is met dit model Mio, maar het vreemde is dat er al veel mensen zijn die het als een zonnetje hebben draaien.
Link naar TomTom site.
  • dupondje
dupondje
Powa 2 Tha PPL :)
Zojuist een P560 besteld :) Morgen normaal in de brievenbus :) Laat ons hopen dat we met dit speelgoedje veel plezier beleven
  • dupondje
dupondje
Powa 2 Tha PPL :)
Ik heb zojuist tomtom installed, alles werkt, maar tomtom blijkt geen GPS signaal te krijgen ... Enig id ? Welke instellingen gebruiken jullie ?
  • rick77
  • Laatst online: 06-07 20:06
rick77
... get to the point!
Iemand info over de batterijduur van de P560 (of P360)? Ben m.n. geinteresseerd hoe dit zich verhoudt tot de Asus A696 (of A639/A686), die bekend staat om z'n lange batterijduur.
  • renechaos
  • Laatst online: 29-04 09:53
Ik heb de Mio p560 met TT6, instellingen die ik gebruik:
- type gps-ontvanger: Andere NMEA GPS-ontvanger
- baudrate: 57600
- GPS_COM
en werkt prima meestal binnen 20 sec een sateliet sync
qua batterij gaat het ook prima, nu (na twee weken in bezit en dagelijks gebruik) houdt de batterij het ruim 4 uur uit (daarna toch maar de oplader erin geprikt, ondanks dat het batterij icoontje nog niet begon te zeuren).
  • dupondje
dupondje
Powa 2 Tha PPL :)
GPS werkt nu perfect, Alleen binnenshuis doet hij het niet of toch zeker niet snel.
Batterij ben ik ook zeker tevreden over :)
  • alwinus
alwinus
Tweaked
Het duurt nog vrij lang voordaat de pda begint te zeuren om opladen als de batterij indicator op 1 streepje staat.
Binnenhuis gps werkt idd niet best. Maar dat is nogal logisch, geen enkel gps apparaat werkt binnenshuis goed. Lijkt gedeeltelijk ook wel programma afhankelijk. IGo heeft binnen sneller satellieten gevonden dan TT6. Hoe dat komt weet ik niet.... :P
  • ArieR
Heb mijn TT6 ook eindelijk aan de gang. Geen thuisadres selecteren, snel een GPS-ontvanger selecteren waarna ik in het hoofdmenu kwam en het nu als een raket loopt. Uit mijn hoofd gebruik ik volgens mijn een baudrate van 4800. Maar dat moet ik voor de zekerheid even checken.
Maar finally TT werkt en kan dat iGo (wat ook goed werkte) eraf knikkeren. De rede daarvoor is dat TomTom de rij richting laat zien als hij navigeert en iGo laat het zien zoals de wegen in Nederland liggen. Als jullie begrijpen wat ik bedoel! :)
  • Gekkehuus
  • Laatst online: 08-07 12:45
Heb sinds vorige week ook een P560, mijn P550 hebben ze 2 weken geleden gestolen.
Weet iemand of het scherm te 'calibreren' is, want bij het intoetsen van de letters op het virtuele toetsenbord slaat hij te vaak de letter boven de aangetoetste letter aan. Ook scrollen van het beeld moet ik helemaal in de rand van het beeldscherm, ipv de balk die je normaal aan de rand ziet.
Hebben meer mensen dit probleem (gehad) en is er iets aan te doen, of wordt dit een gevalletje van RMA?
  • dupondje
dupondje
Powa 2 Tha PPL :)
Gekkehuus schreef op woensdag 19 maart 2008 @ 15:28:
Eerste keer dat je hem aansteekt moet je normaal calibreren,
Anders een Instellingen -> Scherm -> Scherm uitl.
  • Gekkehuus
Dank je, had geen tijd gehad om de handleiding te lezen. Beetje luiheid van mijn kant.
Ik merk dat mijn tomtom niet geheel 'vloeiend' loopt. Heeft dit te maken met de snelheid van de geheugenkaart of is er iets anders aan de hand?
  • renechaos
Gekkehuus schreef op vrijdag 21 maart 2008 @ 23:39:
Wat bedoel je met 'vloeiend'? ik heb TT6 op een 'gewone' 1GB sd kaart gedraaid, op een ultra-2 1GB sd kaart en nu op mijn 8GB sdhc (class6) kaart, maar ik merk geen verschil.
Iemand trouwens enig idee waar dat miomenu vandaan komt?
het is te zien hier bovenaan de post in de P360.
Ik heb het niet op mijn P560 en vraag me af of dit een losse applicatie is of iets wat met de pda mee zou moeten komen.
  • FicoF
Ik heb mijn MIO nu ruim een maand. Hij bevalt erg goed, ik gebruik het met name voor navigatie (tomtom) en dat is duidelijk en een heldere stem.
Wat ik wel jammer vind is dat je tijdens het tomtommen niet even terug naar WMobile kan gaan, om bijvoorbeeld even een notitie toe te voegen.
