[Ubuntu] Wireless lukt niet
  • 3.975 views sinds 30-01-2008
  • TheGuest
  • Laatst online: 29-01-2024
TheGuest
De enige echte
Heyho mensen,
Ik ben eens linux gaan proberen en ben begonnen met Ubuntu. Waar ik nu tegen aanloop is dat ik mijn draadloos netwerk niet op kom, onder Windows lukt dit wel.
Zie hier mijn gepruts:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
richard@Laptopje:~$ dmesg | grep ipw
[4294702.081000] ipw2100: Intel(R) PRO/Wireless 2100 Network Driver, 1.1.2
[4294702.081000] ipw2100: Copyright(c) 2003-2005 Intel Corporation
[4294702.085000] ipw2100: Detected Intel PRO/Wireless 2100 Network Connection
richard@Laptopje:~$ ifconfig
eth0      Link encap:Ethernet  HWaddr 00:04:23:4E:F7:89
          inet6 addr: fe80::204:23ff:fe4e:f789/64 Scope:Link
          UP BROADCAST MULTICAST DYNAMIC  MTU:1500  Metric:1
          RX packets:301 errors:3156 dropped:3106 overruns:0 frame:0
          TX packets:158 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:19047 (18.6 KiB)  TX bytes:47564 (46.4 KiB)
          Interrupt:10 Base address:0xa000 Memory:e8100000-e8100fff
eth1      Link encap:Ethernet  HWaddr 00:40:CA:C0:83:0B
          inet addr:192.168.1.105  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::240:caff:fec0:830b/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:15929 errors:0 dropped:0 overruns:0 frame:0
          TX packets:15876 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:6997901 (6.6 MiB)  TX bytes:1853600 (1.7 MiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:34209 errors:0 dropped:0 overruns:0 frame:0
          TX packets:34209 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:3120983 (2.9 MiB)  TX bytes:3120983 (2.9 MiB)
richard@Laptopje:~$ iwconfig
lo        no wireless extensions.
eth1      no wireless extensions.
eth0      unassociated  ESSID:"Draadloosheid!"  Nickname:"DiepeZucht"
          Mode:Managed  Frequency=2.462 GHz  Access Point: 00:00:00:00:00:00
          Bit Rate=0 kb/s   Tx-Power:off
          Retry min limit:7   RTS thr:off   Fragment thr:off
          Power Management:off
          Link Quality:0  Signal level:0  Noise level:0
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:51   Missed beacon:0
sit0      no wireless extensions.
richard@Laptopje:~$ sudo dhclient eth0
There is already a pid file /var/run/dhclient.pid with pid 0
Internet Systems Consortium DHCP Client V3.0.2
Copyright 2004 Internet Systems Consortium.
All rights reserved.
For info, please visit http://www.isc.org/products/DHCP
sit0: unknown hardware address type 776
Listening on LPF/eth0/00:04:23:4e:f7:89
Sending on   LPF/eth0/00:04:23:4e:f7:89
Sending on   Socket/fallback
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 8
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 14
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 10
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 18
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
Verder is mijn draadloos netwerk als volgt ingesteld op mijn Linksys WRT54G router:
1) ESSID wordt niet uitgezonden
2) WEP encryptie.
3) DHCP staat aan.
Dat klinkt niet goed en daarom krijg ik geen IP van mijn router toegewezen, dus heb ik dat gezocht op google maar nergens vind ik waar dit precies aan ligt.
Ik hoop dat jullie mij hier mee kunnen helpen.
  • viper
  • Registratie: Augustus 1999
  • Laatst online: 28-08 20:54
Misschien moet je ff je wep-key invullen (iwconfig eth0 key <<key>>)
  • smokalot
  • Laatst online: 15-01 22:00
smokalot
titel onder
ik vind die sit0 regel een stuk beter klinken dan "eth0 unassociated " uit je iwconfig. Hoe wil jij DHCP gebruiken zonder link naar je AP? Ik denk dat je idd je WEP key vergeten bent...
(overigens heeft ubuntu tegenwoordig een prima GUI voor wireless/bedrade netwerken toch?)
It sounds like it could be either bad hardware or software
  • TheGuest
TheGuest
De enige echte
Wepkey had ik al ingevuld, daarnet nogmaals gedaan (wepkey copy paste ik direct vanuit mijn router dus dat kan niet fout zijn) maar nog steeds hetzelfde resultaat.
Met die GUI duurt het soms een eeuw voor dat hij mijn instellingen bewaart en de interfaces activeert, nee geef mij maar de GUI-loze manier. :Y)
Ik zie bij de output van iwconfig het volgende staan:
Tx-Power:off
Moet deze niet ingeschakeld staan? Nu lijkt het of de transmission power is uitgeschakeld.
  • TheGuest
TheGuest
De enige echte
Ik heb denk ik het probleem gevonden.
Als ik de wepbeveiliging uitzet, dan werkt het wel. Verder spitten blijkt dat ik een nieuwe driver moet installeren (http://ipw2100.sourceforge.net) omdat de driver die ik nu heb kennelijk een niet helemaal lekker met wep omgaat.
