Vista driver voor Promise TX2200/TX2300
  • WiseGuy_NL
  • Laatst online: 14-04 07:29
Voor iedereen die geinteresseerd is,
Ik ben in het bezit van de Beta vista driver voor de Promise TX2300. Deze is alleen verkrijgbaar door naar de amerikaanse Promise supportlijn te bellen en een verklaring te ondertekenen en terug te sturen.
Dat heb ik vandaag dus allemaal gedaan met onderstaande driver als gevolg:
http://people.zeelandnet....ta%20DTM%202.06.0.324.zip
Dit is de Readme die in de ZIP-file zit:
* FastTrak TX2200/TX2300 Series Driver Diskette *
Contents on the disk
README TXT This readme file
FTTXR52P Microsoft Windows miniport disk label file
TXTSETUP OEM Microsoft Windows miniport text mode setup file
FTTXR52P SYS Microsoft Windows miniport driver
FTTXR52P INF Microsoft Windows miniport setup file
Software Version
Microsoft Windows miniport driver 2.06.0.324
Dit moest ik ondertekenen:
Supplier is providing this Beta version Product to Customer without charge and at Customer’s specific request. Customer understands and acknowledges that this Beta version Product has not been fully tested by Supplier. This Product is provided to Customer “as is” and with Customer assuming all risk of use of the Product.
Except where prohibited by law, Supplier DISCLAIMS any and all warranties, express or implied, by statute or otherwise, regarding the Products including, without limitation, any warranties for fitness for any purpose, quality, merchantability, non-infringement, or otherwise, and any warranties arising out of a course of dealing, trade usage, or trade practice. Supplier makes no warranty or representation concerning the suitability of any Product for use with any other item. Customer assumes full responsibility for selecting Products and for ensuring that the Products selected are compatible and appropriate for use with other goods with which they will be used. Customer assumes and accepts all risk associated with procuring and using a Beta version product.
Supplier DOES NOT WARRANT that this Product is free from errors or that it will interface without any problems with purchaser’s components or computer system. It is the responsibility of the purchaser or end-user to back up its computer or otherwise save important data before installing any Product and to continue to back-up its important data regularly.
Supplier shall not be liable for the cost of procuring substitute goods or services, lost profits, unrealized savings, equipment damage, or for any other general, special, consequential, indirect, incidental, or punitive damages, whether in contract, tort, or otherwise, notwithstanding the failure of the essential purpose of the foregoing remedy and notwithstanding that Supplier has been advised of the possibility of such damages.
Date___________ Signed ___________________
I stuck my head out of the window and got arrested for mooning
  • Raggie3
  • Laatst online: 08-07 15:20
Heb je toevallig ook enig idee of er een driver is voor de Promise TX2300 voor Windows Vista (Ultimate) 64bit?
  • Dukey
  • Laatst online: 24-05 12:14
Dukey
Ik heb dit getypt hier -->
Sorry, maar wat een flauwekul...
Ik heb een Promise TX2300 en een E8350, werken allebei netjes met de laatse nieuwe drivers die te vinden zijn op de Promise website. WebPAM werkt ook netjes.
Ook wel de allergrootste _ _ _ _ _ (vul in met blokletters)
  • Raggie3
is dat dan vista 32bit of 64bit? Dat het onder 32bit gewoon goed werkt lijkt me ook wel namelijk :)
  • Dukey
Dukey
Raggie3 schreef op zondag 11 maart 2007 @ 16:54:
Ik draai 32bit. Kan niet zien dat de boven genoemde driver speciaal voor 64bit is. Mocht er wel een XP 64bit driver zijn dan zou ik die iig proberen.
  • mo3lla
  • Laatst online: 28-06 20:02
te gek! nu kan ik wel Vista naast 2003 zetten in dualboot! Met de embedded driver van Vista was het niet mogelijk de vrije ruimte op mijn RAID 0 als installatie schijf te kiezen, kreef de foutmelding: windows is unable to find a system volume that meets its criteria.
bedankt!
  • mo3lla
Dukey schreef op zondag 11 maart 2007 @ 10:35:
Waar dan? Op deze pagina komt het woord Vista niet eens voor.... plus het feit dat er nog geen enkele Windows driver is uitgebracht in 2007
http://www.promise.com/su...D=136&category=all&os=100
Bij mij doen de gewone drivers het gewoon goed onder vista ultimate...
  • Dukey
Dukey
mo3lla schreef op maandag 09 april 2007 @ 12:34:
Dat bedoel ik ook met mijn opmerking dat het met de laatste (XP) drivers gewoon werkt...even door denken he.
Verwijderd schreef op maandag 09 april 2007 @ 13:54:
Rickmeister bevestigt.
[ Voor 18% gewijzigd door Dukey op 09-04-2007 19:32 ]