Verder een prima apparaat. Kan er eigenlijk niets meer over verklappen, hij doet het gewoon. :+
  • dupondje
dupondje
Powa 2 Tha PPL :)
FicoF schreef op vrijdag 11 april 2008 @ 19:39:
Kan je wel, klik eens op die onderste knoppen :)
  • grep
  • Laatst online: 09-07 17:24
grep
meer begrep...
Heb een P360 recentelijk aangeschaft. Nu wordt, zover ik kan zien, in de manual de 'Flash Disk' totaal niet besproken en aangezien ik geen ervaring heb met zo'n flash disk (had hiervoor een Mio 168) vraag ik me af hoe je die ruimte het beste kan gebruiken?
Ik dacht namelijk dat zo'n flash disk ruimte verloren ging bij een harde reset, maar ik heb dit nu getest en ik zie software, die ik op de flash disk gezet heb, gewoon terug na een harde reset.
Moet ik die Flash disk dus gewoon als een soort snelle storage card zien? En gaat dat ten koste van het werkgeheugen?
  • dupondje
dupondje
Powa 2 Tha PPL :)
grep schreef op zondag 04 mei 2008 @ 11:35:
Die "Flash Disk" is gewoon ingebouwde ruimte ... gewoon gebruiken voor je programma's op te installeren.
  • dupondje
dupondje
Powa 2 Tha PPL :)
Iemand die een TMC antenne heeft voor dit toestel?
Blijkbaar is het een beschikbaar accessoire voor dit toestel, maar kan het in geen enkele winkel vinden.
Ik heb TT6.0 op mijn Mio P560 geinstalleerd, maar als ik TT6 opstart, krijg ik het opstartscherm, waarna de P560 weer terug gaat naar het MIO menu. Heb ik de verkeerde versie t.o.v. Windows Mobiel 6? :'(
  • grep
grep
meer begrep...
Ik had al een paar keer gemerkt dat het scherm van mijn P360 aan stond terwijl ik hem al uren niet gebruikt had.
Maar nu laatst had ik hem op m'n bureau liggen en ik zie in mijn ooghoek het scherm opeens oplichten !?!
Sindsdien er een beetje op gelet en het is al meerdere keren gebeurd. Ding ligt gewoon stil op het bureau en licht opeens op.
Omdat ik de PDA nogal es in een binnenzak heb zitten, heb ik (bij de energie instellingen zit dat geloof ik) wakeup disabled voor alle hardware buttons, evenals de SD card en touch screen. Enige manier waarop ik bewust de PDA uit slaapstand kan laten komen is door de power button bovenop in te drukken. Dit meerdere malen getest.
Iemand enig idee waarom de P360 opeens kan besluiten uit z'n slaapstand te komen, zonder dat hij aangeraakt wordt?
[ Voor 3% gewijzigd door grep op 02-07-2008 15:43 ]
  • FlipFluitketel
  • Laatst online: 09-07 20:06
FlipFluitketel
Frontpage Admin
grep schreef op woensdag 02 juli 2008 @ 15:42:
Dit heb ik dus ook met mijn P560. :/
Dacht al dat het aan mij lag maar blijkbaar zijn er dus nog mensen die dit merken. Laatste 2 keer dat ik het gemerkt heb was beide keren om middernacht.
There are only 10 types of people in the world...those who understand binary and those who don't.
Jeremy Clarkson: It’s, um, a mobile phone holder, or as Richard Hammond calls it, a seat!
  • dupondje
dupondje
Powa 2 Tha PPL :)
Active Sync durft wel es PDA uit slaapstand te halen ...
Ik ben aan het overwegen deze pda aan te schaffen. Ik ben aan het twijfelen tussen de Asus MyPal A696 en de Mio P560 GPS.
Op zich heeft de Mio mijn voorkeur, zeker als ik alle slechte ervaringen van tweakers lees met de Asus. Het enige wat mij niet zint aan de Mio is dat de accu van de Mio niet vervangbaar is (volgens PDAshop).
Klopt het dat de accu niet te vervangen is?
Als die wel te vervangen is, waar zijn ze dan te krijgen?
Alvast bedankt
  • FlipFluitketel
FlipFluitketel
Frontpage Admin
Er zit inderdaad geen klepje wat je kunt openen om simpel de accu eruit te halen. Het kan best zijn dat het wel mogelijk is als je de pda compleet uit elkaar haalt maar dat durf ik dus ook niet zeker te zeggen (misschien dat er iemand anders is die dit al eens geprobeerd heeft :P).
hmm jammer, dat doet me toch weer erg twijfelen :S. De accu blijft toch altijd een zwak onderdeel. Voor een apparaat van +/- €300,- vind ik het nogal lomp dat een zo slijtage gevoelig onderdeel niet (makkelijk) te vervangen is :(. Bovendien is het altijd handig om een reserve accu bij te hebben.
In ieder geval bedankt voor de snelle reactie!
  • grep
grep
meer begrep...
dupondje schreef op vrijdag 04 juli 2008 @ 09:48:
heb het nog een tijdje getest en er steeds voor gezord dat er geen enkel programma op de pda actief was (dus ook geen activesysnc).