Geen idee hoe dat installeren gaat, moet ik me ff in gaan verdiepen en kijken of dat daadwerkelijk het probleem verhelpt.
  • Borromini
Borromini
Mislukt misantroop
Het zou me verbazen mocht Ubuntu een driver leveren die niet deftig werkt... De drivers voor de Intel wireless NICs behoren tot de beste die je onder linux kan krijgen (op sommige vlakken zijn ze zelfs beter dan de windows-drivers :P).
Edit: je hebt gelijk, recentste versie is 1.2.1... Verbaast me een beetje dat Ubuntu zo'n oude versie meelevert. Welke Ubuntu-release draai je?
Wat je waarschijnlijk moet (ook) doen is de firmware installeren in /lib/firmware. Rebooten, en opnieuw proberen te configureren. Afgaande op het feit dat je een open netwerk al aan de praat krijgt, zou dat niet meer nodig zijn normaal gezien.
[ Voor 27% gewijzigd door Borromini op 09-05-2006 00:25 ]
  • TheGuest
TheGuest
De enige echte
Ik draai versie 5.10
  • TheGuest
TheGuest
De enige echte
Ik heb mijn wireless drivers geüpdate na veel gepruts maar nog steeds geen succes... ik ben nu op het punt aangekomen dat ik niet meer weet wat ik nog meer kan doen...
  • Borromini
Borromini
Mislukt misantroop
Als het netwerk onbeveiligd werkt dan wil het zeggen dat je iets mis doet tijdens de configuratie... Ik zou de stappen tussen beveiligd en onbeveiligd nog es goed nagaan.
  • TheGuest
TheGuest
De enige echte
iwconfig eth0 mode Managed
iwconfig eth0 essid MijnDraadloosNetwerkje
iwconfig eth0 key <copy past vanuit router>
dhclient eth0
Ik weet niet wat ik verkeerd doe en de stappen zijn voor mij duidelijk en zeer logisch.
Mijn router transmit de 2e key, in Windows kan je dit ook aangeven maar in Ubuntu mis ik dat. Misschien dat het daarom fout gaat? Zo ja hoe kan ik dan in Ubuntu instellen?
Oja ik ben dus wel zo slim om de 2e key te copy-pasten in Ubuntu :P
TheGuest schreef op donderdag 11 mei 2006 @ 20:12:
dhclient eth0
Ik activeer mijn wlankaart op deze manier (rt2500 chip). Meerdere keys kan je ook gebruiken zie de manpage van iwconfig. X-en vervangen door webkey ;)
iwconfig eth0 key restricted XXXXXXXXXXXXXXXXXXXXXXXXXX
iwconfig eth0 essid WLAN
ifconfig eth0 up
dhclient eth0
En nogmaals: Ik zie bij de output van iwconfig het volgende staan:
Tx-Power:off
Uit de manpage van iwconfig:
txpower
For  cards  supporting  multiple  transmit  powers, set the transmit power in dBm. If W is the power in
Watt, the power in dBm is P = 30 + 10.log(W).  If the value is postfixed by mW, it  will  be  automati-
cally converted to dBm.
In  addition, on and off enable and disable the radio, and auto and fixed enable and disable power con-
trol (if those features are available).
Examples :
    iwconfig eth0 txpower 15
    iwconfig eth0 txpower 30mW
    iwconfig eth0 txpower auto
    iwconfig eth0 txpower off
[ Voor 29% gewijzigd door Verwijderd op 12-05-2006 00:35 ]
  • Tundreq
  • Laatst online: 28-07 23:30
Ik heb ook problemen met wireless op mijn laptop met ubuntu, nu wil ik niet zeggen dat het aan ubuntu ligt maar over het algemeen aan linux.
Ik heb namelijk wel vaker rare problemen gehad met netwerken in linux, namelijk dat ik verplicht was om dhcp te gebruiken.
Maar als je het probleem achterhaald sta ik ook vooraan want ik heb al 2 weken ubuntu draaien maar krijg het een en ander niet aan de draai.
Alles lijkt goed te gaan alleen krijgt ie geen ip en doet ie daarom niet, en het vreemde is dat het gewerkt heeft maar na een reboot was het over.
En wat ik ook probeer doen doet ie niet meer.
In ieder geval veel plezier ermee en ik wachtaf als iemand het probleem op heeft gelost.
  • Borromini
Borromini
Mislukt misantroop
Verwijderd schreef op vrijdag 12 mei 2006 @ 00:26:
Het probleem is dat RaLink devices het vaak nog op hun eigen manier doen, en niet altijd de standaard programma's van Linux gebruiken ;). Ik heb ook een RaLink (RT2500), die werkt bijvoorbeeld niet met wpa_supplicant (toch niet de native rt2500 beta drivers). De nieuwe rt2x00 all-in-one drivers die nog volop in ontwikkeling zijn zouden wel wpa_supplicant compliant moeten zijn.
dhclient eth0
Wat voor key gebruik je? ASCII of alleen maar letters & cijfers?
[ Voor 35% gewijzigd door Borromini op 12-05-2006 02:06 ]
  • TheGuest
TheGuest
De enige echte
Hoera!
Ik heb het aan de praat:
sudo iwconfig eth0 mode Managed
sudo iwconfig eth0 key restricted [1] <wepkey1 uit mijn router>
sudo iwconfig eth0 key restricted [2] <wepkey2 uit mijn router>
sudo iwconfig eth0 key restricted [3] <wepkey3 uit mijn router>
sudo iwconfig eth0 key restricted [4] <wepkey4 uit mijn router>
sudo iwconfig eth0 essid WLAN
sudo iwconfig eth0 txpower 30mW
sudo ifconfig eth0 up
sudo dhclient eth0
(Dit zijn hexadecimale keys uiteraard.)
Nu wil ik weer een stapje verder :P
Ik zit op de Haagse Hoge School en daar wil ik dus ook gebruik maken van wireless. Daar hebben ze leuke handleidingen voor geschreven (http://wireless.hhs.nl/) en in windows is het appeltje eitje. Maar in Linux wordt het heel erg vaag. Ik heb xsupplicant ingesteld zoals beschreven maar ik krijg het niet voor elkaar.
De vraag is; hoe krijg ik het voor elkaar om een wireless verbinding op te zetten waarbij ik mij moet authenticeren via PAP ?
[ Voor 5% gewijzigd door TheGuest op 12-05-2006 14:23 ]
  • FooLsKi
  • Laatst online: 14:39
FooLsKi
Prutz0r 4 Life
Als 1e mijn excuses voor het kicken van een bejaard topic. :)
Als 2e mijn probleem:
Ik ben al een paar dagen bezig om mijn Intel PRO/ 2200BG wireless weer met mijn netwerk te laten communiceren. Wat ik ook probeer, txpower blijft 'off' staan en ik krijg 'm met geen mogelijkheid 'on'.
Wat is het en wat draait erop?
Het gaat hier om een Acer Travelmate 4500 series, Pentium Mobile 1,5GHz, Intel 2200BG wireless, 1GB mem en dat alles op een Centrino-bordje van Intel. Dit alles draait onder Ubuntu 7.10.
Wat heb ik al geprobeerd?
Ik heb diverse programmaatjes gebruikt om verbinding te maken en netwerken te zoeken (wlassistant, RutilT WLAN Manager, Wifi-radar). Allemaal geven ze de melding dat radio off staat. Wlassistant geeft de mogelijkheid om de radio on te zetten, maar dat geeft in de terminal een error (Error for wireless request "Set Tx Power" (8B26) : SET failed on device eth1 ; Input/output error.). Ik heb bovenstaande tips met sudo iwconfig ook al geprobeerd, maar telkens loop ik vast bij het gedeelte waar ik txpower aan wil zetten. Ik krijg dan telkens de hiervoor genoemde error. Ik heb zelfs geprobeerd om de windowsdrivers via ndiswrapper te installeren, maar ook dat helpt niets. Hij installeert de drivers en ziet dat de hardware aanwezig is en that's about it...
Het heeft allemaal gewerkt onder 7.04, maar sinds ik ben "ge-upgrade" naar 7.10 is het drama. Het maakt ook niet uit of ik bij System - Administration - Network eth1 op roaming mode zet of niet. Ook het knopje op de laptop om wifi aan of uit te zetten helpt niet. Sinds ik de laptop op Ubuntu heb werkt het lampje daarvan ook niet meer, maar dat zal me een worst zijn.
Heeft iemand een suggestie of een gouden tip waarmee ik m'n laptopje weer draadloos onder Ubuntu kan gebruiken? Het is dat ik teveel van m'n computerspeeltjes hou, anders was 'ie al van 14 hoog het balkon af gegaan ;)
Hoezo, ik zit je raar aan te kijken? Zo kijk ik altijd! Slijpen is niet nodig, ik prefereer de botte bijl.
  • Jungian
Jungian
>_<
* Jungian zag weer eens wat over het hoofd
[ Voor 84% gewijzigd door Jungian op 28-12-2007 16:46 ]
0.0
  • Borromini
Borromini
Mislukt misantroop
Check welke gerelateerde pakketten een update gekregen hebben van 7.04 > 7.10 (bij voorkeur rond of op de dag dat je merkte dat het niet meer werkte). Als het vroeger was dan is het misschien een dependency- of configuratieprobleem.
  • FooLsKi
FooLsKi
Prutz0r 4 Life
Inmiddels heb ik de live cd van 7.04 erin zitten en dan werkt alles wel zonder problemen. Ik ga 'm nu maar ff downgraden naar Feisty en kijken wat er gebeurt als ik 'm daarna weer naar Gutsy upgrade. Geen zin meer om moeilijk te gaan doen, er staat toch niks bijzonders op die laptop :)
Edit: En nu doet alles het gewoon goed onder Gutsy...
[ Voor 9% gewijzigd door FooLsKi op 28-12-2007 18:35 ]