Het blijft gebeuren.
Viel me wel op dat het om 12:00 en 00:00 uur standaard lijkt te gebeuren, maar zag het ook nu net om 18:18 gebeuren :?
  • tvhouwel
  • Laatst online: 21-05-2025
Een vriend van mij wil de Mio P560 kopen en wil hem vrijwel alleen gaan gebruiken voor Geocachen.
Wie weet te vertellen of de ingebouwde GPS ontvanger "Static NAvigation" aan heeft staan?
Dit is het fenomeen dat de gps ontvanger geen gegevens meer doorgeeft als de snelheid lager is dan 3 km per uur. Voor autonavigatie ideaal, maar voor Geocachen een ramp.
Ik heb al de PDA-shop gebeld, maar die wisten het niet. Ik kreeg het tlf nummer van Mio in Belgie, die
gebeld, maar ook die medewerker wist het niet. :N
Hij adviseerde het in de winkel uit te proberen.
Maar ja, dan moet je daaar Ozi-explorer of zo gaan installeren, dat ik ook al zo wat.
Iemand die uitsluitsel kan geven?
  • rijsbol
  • Laatst online: 07-12-2021
Heeft iemand ervaringen een warmte werende vooruit en de duur van een gps fix?
  • tvhouwel
Ik had de vraag betreffende static navigation ook gesteld aan de support afdeling van Mio.
Vanochtend kreeg ik antwoord.
Bedankt voor uw reactie.
De Mio P360/560 werken inderdaad met static navigation, welke u niet kunt uitzetten.
Static navigation is gedeelte van de navigatie chip en zonder dit is er geen of geen accurate GPS fiks mogelijk.
Beter en volledige uitleg vindt u hier http://www.etenblog.com/2007/11/20/static-navigation-explained/
Geocach is werkt alleen als u Static navigation uit zet dit kan leiden tot beschadiging van de navigatie chip en wordt dus niet door ons ondersteund.
Schade veroorzaakt door verkeerd gebruik valt ook niet onder garantie.
Hopend u voldoende te hebben geïnformeerd.
Wij danken u voor de genomen moeite om contact met ons op te nemen.
Jammer voor het Geocachen, maar we weten in ieder geval nu, hoe of wat.
  • t0tum
  • Laatst online: 25-11-2023
renechaos schreef op dinsdag 25 maart 2008 @ 08:19:
Ik vraag me dit ook af.
Iemand?
  • grep
grep
meer begrep...
Ik heb een P360 maar daar zit het ook niet bij/op. Heb de bijgeleverde cd's er ook nog even op na gespeurd.
Ik ben op zoek naar een goede vervanger voor mijn oude krijger, de Garmin Ique 3600, die
ondertussen hopeloos verouderd is (zelfs niet meer mogelijk om nieuwe kaarten aan te kopen
gezien model niet meer ondersteunt wordt)
Ik ben vertegenwoordiger van beroep en bezoek gemiddeld 2 dagen per week nieuwe prospecten en
bestaande klanten doorheen alle uithoeken van Nl.
Grote voordeel van de Ique 3600 is dat ik vanuit mijn contacten (= al mijn klanten met hun
volledige adres, telefoonnr e.d. die ik relatief makelijk via een Exellijst heb knn inporten)
simpelweg telkens een nieuwe route kan starten, gewoon door de klant te selecteren en de
straatnaam, stad en nr worden automatisch geëxtrapoleerd en route wordt berekend. Bespaart me
veel moeite want ik hoef niet telkens adres volledig in te toetsen.
=> Kan dit ook op de zelfde manier bij de 560?
Ik heb ook gemerkt dat andere GPS-toestellen, in tegenstelling tot huidig toestel, niet
toelaten om te scrollen op de kaart, wat vaak erg handig is.
=> Kunnen jullie mij zeggen of dit ook mogelijk is met de 560?
Is het mogelijk om in combinatie met Navigator 6 de Mio ook te gebruiken als handsfree?
Zo ja, verloopt kan dit ook verlopen via de luidsprekers van de auto, zoals op de TomTom 730
mogelijk is?
Kan je tijdens rijden/navigeren ook Mp3's afspelen?
Tot slot nog 1 vraagje: wat met Traffic Control?
Ik heb bij de spec op pdashop.nl gezien dat de TMC-ontvanger optioneel is.
Kan je RDS-TMC-ontvanger van TomTom gebruikenaansluiten?
Alvast bedankt voor jullie reactie
Groeten
Sophie
  • renechaos
t0tum schreef op donderdag 31 juli 2008 @ 10:24:
Iemand?
Ik weet het nog niet, maar inmiddels gebruik ik touchcommander. Werkt ook prima.
Oh ja dat je P560 zo nu en dan aan gaat, heeft waarschijnlijk te maken met afspraken in je agenda, het automatisch ophalen van je mail, en meer outlook ongein.
Bij mij ging hij elke 20 minuten aan en zodra ik aan een afspraak herinnerd moest worden.
Bleek dat voor een van mijn email profielen aanstond dat hij mail moest checken.
